this system is much better, and with a bit of upgrade down the road can be a beast and its upgradable and if you order during the current promotion, you will get another $125 off the price listed below:
here you go Ticket# 229776 --- Price: $2081 (To see this build click here)
Copy of Specifications:
Chassis Model: Cooler Master HAF 932
Interior Finish: - Standard Factory Finish
Processor: Intel Core i7 920 2.66GHz (Quad Core)
Motherboard: ASUS P6T Deluxe (Intel X58 Chipset) (Supports Dual SLI or CrossFire)
System Memory: 3GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Power Supply: 750W Corsair TX (Dual SLI Compatible) (Silent Edition)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x)
Video Card: 1x NVIDIA GeForce GTX 260+ 896MB (216 Streams) (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 2: Cooler Master V8 (Compatible With i7 Processors)
Liquid Color:- Not Applicable, I do not have a H20: Stage 3 Cooling System Selected
Boost Processor: Yes, Overclock the processor as much as possible with complete stability
Tweak Windows: - No Thanks, Please do not tweak the services on the operating system
Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition) (For Enthusiasts)
Benchmarking: - No Thanks
LCD Display: - No Thanks
Priority Build: - No Thanks
your own config will not work and will be priced higher anyways, for one thing you need to raise your psw to 750w to run the 260+ and above gpus.
Edited by DST4ME - 15 Jan 2009 at 6:33am
