Need your advicePost Date: 2014-10-29 |
tc
Newbie Joined: 29 Oct 2014 Online Status: Offline Posts: 8 |
Topic: Need your advice Posted: 29 Oct 2014 at 6:01pm |
I need a system to do much of computing, programming, video processing and watch movie. I only play games one in a blue moon. I am using 4K monitors. Is this a good configuration?
Specifications: System Configuration: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 Extreme Edition 5960X 3.0GHz (Eight-Core) (Extreme Performance) Motherboard: ASUS X99-DELUXE (Intel X99 Chipset) System Memory: 32GB DDR4 2666MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 850W EVGA SuperNOVA Expansion Bay: Dual Solid State Hard Drive Hot Swap Bay Optical Drive: - No Thanks Storage Set 1: 1x SSD (256GB Samsung 850 PRO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 970 4GB (Includes PhysX) Sound Card: Creative Sound Blaster Z HPC Processor: - No Thanks Extreme Cooling: Standard Factory Heat-sink and Fan H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Standard Intel Turbo Boost 2.0 Automatic Overclocking Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks NVIDIA SHIELD: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Quote Reply Posted: 29 Oct 2014 at 6:54pm |
You'll have to see if your software programs are compatible with SLI...I know Adobe is.
I assume you know how much memory you need, so it looks like the configuration with more cores and sizable memory could definitely handle your tasks. Editing 4K, from what I've heard, can be a bear so I'm not sure how that will go...you may want to poke around some professional editing forums to get their opinion. How tolerant are you of memory errors? If something has to be extremely accurate, then you may want to consider a Xeon processor and ECC ram. Currently no professional graphics cards have HDMI 2.0 outs on them, so you'd need to have monitors that support DP 1.2 if you want to display 4K at 50/60Hz. Also, keep in mind that SMPTE has not yet finalize the UHD standard yet. Still up in the air are color space (a lot of talk about REC 2020), dynamic range (probably end up using 12-14 bits), among other things. Hardware requirements can change between now and practically no current hardware can meet REC 2020. |
tc
Quote Reply Posted: 30 Oct 2014 at 5:35am |
I will look into Xeon and ECC ram.
Thanks for the information. |
Quote Reply Posted: 30 Oct 2014 at 7:20am |
We would be better able to provide advice if you would let us know what particular applications you intend to run. I would also suggest you do some research on the applications to determine if they are multi threaded or single threaded and if they can take advantage GPU acceleration. Multi threaded apps benefit from more cores, while single threaded apps work better at higher clocks. GPU acceleration would allow the applications to use the GPU to accelerate floating point operations, which they excel at.
tc
Quote Reply Posted: 30 Oct 2014 at 2:50pm |
Thanks all, I made my decision and ordered the system.
Quote Reply Posted: 31 Oct 2014 at 12:42am |
Welcome to the DS family..!!!
Quote Reply Posted: 31 Oct 2014 at 2:05am |
Congrats and welcome. Just curious... you do realize you only picked 250GB of storage right? That's not exactly a lot. Do you have your own HDD's and/or SSD's you plan on putting in there? I'm just curious is all.
tc
Quote Reply Posted: 01 Nov 2014 at 3:55pm |
Yes, I only ordered 250GB. I have my own NAS.
Quote Reply Posted: 01 Nov 2014 at 4:23pm |
Change that. Please, just take my word. Pay extra, get a better air cooler if that's what you really want... but don't get standard. |
Quote Reply Posted: 01 Nov 2014 at 5:16pm |
Also most motherboards onboard audio is a lot better now than what they was so a sound card may not be needed but its your choice really on that matter. I would compare both audio specs and see which is better before adding a sound card.
Edited by ArkansasWoman777 - 01 Nov 2014 at 5:17pm |
tc
Quote Reply Posted: 02 Nov 2014 at 7:14am |
Thanks AW777! I already ordered it but it is hard to change.
tc
Quote Reply Posted: 02 Nov 2014 at 7:16am |
Thanks, I already ordered the system. |
tc
Quote Reply Posted: 02 Nov 2014 at 7:38am |
I have been using Dell and HP desktops for over 20 years. This is my first desktop from DigitalStorm. Hope it will last at least 5 years for this system.
Quote Reply Posted: 02 Nov 2014 at 8:04am |
Did you change the extreme cooling or did you leave it as is? Also do note that DS is closed on the weekends but they will begin processing Monday, if you didn't change it and they run into heating issues during their testing they will probably contact you.
Edited by ArkansasWoman777 - 02 Nov 2014 at 8:06am |
tc
Quote Reply Posted: 02 Nov 2014 at 11:06am |
They are close today. I will see if they ask me to add the cooling. If they do, I might ask them to remove the audio card and add the cooling instead. |
Quote Reply Posted: 03 Nov 2014 at 12:20am |
They open at 9PST... and they are usually busier than a one-armed paper hanger at that time.. so try early and try often.
Quote Reply Posted: 03 Nov 2014 at 1:56am |
Unless it's changed, they'll probably run into an issue with the cpu cooling as none of the 2011 socket cpu's came with a fan/heatsink.
I guess intel figured you're going to be buying an Enthusiast cpu, you'll have an enthusiast cooling. Though at the end of the day, it's your pc and your money, but in my opinion, a better cpu cooler is 100x more important than a sound card. |
