Performance problem needs troubleshootingPost Date: 2014-06-20 |
Slappyn
Newbie Joined: 18 Nov 2011 Online Status: Offline Posts: 3 |
Topic: Performance problem needs troubleshooting Posted: 20 Jun 2014 at 3:15am |
Hi All,
I have a problem with my computer. At random times it seems to lag. I would blame the internet except its not just pages is everything. The symptom is a glitchyness in my mmo game and freezing where 20 seconds later the battle is over but it looks to me like it has not even began. I have noticed the water cooling system make a sloshing sound a second before the glitching starts. The glitching happens at least once a day, anytime into my computer use (from 5 min on generally) and sometimes goes away on its own or a reset will solve it. This has been going on for a few days. What do you think? Specs below and thanks for helping. HAFF 922 with an I7 920 oc to 3.4GHz with an evga x58 micro chip set win 7 64 bit 6 month old GTX 780 Asetek Liquid CPU cooler All fans working Samsung SSD 16GB Ram |
Quote Reply Posted: 20 Jun 2014 at 3:23am |
I'm not an expert, nor even half as knowledgeable as most of the people you'll encounter here, but I have to ask something.
Have you checked your temps/voltages? Download HWMonitor and see if anything spikes.
I'm sure the smarter people will be here shortly to help, too.
Quote Reply Posted: 20 Jun 2014 at 3:27am |
Hi Slappyn... I would get some canned air and blow out the case of any dust buildup if you haven't already. Blow through the fan on your 780 and out the back with power off.
Blow out the Asetek coolers fins behind the fan. They can plug with dust. Download and run the free HWMonitor and check your cpu core and 780 gpu core temps while stressing the rig. Temps should be mid 80C or less. Good luck. Snaike beat me to it. Edited by bprat22 - 20 Jun 2014 at 3:28am |
Slappyn
Quote Reply Posted: 20 Jun 2014 at 3:38am |
Maybe its not a gushing sound from the radiator but it kinda sounds like one.
Quote Reply Posted: 20 Jun 2014 at 3:49am |
If you have noise coming from the rad or the pump unit mounted to the cpu, then it's a good chance the unit is failing. Try blowing out the rad and checking temps. Temps will tell you if that's it or a problem elsewhere.
If the temps are good then you could have a bad ram stick, a drive starting to fail, etc. |
Slappyn
Quote Reply Posted: 20 Jun 2014 at 4:37am |
Everything looking good here. Ill give it a good go over again for dust and check the rams sticks. Thanks
CPUID HWMonitor Report ------------------------------------------------------------------------- Binaries ------------------------------------------------------------------------- HWMonitor version 1.2.5.0 Monitoring ------------------------------------------------------------------------- Mainboard Model 121-BL-E756 (0x00000263 - 0x047853E0) LPCIO ------------------------------------------------------------------------- LPCIO Vendor Fintek LPCIO Model F71882F LPCIO Vendor ID 0x1934 LPCIO Chip ID 0x541 Config Mode I/O address 0x4E Config Mode LDN 0x4 Config Mode registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF 10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 20 05 41 20 19 34 00 00 3E 30 00 40 20 08 0A 00 00 30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 60 02 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Register space LPC, base address = 0x0290 Hardware Monitors ------------------------------------------------------------------------- Hardware monitor Fintek F71882F Voltage 0 3.39 Volts [0xD4] (+3.3V) Voltage 1 1.33 Volts [0x71] (CPU VCORE) Voltage 2 1.51 Volts [0x80] (DRAM) Voltage 3 1.35 Volts [0x88] (CPU VTT) Voltage 4 1.13 Volts [0x72] (NB CORE) Voltage 5 5.13 Volts [0x7A] (+5V) Voltage 6 12.26 Volts [0xA6] (+12V) Voltage 7 3.38 Volts [0xD3] (VSB3V) Voltage 8 3.28 Volts [0xCD] (VBAT) Temperature 0 39°C (102°F) [0x27] (CPU) Temperature 1 46°C (114°F) [0x2E] (VREG) Temperature 2 27°C (80°F) [0x1B] (System) Fan 0 1319 RPM [0x471] (CPU) Fan 1 1771 RPM [0x34F] (JPPWR) Fan 2 688 RPM [0x885] (JCHA) Fan PWM 0 100 pc [0xFF] (CPU) Fan PWM 1 100 pc [0xFF] (System Fan 1) Fan PWM 2 100 pc [0xFF] (System Fan 2) Fan PWM 3 50 pc [0x80] (System Fan 3) Register space LPC, base address = 0x0290 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 FF 03 00 00 FF FF FF FF FF FF 01 51 55 4C 00 00 10 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF 20 D3 70 80 89 72 7A A6 D4 CD FF FF FF FF FF FF FF 30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF 60 00 00 00 00 FF FF 04 00 00 00 FF 0E 40 2A FF 00 70 FF FF 28 FF 2E FF 1B FF FF FF FF FF FF FF FF FF 80 FF FF 64 55 5A 55 55 46 FF FF FF FF FF FF A8 FF 90 00 08 08 00 00 FF 7F FF 44 22 FF 55 55 55 FF 1A A0 04 6B 00 FF 02 C3 3C 32 28 1E FF D9 B2 99 80 0D B0 03 4D 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0E C0 08 87 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F D0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 3F FF 01 72 FF 00 FF FF FF FF Hardware monitor ACPI Temperature 0 39°C (102°F) [0xC32] (THRM) Hardware monitor NVIDIA NVAPI Voltage 0 0.86 Volts [0x35E] (VIN0) Temperature 0 31°C (87°F) [0x1F] (TMPIN0) Fan 0 1305 RPM [0x519] (FANIN0) Fan PWM 0 39 pc [0x27] (FANPWMIN0) Processors ------------------------------------------------------------------------- Number of processors 1 Number of threads 8 APICs ------------------------------------------------------------------------- Processor 0 -- Core 0 -- Thread 0 0 -- Thread 1 1 -- Core 1 -- Thread 0 2 -- Thread 1 3 -- Core 2 -- Thread 0 4 -- Thread 1 5 -- Core 3 -- Thread 0 6 -- Thread 1 7 Timers ------------------------------------------------------------------------- ACPI timer 3.580 MHz Perf timer 3.507 MHz Sys timer 1.000 KHz Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 4 (max 8) Number of threads 8 (max 16) Name Intel Core i7 920 Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Package (platform ID) Socket 1366 LGA (0x1) CPUID 6.A.5 Extended CPUID 6.1A Core Stepping D0 Technology 45 nm TDP Limit 130 Watts Core Speed 3590.8 MHz Multiplier x Bus Speed 18.0 x 199.5 MHz Rated Bus speed 3590.8 MHz Stock frequency 2666 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 4 x 32 KBytes, 4-way set associative, 64-byte line size L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size L3 cache 8 MBytes, 16-way set associative, 64-byte line size FID/VID Control yes Turbo Mode supported, disabled Max turbo frequency 2933 MHz Max non-turbo ratio 18x Max turbo ratio 22x Max efficiency ratio 12x TDC Limit 110 Amps Core TDP 110 Watts Uncore TDP 20 Watts Power @ 12x 52 Watts Power @ 13x 61 Watts Power @ 14x 71 Watts Power @ 15x 83 Watts Power @ 16x 97 Watts Power @ 17x 112 Watts Power @ 18x 130 Watts Max bus number 255 Attached device PCI device at bus 255, device 2, function 0 Attached device PCI device at bus 255, device 3, function 4 |
sabahat
Newbie Joined: 09 Nov 2014 Online Status: Offline Posts: 1 |
Quote Reply Posted: 09 Nov 2014 at 10:00pm |
I too tend to avoid BIOS updates unless the update fixes a specific problem that I am experiencing and it is that last thing I can do before replacing the motherboard.
sabahat
