Ordering soon
Post Date: 2012-07-18
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Topic: Ordering soon
    Posted: 18 Jul 2012 at 11:25am
Updated(2) - here she is http://www.digitalstormonline.com/comploadsaved.asp?id=709786
along with the computer i have gotten the X4 Sidewinder keyboard and Razor DeathAdder Black addition gaming mouse.
and im getting a second GTX 670 FTW
also for my monitor i got the Asus VS247H-P 24-Inch Full-HD LED Monitor
$2,479
Motherboard: ASUS Rampage IV Extreme X79 (Intel X79 Chipset) (Features USB 3.0
and SATA 6Gb/s)
System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series
(Highly Recommended) (Hand Tested)
Power Supply: 1200W Digital Storm Certified (Dual/Triple/Quad SLI Compatible)
(Silent Edition Highly Recommended) <b></b>
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM)
(Model: Black Edition)
Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL /
Network Connections)
Video Card: 1x NVIDIA GeForce GTX 670 2GB (PhysX) (FTW Overclocked EVGA)
Extreme Cooling: H20: Stage 3: FrostChill Cooling System: CPU Only <b></b>
Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is
Successfully Processed
Edited by N6D4 - 18 Jul 2012 at 10:57pm
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 1:25pm
bumpity bump bump
  Quote FrankW Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 2:19pm
Hi N6D4,
I am going to post your build here so everyone will know what we are talking about.
Chassis Model: Special Deal Hot Seller - SilverStone TJ09 (FREE Blue Exotic Exterior Paint Finish)
System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
H20 Tube Color:Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
1. You need to get Stage 4 cooling with the 240 rads. If that is too expensive then go for the Vortex 240.
2. There is no advantage to the 2133 memory over the 1600 DS memory. Save a few bucks.
3. If you can squeeze it into your budget the 1050 Corsair PS is a much better power supply. Comes with 7 year manufacturer warranty. The 800 GS comes with a factory warranty of 3 years but DS warrants it for 5 years.
4. I am not sure why you picked the TJ09 but HAF-X will give you better performance for a cheaper price. The only thing I like about your case is the color. The HAF-X has much better air flow. The TJ09 120mm fans operate at 1200 RPM and that is not a lot of air flow. It keeps the noise down but limits the cooling.
Edited by FrankW - 18 Jul 2012 at 2:29pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 2:30pm
Hi Frank... thanks for posting the config.      N6D4.,     in addition to the cooler fix., drop ram speed from 2133mhz to 1600mhz .      The higher ram speed you will not notice and can cause overclocking issues.   Also, drop cpu overclocking to stage 1. DS will not go higher than stage 1 with 3820 chip.    Good luck.     Ooops... Frank has this covered.   A little overlapping.
Edited by bprat22 - 18 Jul 2012 at 2:32pm
  Quote FrankW Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 2:42pm
That is good bprat22. I forgot the 3820 OC limit.
I know some don't like others to help with a build but I welcome any input from anyone. As you know I don't hesitate to jump in with my thoughts.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 2:45pm
My thoughts exactly.    The more info, the better for the customer.
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 3:29pm
Thank you for the help will change all of those and save some money. And also how is the 670 FTW sli and dual monitors.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 3:59pm
Sli gtx 670 FTW with dual monitors will give you great gaming.   If you game on both and play some of the gpu hogs like Crysis andBF3 you could game on at least High settings.     I would rather play on single 23/24" monitor but that's me.    Just seems less of a hassle.       Nice rig with the changes and keep us updated.
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 6:25pm
Same with me I changed to one 26" monitor :)
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 7:10pm
and also why do i have to go up to the stage 4? what will that effect?
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 7:23pm
Edited the main post now i just need help with a monitor.
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 10:58pm
here she is
and im getting a second GTX 670 FTW from amazon
$2,479
and SATA 6Gb/s)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Jul 2012 at 5:58am
That is a real nice config.
What was meant by going to the stage 4 cooling or the Vortex 240mm rad over the stage 3, is that the stage 3 has a smaller 120mm radiator and the stage 4 has a 240mm radiator and better parts.  The cheaper Vortex 240 also has a 240mm rad for less money and is a sealed unit..
But, if you're going for the UV tubing and don't want to add the extra cost of stage 4 cooling, then this will work.
You could go with the 1050HX psu for a few bucks more and get a better supply with better warranty.
You've put together a nice gaming rig.   Keep us updated.Big%20Smile
Edited by bprat22 - 19 Jul 2012 at 6:09am
  Quote FrankW Quote  Post ReplyReply bullet Posted: 19 Jul 2012 at 1:11pm
You are paying $110 more to get stage 3 cooling over the Vortex 240. So you are paying a premium for less cooling. Stage 3 uses a 120mm radiator and the Vortex 240mm uses a 240mm rad.
Take a look at the two photos below and compare the size of the rads.
120mm Stage 3 Cooling
240mm Stage 2 Vortex Cooling
N6D4 View Drop Down
  Quote N6D4 Quote  Post ReplyReply bullet Posted: 19 Jul 2012 at 1:27pm
Yes i know that but i would like the tubing in my rig
  Quote FrankW Quote  Post ReplyReply bullet Posted: 19 Jul 2012 at 1:36pm
Hi N6D4,
I assumed that you were going for looks and that is why I suggested Stage 4 cooling. It gives the advantage of the look and better cooling with better parts. But the choice is yours.
Edited by FrankW - 19 Jul 2012 at 1:36pm
