Need advice on this buildPost Date: 2015-04-29 |
Sting
Newbie Joined: 29 Apr 2015 Online Status: Offline Posts: 2 |
Topic: Need advice on this build Posted: 29 Apr 2015 at 11:38pm |
Hi everyone, I'm planning to buy a computer so I've been googling companies that sell custom gaming PCs and I found this site. I've been reading the forums and see it's worth to buy from here. I would like if anyone can give me any advice to my build. I will really appreciate your help. Thanks in advance!
Budget: Around $1700-$1900 Expectations: Would like to play video games at high fps rates in Max settings. Using dual monitor at 1920x1080 resolution. Usage: Gaming and sometimes video editing Special needs: Have a quiet computer. Be able to upgrade any hardware in the future. Build: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 4690K 3.50 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE Z97X-SLI (Intel Z97 Chipset) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX750M Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks NVIDIA SHIELD: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Gunner GzR
Newbie Joined: 17 Apr 2015 Online Status: Offline Posts: 58 |
Quote Reply Posted: 30 Apr 2015 at 12:42am |
Only 2 things I might change is the ram up to 16gb and the motherboard (I don't like gigabit boards but that's just me)
Everything else looks good |
Quote Reply Posted: 30 Apr 2015 at 2:50am |
Hi Sting...... Unless you don't like the looks of the Vanquish 230t case, the Vanquish level 4 is almost identical for hundreds less.
Either way, they look good. |
Sting
Quote Reply Posted: 30 Apr 2015 at 5:14pm |
Thank you for your responses, @Gunner what motherboard would you recommend me to pick? Honestly, I don't know which one I should pick. I'm gonna try to change my ram to 16gb as you said. @bprat22 I looked at the Vanquish case and it looks nice so I might pick that one instead of the Apollo. At overall, do you guys think it's a good setup?
Thank you again Edited by Sting - 30 Apr 2015 at 5:16pm |
Gunner GzR
Quote Reply Posted: 01 May 2015 at 1:33am |
If the Asus is available go with that. I have always had good luck with Asus product's.
Edited by Gunner GzR - 01 May 2015 at 1:33am |
Quote Reply Posted: 01 May 2015 at 9:48am |
Hi Sting,
I second bprat22 suggestion. Frank |
