Need serious advice. Thanks in advancePost Date: 2015-05-05 |
20NDIANS20
Newbie Joined: 05 May 2015 Online Status: Offline Posts: 2 |
Topic: Need serious advice. Thanks in advance Posted: 05 May 2015 at 9:40pm |
Max $3000 Expectations: I want a computer system that will last a few years without needing any major upgrades. Usage: Essentially running games at the highest possible graphics and fps, with a small amount of video and photo editing. Special Needs: Powerful enough to handle all of this with ease, and still be a powerful rig in a few years Saved Ticket #: 1192995 Specifications: Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE G1.Sniper Z97 (Intel Z97 Chipset) (Onboard Creative Sound) <br><strong></strong> System Memory: 16GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) <br><strong></strong> Power Supply: 850W EVGA SuperNOVA <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) <br><strong></strong> Storage Set 2: 1x Storage (3TB Seagate) <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 970 4GB (Includes PhysX) <br><strong></strong> Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) I do not really have a whole lot of experience with building computers so any advice you can provide me would be greatly appreciated. Google search is only so helpful I'm afraid. |
BiohazardX-87
Newbie Joined: 17 Jun 2012 Online Status: Offline Posts: 51 |
Quote Reply Posted: 06 May 2015 at 5:40am |
Welcome
Here is some advice I received when looking for the same thing you are. First, they will need to know the resolution of your monitors to help with Graphics suggestions. Second, here are some tips. Quoting from the advice people gave me - MOBO: The Sabertooth MOBO has a longer warranty 5 year vs 3 years MEMORY: 1600MHz would sufficiently get the job done and save you some cash. PSU: The 750W SuperNova has the same 10 year warranty and will safely cover what you are running. STORAGE 1: Switch the SSD for the Samsung PRO. None of these are necessary changes, just suggestions to save money while maintaining performance, or to improve performance. Good luck. |
Quote Reply Posted: 06 May 2015 at 9:44am |
Hi 20NDIANS20,
You got some very good suggestions from BiohazardX-87. I agree with everyone of them. One other thing to consider is to change your CPU cooler to The H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU. The cost is $70. It gives you a closed loop cooler that works very well in the Apollo case. The cooler will be mounted at the top of the case instead of at the back like the one you chose. Not to say the one you chose is not good, it is just that the 280mm is bigger with improved cooling. Not quite as important for a stage 1 OC. Frank |
20NDIANS20
Quote Reply Posted: 06 May 2015 at 9:50am |
Thanks for the input guys.
As of right now my display will actually be a 40" HD Vizio tv that i currently have mounted for consoles. I have however heard that HD tvs of this size aren't as great for resolution, and if that is an annoyance i will be purchasing a different display after some research. |
