Need some advice on my buildPost Date: 2014-12-31 |
Amasian
Newbie Joined: 31 Dec 2014 Online Status: Offline Posts: 1 |
Topic: Need some advice on my build Posted: 31 Dec 2014 at 4:42pm |
under 4000 Expectations: To run most new games at 1080p Usage: To play Far cry 4 and other games like evolve when it comes out Special Needs: Saved Ticket #: 1124746 Specifications: Processor optionIntel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) More Info CHANGE Motherboard optionASUS Z97-DELUXE (Intel Z97 Chipset) (Features 802.11ac Wi-Fi Connectivity) [+$196] More Info CHANGE System Memory option16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) More Info CHANGE Power Supply option750W Corsair CX750M More Info CHANGE STORAGE / CONNECTIVITY Expansion Bay option- No Thanks CHANGE Optical Drive optionDVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) More Info CHANGE Storage Set 1 option1x Storage (2TB Western Digital - Enterprise Edition) [+$92] More Info CHANGE Storage Set 2 option1x Storage (1TB Seagate) More Info CHANGE Storage Set 3 option- No Thanks CHANGE Set 1 Raid Options option- No Thanks CHANGE RAID Card option- No Thanks CHANGE Internet Access optionHigh Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) More Info CHANGE MULTIMEDIA Graphics Card(s) option1x NVIDIA GeForce GTX 980 4GB (Includes PhysX) More Info CHANGE Sound Card optionIntegrated Motherboard Audio More Info CHANGE HPC Processor option- No Thanks CHANGE ENGINEERING Hydrolux Cooling. Learn more. Extreme Cooling optionH20: HydroLux Level 1: Digital Storm Exotic Custom Cooling System (CPU Only) [+$524] More Info CHANGE H20 Tube Color optionGreen Tubing with High-Performance Fluid (UV Lighting Reactive) [+$0] More Info CHANGE Airflow Control option- No Thanks CHANGE Internal Lighting optionInternal Chassis Lighting System (Green) [+$10] More Info CHANGE Chassis Fans optionUpgrade Chassis With LED Performance Fans (Green) (Up to 6 Fans) [+$59] More Info CHANGE Chassis Mod's option- No Thanks CHANGE Noise Reduction option- No Thanks CHANGE LaserMark option- No Thanks CHANGE OVERCLOCKING CPU Boost optionStage 1: Overclock CPU 4.0GHz to 4.4GHz More Info CHANGE Graphics Boost optionYes, Overclock the video card(s) as much as possible with complete stability [+$45] More Info CHANGE Memory Boost option- No Thanks, Please do not overclock my memory CHANGE OS Boost optionYes, Disable and tweak all of the non-crucial services on the operating system [+$35] More Info CHANGE SOFTWARE Windows OS optionMicrosoft Windows 7 Home Premium (64-Bit Edition) [+$0] More Info CHANGE Recovery Tools optionWindows Recovery Toolkit (Bundled with Windows CD) More Info CHANGE Virus Protection optionFREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) More Info CHANGE Office Suite option- No Thanks CHANGE Game option- No Thanks CHANGE ACCESSORIES Branded Gear option- No Thanks CHANGE Display optionAsus 27 inch Professional PB278Q (2560 x 1440) (100% sRGB) (WQHD LED Backlight) [+$629] More Info CHANGE Surge Protector option- No Thanks CHANGE Audio option- No Thanks CHANGE Keyboard option- No Thanks CHANGE Mouse option- No Thanks CHANGE NVIDIA SHIELD option- No Thanks |
Quote Reply Posted: 01 Jan 2015 at 6:53am |
Hi Amasian... Welcome to the forums. Looks like a good build to me.
The gtx 980 will give you excellent gaming on the 1080p you mentioned or the 2560x1440 monitor you listed in the config. Good luck and keep us updated. |
