OC Question
Post Date: 2012-02-09
hotshot146 View Drop Down
  Quote hotshot146 Quote  Post ReplyReply bullet Topic: OC Question
    Posted: 09 Feb 2012 at 5:05pm
I have a 4.3 GHz overclock done by Digital Storm on my computer. The question I have when in the bios the vcore is set to 1.37v. When I check cpuid hardware monitior with no load it said the voltage is 1.38 and with load from prime95 the voltage is 1.40v to 1.42v. Is this just the software reporting the wrong voltage? I have the lastest version which is 1.19. Here are pics  with load and no load. Thanks
Tidgxor View Drop Down
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 10 Feb 2012 at 10:41am
Within the BIOS itself is the voltage set to any sort of auto feature? I know you said it was 1.37v, but I'm not familiar with the new BIOSes and that's the first thing I would check. I things that auto-adjust processor speeds, if left at default (stuff like Speed-Step, C1E, etc.) will change the vcore (at least on last-gen bioses).
Edited by Tidgxor - 10 Feb 2012 at 10:49am
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 10 Feb 2012 at 10:26pm
Here are screenshot of bios.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 11 Feb 2012 at 11:53am
I have a feeling its because of Intel SpeedStep, again, I'm not using the same platform as you, but I'm not sure why this would have changed. You might try temporarily disabling SpeedStep and see if the voltages still fluctuates that much. At the very least, it would rule the possibility of SpeedStep overriding the manual voltage out.
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 11 Feb 2012 at 2:45pm
I tried disabling SpeedStep and still have the same problem. I thought that maybe the software is reporting the wrong voltage but I downloaded the latest version with support for x79 CPUs.
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 11 Feb 2012 at 2:47pm
One more question could the settings on the last pic be the problem? The turbo mode parameters are all set to auto for voltage.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 11 Feb 2012 at 2:56pm
Yep, that was actually going to be my next guess. Turbo Mode essentially controls the voltage fed to the processor depending on stress levels. I always thought that it remained under the manual voltage though. However, in this case, I'm thinking the Auto is actually overriding the central manual setting.
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 11 Feb 2012 at 3:13pm
which setting should I change and to what should I change it to?
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 11 Feb 2012 at 3:19pm
Based on recent things I've heard on the forum, you are going to want to call Digital Storm and ask them, as if we change it, it may void your warranty. If they tell you what  to do though, you're good. So I'd wait until Monday then call them to be safe, I don't want to void your warranty by trying to help you Big%20Smile
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 11 Feb 2012 at 3:26pm
ok Thank You
Brewtus View Drop Down
  Quote Brewtus Quote  Post ReplyReply bullet Posted: 13 Feb 2012 at 5:01pm
I noticed the same thing happening with me. I requested the vcore be set to a maximum of 1.4
Wonder what's going on?
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 13 Feb 2012 at 6:47pm
Maybe hotshot146 will let us know after he has spoken to DS. I have a feel its Turbo, but can't say for sure simply because I don't want to mess with anyone's warranty.
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 14 Feb 2012 at 7:46pm
I will let you guys know when I call tomorrow.
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 15 Feb 2012 at 11:54am
Here is the email they sent me about the problem.
The design of the CPU allows it to automatically Increase the voltage required. There is no option in bios to disable this feature. The reason it does this is to keep the chip stable. As stress increases on the CPU it draws more voltage to keep up with the load. If the system failed to raise the voltage, it would become unstable and crash.  Because of this feature, the system is able to use a lower voltage when not under a very heavy load and keep the temps down.
Mike Davis
Customer Service Manager
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 18 Feb 2012 at 2:17pm
If the cpu does change voltage to be stable would it be better to change the vcore to auto so if the cpu needs less power the bios will change it and not be hit by the setting of 1.37.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 18 Feb 2012 at 3:03pm
Hi hotshort146,
From looking at your readings I see the Vcore going from 1.38 to 1.41. This is normal readings that you should be getting. As long as the Vcore is right at 1.4 you are good to go. I think you are worrying about a non problem.
  Quote hotshot146 Quote  Post ReplyReply bullet Posted: 18 Feb 2012 at 3:05pm
ok thanks
