Noise level for Stage 3 FrostBite CPU System?Post Date: 2008-12-22 |
djb
Newbie Joined: 22 Dec 2008 Online Status: Offline Posts: 1 |
Topic: Noise level for Stage 3 FrostBite CPU System? Posted: 22 Dec 2008 at 6:03pm |
I would just like to know how loud the H20 Stage 3 FrostBite CPU System is compared to some of the quieter air coolers (<20dB) on the market? My main priority is silence so if the Stage 3 cpu cooling system isn't completely silent, then I'll just opt for the Stage 1 Air Cooler and swap it out myself for a quieter solution. The config I am looking to purchase will include either a Core2Quad 3.0Ghz+ or one of the i7 cpus, if that makes a difference. I am not a gamer so I will be using a passively-cooled video card, Corsair 550w PSU, WD 10k rpm drive (installed in a SmartDrive enclosure), and quiet <18dB) case fans. Oh and is the 750Si case available without the see-thru window on the side?
Thanks!
DST4ME
Quote Reply Posted: 22 Dec 2008 at 7:48pm |
every liquid cooling system is gonna have some sound from their rad's fan and the water moving around, Noise in this case, is a matter of perception, what I think is quiet you probably think is loud.
you should contact DS, send them a ticket and ask them to give you a call, then ask them if the fans can be changed to more quiet ones or maybe they use the fans with least amount of noise already, I think talking to them will give you the best picture. |
