Overclocking Failed
Post Date: 2012-03-04
chasblock View Drop Down
  Quote chasblock Quote  Post ReplyReply bullet Topic: Overclocking Failed
    Posted: 04 Mar 2012 at 1:19pm
I was getting blue screens periodically, and my PC would reboot. Finally got a message on boot up....the dreaded "Overclocking Failed".
Managed to get into the bios and load some configuration, not sure what it is, but the PC is up and running. Temps were low 30's C, so I don't think Temperature was an issue.
Guess I'll be calling DS this week to see if they can sort it out.
Forgot to add... I've had this system less than a week.
Video Card(s): 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX) (Overclocked EVGA Edition)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional
Enhancements: Touch V12XT Aerocool Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
Display: Samsung 24 inch (Widescreen) (Black) (5ms Response Time)
Edited by chasblock - 05 Mar 2012 at 5:22am
