New Rig Advice
Post Date: 2012-05-06
Ghost-Ryder View Drop Down
  Quote Ghost-Ryder Quote  Post ReplyReply bullet Topic: New Rig Advice
    Posted: 06 May 2012 at 4:49pm
Budget :4000-5000
Monitor: 2  23inch ISP 1920X1080 one for gaming
Usage: FPS Gaming
            Video Rendering a lot of it and Video Editing
Should I go with the Z77 Ivy or X79(6core) ?
Here is what i got so far
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (PhysX) (Overclocked EVGA 02G-P4-2682-BR)
I will install a second and third Hard drive my self
Edited by Ghost-Ryder - 06 May 2012 at 4:51pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 07 May 2012 at 5:27am
For your video editing and rendering I would start with the Dreadnought Level 3.  The X79 platform is made for just that work, its quad channel ram and 6 core cpu able to handle the work quicker.
Edited by bprat22 - 07 May 2012 at 5:28am
  Quote Ghost-Ryder Quote  Post ReplyReply bullet Posted: 07 May 2012 at 3:24pm
THX for the help
I have ordered it with the Sabertooth X79 and the i7 3930K 6 core.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 May 2012 at 6:58am
That was fastBig%20Smile  CongratsAwesome
