rad/fan question
Post Date: 2014-03-02
kernols View Drop Down
  Quote kernols Quote  Post ReplyReply bullet Topic: rad/fan question
    Posted: 02 Mar 2014 at 4:44pm
Currently im using a 240 thick rad with two typhoons 1850 rpm pulling air in to cool a 3630k.  i wanted to mess around with adding 2 fans inside the case on the rad to make it push pull. problem is, the room between the rad and the motherboard is much slimmer than a standard 120mm fan.  so there are slim ones out there but which rpm/cfm fan should i go with.   something slower or faster than the gt's. i was reading slower rpm, is that correct?
