user6895
Topic: "Chip Set Posted: 18 Nov 2009 at 5:10pm |
When they say "chip set" just how many chips and which one's are LC with the new Stage 6 Dual Loop CPU, dual GPU and "Chip Set". I see 2 radiators but don't know which or how many the "chip set " entails. Also can I get the RAM fans with red LED's?
Thanks For Any Info
DST4ME
Posted: 18 Nov 2009 at 5:13pm |
by chipset they are talking about the water block for the mobo.
no you can't get red led for ram fans, they don't make any and DS won't change them. if you find one let me know, I'm looking for one also.
justin.kerr
Posted: 18 Nov 2009 at 5:16pm |
user6895
Posted: 18 Nov 2009 at 6:35pm |
Just what I need, do you know if the 60mm red fans is a direct replacment? Will it fit on the frame of the ones you get from DS for RAM cooling?
justin.kerr
Posted: 18 Nov 2009 at 6:58pm |
they are standard 60mm fans. you will have to wire them together, and put them on the mobo fan header, and run them at a bit slower than max, cause they are loud little suckers wide open
DST4ME
Posted: 18 Nov 2009 at 10:12pm |
you can't swap those, looked into that already, the original fans are 60 x 15, these are 60 x 25, I had found a nice orange 60mm pair for swap few months ago but then found out the originals are not as wide.
user6895
Posted: 19 Nov 2009 at 2:04pm |
Would it be possible to not get the RAM fan option and then buy from another source online that would fit the RAM with little needed mods. Who sells RAM fan kits that install easily on the DS system?
justin.kerr
Posted: 19 Nov 2009 at 2:11pm |
Originally posted by DST4ME
you can't swap those, looked into that already, the original fans are 60 x 15, these are 60 x 25, I had found a nice orange 60mm pair for swap few months ago but then found out the originals are not as wide. |
you just have to open up the bottom of the bracket.
justin.kerr
Posted: 19 Nov 2009 at 2:20pm |
The OCZ ones are a different disign, should not need to mod to make work.
user6895
Posted: 19 Nov 2009 at 2:24pm |
Do you think these would work on any RAM or would you need Corsair RAM? They have no RED LED's which is what I want, but they do have some red paint on them, might do in a pinch.
CMXAF2 GT - Corsair Airflow 2 GT cooling fans for memory
Edited by user6895 - 19 Nov 2009 at 2:34pm
justin.kerr
Posted: 19 Nov 2009 at 2:29pm |
the ones designed for triple RAM setups will all fit. the OCZ ones should fit the red led fans with no mods.
DST4ME
Posted: 19 Nov 2009 at 5:27pm |
I don't think they will fit, the fan is gonna be lower and can hit the ram itself, how much clearance is there between the 60 x 15 and the ram from the bottom of the fan to the top of the ram? if there is room then it should work but I was told by a DS tech that it won't work.
Edited by DST4ME - 19 Nov 2009 at 5:28pm
justin.kerr
Posted: 19 Nov 2009 at 9:38pm |
lots of clearance Clarence 15- 20 MM
