New Rig, advice??
Post Date: 2012-03-22
cdavis117 View Drop Down
  Quote cdavis117 Quote  Post ReplyReply bullet Topic: New Rig, advice??
    Posted: 22 Mar 2012 at 6:21pm
[$2000--$2300]
A rig that can handle the newest games on the highest settings.
I'll be using it for gaming mostly. Not extremely hard core, but games like mass effect 1-3, minecraft, cod, assassins creed for example. I want to be able to run all those on the highest settings possible, even forcing more through NVIDIA Inspector.
Got a 120Hz monitor ready, not really for 3D (but I will be using it) but just for the 120Hz performance, so want the rig to be able to handle that.
I'm fairly decent with computers, and have been a gamer for a long time. I'm just done with consoles, not cause I hate them but because high res is pretty darn enticing :)
Saved Ticket #: 667513
Chassis Model: Special Deal Hot Seller - Cooler Master CM 690 II Advanced <b></b>
Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) <b></b>
Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) <b></b>
Hard Drive Set 1: Operating System: 1x (500GB Seagate Barracuda (7200 RPM) (16MB Cache)
Video Card: 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX) (Overclocked EVGA 015-P3-1582-BR) <b></b>
Extreme Cooling: H20: Stage 2: Corsair H80 Liquid CPU Cooler (High-Performance Edition) <b></b>
Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) <b></b>
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Mar 2012 at 3:45am
Hi cdavis117     Welcome to the forums...
You didn't mention monitor size or resolution, so I'll go 24" at 1920x1080 just for reference.
To max out modern gaming on that resloution you'd need sli, 2x gpu and up the psu to 1050Hx to handle it.  Or, go with 750HX psu and a single gtx680, just released and the best card out there.  It's expensive but still cheaper than going sli 570's and upping the PSu.
We like the D14 air cooler better than the H series coolers for dependability and lots less to go wrong and quieter, but your call.  Not sure the D14 would fit that case, probably, just not sure until I check it out.
Go for stage 2 overclocking, it's a boost in gaming, safe and the cpu and cooler can handle it just fine.
Config # 667664      Cost$ 2159
Video Card: 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) (EVGA)
 I always recommend the HafX case, but left the 690 in.  The HafX is quiet, has 230mm and 200mm fans  and is the best air cooling case, but that's me.  The gtx680 and that chip don't run very hot, so your call of course.
The changes if made would still be within your budget.
See what ya think and Good LuckBig%20SmileBig%20Smile
Edited by bprat22 - 23 Mar 2012 at 3:49am
  Quote cdavis117 Quote  Post ReplyReply bullet Posted: 23 Mar 2012 at 12:39pm
Thanks for the help! Ya, its a 23" 1920x1080 monitor. I'm loving the gtx 680, specially the more I read about it. I'll probably go with the HafX case, just because I think it looks awesome and can hold at ton of fans like you said. In reference to the D14 cooler vs the H series, is the air cooler more effective than the liquid? You mentioned dependability of the H series, do they have problems? Thanks for your help!!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Mar 2012 at 12:50pm
The D14' s cooling is better than H80 but about the same as H100.   As far as dependability, they have had some problems, even some of our forum members with it. I'm sure most don't t have problems, but nobody has had problems with the air coolers.   D14 is a big block of cooling fins with fans attached, no tubing, or small pump or fan controller in the pump head to go bad.       The H series do have a 5 year warranty, so most must run pretty good.
