Hi all,
Any input on the below?
I have read a bunch of posts going back in the forums (been reading for
several years). I have an XPS on its
last legs and it is time to replace it.
I am currently running 2 IPS
monitors at 1900x1200 (why have they basically stopped making these???)
although I may move up to one 2560x1600 (and maybe one or both 19x12’s on the
sides) (or the 2560x1600 with 2 1600x1200 [which I already have] in portrait on
the sides, a configuration I read about on here about 6 months ago but can’t
find the post; DST4Me commented on it as pretty cool at the time IIRC) (dream config 2x2560x1600)
Budget: mid-3k, the less expensive the better, the big monitors don't buy themselves.
Uses:
No Cad No Video Editing (hence the i7 3770K based on
previous posts; not adverse to going higher)
-This means a Z77
MoBo (and I like the one below with built in Wifi); but am I missing out on
anything by not going with the 3930 and the X79?
RTS/Some FPS (don’t necessarily need the absolute best
highest res and frame rate)
Trading (one reason for multiple screens) programs and data intensive
spreadsheets; movies/multimedia
Need USB 3 (speed)
Need hot swappable HDD slots (currently using too many
external HDDs)
Want it as quiet as possible. The below build is based off one of Frank’s
and others’ previous suggestions which is why I am with the HAF X over the 550D
which was my original consideration (see Ticket Number: 689303 for original config). Also why I chose Phanteks over LC.
With the HAF X, should I choose noise reduction/noise dampening?
Ticket Number: 689328
Total Price with Instant Savings: $3,198.00
Processor: Intel Core i7 3770K 3.50 GHz (Unlocked CPU) (Quad Core) (Requires
Z77 Motherboard)
Motherboard: ASUS P8Z77-V DELUXE (Intel Z77 Chipset) (Higher Overclocks and
Unique Wi-Fi Features) <b></b>
System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series
(Highly Recommended) (Hand Tested) <b></b>
Power Supply: 1050W Corsair Pro Silver 1050HX (Dual/Triple/Quad SLI
Compatible) <b></b>
Hard Drive Set 1: Operating System: 1x (180GB Solid State (By: Corsair) (Model:
Force GT Series CSSD-F180GBGT-BK) (SATA 6Gbps) <b></b>
Hard Drive Set 2: Multimedia\Data: 1x (2TB Hitachi/Seagate (7200 RPM) (32MB
Cache) <b></b>
Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL /
Network Connections)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (Includes PhysX)
<b></b>
Extreme Cooling: AIR: Stage 2: Phanteks PH-TC14PE Extreme Performance
<b></b>
H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS
Cooling System Selected
Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires
Pro/Deluxe/Sabertooth Motherboard)
Boost Video Card: FREE: Yes, Overclock the video card(s) as much as possible
with complete stability <b></b>
Boost OS: FREE: Yes, Disable and tweak all of the non-crucial services on the
operating system <b></b>
Windows OS: Microsoft Windows 7 Ultimate (64-Bit Edition) <b></b>
Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is
Successfully Processed
Thanks!
