Question about Velox RigPost Date: 2014-11-27 |
Donzi
Newbie Joined: 27 Nov 2014 Online Status: Offline Posts: 2 |
Topic: Question about Velox Rig Posted: 27 Nov 2014 at 1:09pm |
Hello DS!
I am a soon to be Velox owner but I have a question about my order #39616. I was informed that the slim bay cd drive was on back order and or out of stock and was asked about using a regular cd bay drive and I went on and said "OK" in anticipation of getting my computer. After some thought and reviewing photos online it would appear that by doing this I would be losing one fan on the front of the case and the option to run a 3xRad in the front of the case as I presume one fan has to be removed to fit the regular cd bay drive ? Would this thinking be correct ? If so I would prefer to wait as to maintain the 3xfans on the front and not have the unused slot on the front of the case. Aesthetics and performance are one in the same for me and I would rather hold off and have the aesthetics as well as performance over a speedy build process. Would it be to late to go with a pre built loaded Bolt 2 Battle Box in black over the Velox as I notice DS now has the pre built option. Thanks, Kevin |
Quote Reply Posted: 27 Nov 2014 at 4:05pm |
Hi Donzi,
Your configurator number doesn't work. Seems that it is too old and doesn't work in the system any more. I agree with your thinking. I would wait for the slim bay cd drive and not go with a regular drive. I know it is hard to wait but I would prefer to have a Velox over the Bolt. If you want a flexible system with many options for expansion or upgrading, the Velox is a better choice than the Bolt. In my opinion. Frank |
Donzi
Quote Reply Posted: 27 Nov 2014 at 5:58pm |
FrankW,
I will try contacting them tomorrow about the slim drive as I would much prefer to have that. I could always order one off the net as they seem to be all over the place out there. The the order number is currently showing it is in the stress testing phase so I guess when I call tomorrow I can learn more. Thanks, Kevin |
Quote Reply Posted: 27 Nov 2014 at 6:08pm |
that is an order number not a configuration number, which we can't check only DS and the person buying can Edited by ArkansasWoman777 - 27 Nov 2014 at 6:08pm |
Quote Reply Posted: 28 Nov 2014 at 4:51am |
Thanks ArkansasWoman777,
He did say it was an Order Number. Another old guy mistake. Frank |
