New Vanquish2 level 4 USB question
Post Date: 2015-03-17
Swap View Drop Down
  Quote Swap Quote  Post ReplyReply bullet Topic: New Vanquish2 level 4 USB question
    Posted: 17 Mar 2015 at 7:57am
The front 2 USB ports on the front of the case are not working, anyone know why? or what to do to get them to work? I just recently got my computer only yesterday. So far that has been the only issue. The 2 USB ports in the front are usb 3.0 so it would be nice to have access to them.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Mar 2015 at 8:11am
Hi Swap.....   Take off the left side cover and look for the wires coming from the top, front of the case.   The wires might come from behind the right cover and snake over to the mobo.   Some go to the bottom right of the motherboard for Power On, Reset, HDD led, etc and there is also a USB connector.  Follow it and make sure its plugged into a USB port on the mobo.  The manual has a mobo overlay picture to help identify locations on the mobo.
Hope this helps. Big%20Smile
Edited by bprat22 - 17 Mar 2015 at 8:12am
This page was generated in 3.515625E-02 seconds.
