Originally posted by Muz
This is my first question. To keep it simple, lets take the new ATI 5870 card and pretend i have it now. On the 46" playing at 1920x1080, will i need 2 cards because of the size of the screen to get a solid framerate of 50-60 fps in todays games or can i get away using one? (ie modern warfare 2)
Second question. How would i conect those badboys to the pc? I will need a receiver for those speakers and was wondering if i need to connect a cable from the receiver to the soundcard or can i just connect the speakers to the soundcard directly?
- Rob |
Hey Rob.
as someone stated the 5870 is enough to power up both.
and as for NEC monitors, I do not recommend, they are so horrible even their high ends. I actually had burn ins with them from LOTR battle for middle earth + wc3
and I think Lineage2
Try out Samsung T series, T260HD (I am currently using) its basically LCD HDTV full 1080p Great natural Contrast (Not dynamic contrast i hate those)
or T240HD they come with built in decent speakers as well, and I figured with HDMI cable you get both Great sound + video (HD5800 series offer Blu-ray Bitstream) Currently i'm powering up the T260HD + 57" 57732 DLP 1080p
At the same time with 4870x2 (single card) gf watches HD movies on one, while i game play on other both connected to 1 pc.
so if you decide to watch movies and such off blu-ray or your HDD you get best of both worlds.
2nd as for speakers I stopped using them due to my monitor built in speakers instead if I wanna go all out loud, I slap on my headphones I perfer it over speakers unless I go true surround sound 5.1-7.1
And no reciever is not required (if you're buying a new speaker system 2.1 w/ sub), you can connect it directly to soundcard
(Creative x-Fi recommended)
Razor's 2.1 Is pretty impressive , I think they copied JBL's
and I personally love Logitech Speakers cause they are decent for their value.
A forgotten or discontunued company I praise is Siccurro (i think thats how it's spelled lol)
Some germany company known for good speakers at a low price. Hope that helps
