NVIDIA Maxwell GTX 750 to require no PCI-E Power
Post Date: 2014-01-25
Nav View Drop Down
Digital Storm Employee
  Quote Nav Quote  Post ReplyReply bullet Topic: NVIDIA Maxwell GTX 750 to require no PCI-E Power
    Posted: 25 Jan 2014 at 11:40am
According to sources the Maxwell GTX 750 Ti is releasing on the 18th of February. The Maxwell GTX 750 is thought to be a simultaneous release, ie you should expect it to be released on 18th feb too, alongside the Ti. The GTX 750 Non-Ti will basically be a cut down variant of its big brother. It will also have 2GB worth of GDDR5 Memory but perhaps more interestingly it will not require an external power supply.
Its Power Draw is slated to be 75W and it will take that power directly from the PCI-e connection, requiring no external connector or PSU pins. Our sources insist that despite of this the GTX 750 will score about 25% better than its predecessor. We also expect you to see custom variants very soon, though the reference design should be available for sale as well (not just to OEMS).
Another piece of information is that the GTX 750 is being released to replace the GTX 650 Ti Boost. Now this is here where our already raised eyebrows go through the roof. If you remember the benchmarks, the GTX 750 Ti couldn’t beat the GTX 650 Ti Boost so how can the GTX 750 be expected to beat the same, with no power connector mind you? Perhaps they are referring simply to the price range?The price range target is speculated to be 200USD to 250USD including tax.
Source
Edited by Nav - 25 Jan 2014 at 11:47am
This page was generated in 2.832031E-02 seconds.
