Budget :4000-5000
Monitor: 2 23inch ISP 1920X1080 one for gaming
Usage: FPS Gaming
Video Rendering a lot of it and Video Editing
Should I go with the Z77 Ivy or X79(6core) ?
Here is what i got so far
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (PhysX) (Overclocked EVGA 02G-P4-2682-BR)
I will install a second and third Hard drive my self
Edited by Ghost-Ryder - 06 May 2012 at 4:51pm
