Ok, take a look at
Build 658243Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X
Motherboard: ASUS P9X79 PRO (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) <b></b>
Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) <b></b>
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 520 Series) <b></b>
Video Card: 3x SLI Triple (NVIDIA GeForce GTX 570 2.5GB (Includes PhysX) (EVGA 025-P3-1579-BR) <b></b>
Extreme Cooling: H20: Stage 2: Corsair H100 Liquid CPU Cooler (240mm Radiator) (Extreme-Performance Edition) <b></b>
Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard) <b></b>
It has a better case with better air cooling for the GPUs. A better SSD, and better HDD and a better GPU set up with x3 SLI. It's not too far over your budget and it is what I would recommend over the ODE 4.
