Originally posted by AndydViking
EDIT: I'd go with the Haf X because your going liquid cooling which will cause you to loose some of the dampening material/area of the 550 D right away and bring the fans to the top of the case without the material there to prevent noise escaping. If you were going air it'd be a little different.
Thanks for the advice.
I've made the following changes:
Processor: Intel Core i7 2700K 3.50 GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
Motherboard: ASUS Maximus IV Extreme (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Western Digital (7200 RPM) (Model: Black Edition) (SATA 6Gbps)
Video Card(s): 1x NVIDIA GeForce GTX 670 2GB (Includes PhysX) (Overclocked EVGA 02G-P4-2672-BR)
H20 Tube Color: Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
CPU Boost: Stage 3: Overclock CPU 4.9GHz to 5.2GHz (Requires Extreme Series Motherboard)
Virus Protection: Trend Micro Titanium Internet Security
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Medium)
Just one more question, If I wanted to add a second GPU would the above cooling and power requirements be sufficient?
