Need advice on new PCPost Date: 2014-11-03 |
Rem
Newbie Joined: 27 Jul 2010 Online Status: Offline Posts: 39 |
Topic: Need advice on new PC Posted: 03 Nov 2014 at 4:05pm |
hey guy,
I'm plan on buying new Desktop With DS!! sometime this week. I would like to get some opinion/recommendation before I put in an Order. ^^' Expectations: I will be using this PC for mostly Gaming, Watching Movie-Sport... Pretty much every thing ^^' I don't have Television. ;P I normally left my PC on all the time. I will reboot it once or twice every 2 week but rarely turn it off. I'm not sure if the spec that I have select will be stable or not. any advice or recommendation is welcome ^^' AMD Radeon R9 295X2 8GB seem to require a bit bigger power supply. hopefully, the 850w power supply that I pick is enough... >< also, I'm a bit confuse on the pricing. from what I have seen AMD Radeon R9 295X2 8GB pricing is around $1000 on amazon and other e-commerce site. but it seem to cost about $1,400 on DS website. is the card that DS use is different model from the one on market? really sorry it been a while since I buy my last PC, haven't keep up with the new lately. Thank you for your Kindness, Rem ********************************** EDIT : I already place an Order a few week back and already receive the PC. it working out great. ;D ********************************** here is my final spec Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Edited by Rem - 05 Dec 2014 at 7:15pm |
Quote Reply Posted: 03 Nov 2014 at 9:23pm |
Firstly, DS sells their items in regards to the cost it was for them when they purchased said cards.
So if DS bought them when they were $1500 then you can expect that price until their stock reflects as such. Though you can always call and talk to their sales team about it, I'd think. My recommendation would be the following: More storage space. Especially if you want a gaming machine. Get either another SSD that is bigger than 128GB or increase your one drive to something larger. Swap that R9 295X2 to some GTX 980's. If DS is charging $1400 for a R9 295X2, then you can get 2 GTX 980s for a much cheaper price and they will perform much better. For close to $1500 you can possibly get a triple SLI GTX 980. And lastly, I'd drop the Noice Reduction package. ASUS motherboards have some of the absolutely best integrated fan controllers thanks to their AI Suite 3 software. And an opinionated upgrade. Get that Hardline tubing to cool your CPU and GPU's. Especially if you want an extremely quiet system. And if you do decide to get it, make sure you refer to it as the EllerLux cooling system. Let me know if you have any questions over any of my recommendations. |
Rem
Quote Reply Posted: 03 Nov 2014 at 10:06pm |
about the storage, I plan on using the hard drive i have currently atm. I got 1 TB and another 150gb SSD that i plan on hooking up with this rig ;)
if ASUS MB already has good system then i will be dropping noise reduction. ;) I will have to see about EllerLux cooling system ;) for the GPU, I have try NVidia card a few time in the past and I always have issue with it . (it wouldn't work right for some reason ...) at this point I would prefer Radeon card. T_T regard, Rem |
Quote Reply Posted: 04 Nov 2014 at 3:04am |
That's fine. To each their own. I only use nvidia now a days. Even so, you can probably save money and get as good of performance out of 2x R9 290X over a single 295X2. Given that the 295X2 is so expensive on here.
Everyone has their own taste. I, for one, will keep using EVGA cards for a good long while. Given that you have a larger data storage set up and another SSD, then my recommendation would be to: Drop noise reduction Swap the 295X2 for either 2x R9 290X or 2x GTX 980's (I know, you don't like nvidia... but I wouldn't be able to sleep knowing I didn't state it in my recommendations). And if it fits you budget, since you're saving money on noise reduction and replacing that expensive 295X2, look at liquid cooling. It'll drastically help with sound, and give much better overclocking and overall cooling results. The difference in cooling here, because I mentioned the EllerLux (Or Hardline) is you can run a soft tubing build, or the hardline which is acrylic. The hardline tubing looks so much cleaner, where as the soft tubing is cheaper. Both offer same cooling results. I want to stress the consideration of liquid cooling because you're dead set on AMD cards. The 290X's run hot. Now AMD swears up and down they were built and meant to run really hot. But... well I'll just say it. AMD is stupid for doing it. It's a failed marketing set up on their part. Saying they want it to run hot, it's the design when really it's just a 7970 binned and overclocked higher, hence the higher temps. *claps AMD... * (Not animosity... I just call it how it is. Hopefully their 300 series is better). Either way, yea that's why a more exotic cooling is worth consideration. |
Quote Reply Posted: 04 Nov 2014 at 9:55am |
The issue I see with the cooling is that the exhaust cooling ports would both be covered by radiators. You will have the two top ports covered by the CPU's cooler and the rear covered by the graphics cards cooler. You might want to consider going for air on the CPU cooler, like the Noctua. That would give better overall airflow for the system.
Rem
Quote Reply Posted: 04 Nov 2014 at 10:28am |
@Meller
as for the GPU, for some reason the price for 295X2, 2x R9 290X, and 2x GTX 980's, is about the same the different is within $70. (their price is around 1400-1500.) at this point 1x NVIDIA GeForce GTX TITAN Black 6GB might be better choice for me as it about 200 cheaper...-*- for the cooling, depend on the price I get for GPU I might consider going H20: HydroLux Level 1 on CPU. @danjw1 Thank for the recommendation ;) I still not sure which GPU I'm getting yet (Price-wise ...T_T). if I end up with 295x2 then Noctua seem to be better option. |
Quote Reply Posted: 04 Nov 2014 at 10:29am |
Just to throw my thoughts into the ring...
I personally would opt for a sli 970 or sli 980 setup over the 295X2. The sli 970 benches almost the same, maybe 10% less for a lot less money. Sli 980 beats it. Plus, less heat and power draw. The 970/980 and the 295x2 all have the same vram, 4Gb, so that's a draw. My big issue with a dual gpu card is that if it fails you don't have another to fall back on like with a dual card in sli. If it fails and not covered by warranty, like a power surge, etc. then you're out a chunk of money. Dual gpu cards are great for a rig that can only hold a single card with its single Pciex16 slot. Just me. Edit.... a single 980 beats the Titan Black. Titan has more vram but 4gb is plenty for most. Edited by bprat22 - 04 Nov 2014 at 10:33am |
Rem
Quote Reply Posted: 04 Nov 2014 at 10:37am |
@bprat22
you do have a point. I haven't though of it that way lol. how is GTX TITAN Black 6GB performance btw. |
Quote Reply Posted: 04 Nov 2014 at 10:44am |
Titan Black is a great card, but big $$$.
Here's a link comparing the 980 to the Titan Black..... http://www.anandtech.com/bench/product/1351?vs=1186 Pretty darn close. Titan is really a scientific card for those that don't want to spend all the money on a Quadro but still need its double point precision for modeling, forecasting, etc. Works great for gaming but there are cheaper alternatives. I always look at things breaking. Too many years in field service has me paranoid. |
Rem
Quote Reply Posted: 04 Nov 2014 at 11:32am |
from the look of it, I'm might give Nvidia another try ;).
is it worth it to go for 2X SLI GTX 980? (the price is the same as 295X2) or is 2X SLI 970 is good enough for now? (about 500 cheaper ) Best regard, Rem Edited by Rem - 04 Nov 2014 at 11:32am |
Quote Reply Posted: 04 Nov 2014 at 12:19pm |
I don't think we talked monitor, but if you game on a single 1920x1080 or single 2560x1440 monitor then the sli 970 will game great. The extra $500 for 980s might be worth it if you go to multi monitor or 4k gaming. Then the extra 20% or so fps will be welcome.
If you use a single 1920x1080 then even a single 970/980 might be all you need. Depends on the game and settings you need. Can always add another later if needed. |
Rem
Quote Reply Posted: 04 Nov 2014 at 1:18pm |
I plan on upgrading to 2 X 1080 Monitor. prolly not going 4K, too expensive there ;S.
at this point I'm looking at ASUS VG248QE or PG278Q. Edited by Rem - 04 Nov 2014 at 1:33pm |
Quote Reply Posted: 04 Nov 2014 at 2:13pm |
For those monitors I would go with the 980s. The extra oomph will come in handy.
Rem
Quote Reply Posted: 04 Nov 2014 at 2:36pm |
Just update PC spec in opening post.
I change my GPU to 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX) still a bit unsure on CPU cooling, at this point I will prolly stick with Corsair H110 280mm Radiator Liquid CPU Cooler Edited by Rem - 04 Nov 2014 at 2:36pm |
Quote Reply Posted: 04 Nov 2014 at 5:12pm |
As long as you are going with air cooled graphics cards you should be fine with the liquid cooler for the CPU. The 980s run cooler than other top end cards, since they are less power hungry.
One more thing, I looked at your build in the Configuratator, and you have Windows 7. Windows 8.1 will support newer versions of DirectX that will be able to take better advantage of the 980's capabilities. My brother is using it after resisting for a long time, he added Classic Shell, to get back to more of a Windows 7 interface without giving up the benefits. It is something you may want to consider. Edited by danjw1 - 04 Nov 2014 at 5:21pm |
Rem
Quote Reply Posted: 04 Nov 2014 at 6:12pm |
is win 8 stable?
i usually dont touch newer version of OS until 3-4 years after it release. |
Quote Reply Posted: 04 Nov 2014 at 6:37pm |
From what i heard windows 8.1 is stable
Quote Reply Posted: 04 Nov 2014 at 7:51pm |
8.1 is quite good actually. It's a good upgrade.
Rem
Quote Reply Posted: 04 Nov 2014 at 8:39pm |
i see, i might try it out then ;) Win 8.1
since GTX 980 doesn't consume that much power then the power supply I select should be enough for 2X 980 (hopefully), 850W EVGA SuperNOVA Edited by Rem - 04 Nov 2014 at 8:43pm |
Quote Reply Posted: 04 Nov 2014 at 9:36pm |
I feel like I've been preaching about the GTX 980's this whole time, especially in SLI and I was denied. One other person says it and it's all of a sudden a "Oh, yea SLI GTX 980's... why didn't someone mention that before?"
Also, 2x GTX 980's or 2x R9 290X's won't be $70 cheaper than an 295X2 if the 295X2 is $1500. 2x GTX 980's would be about $1200 depending on the make and model you get (That's judging off of the 980 SuperClock ACX 2.0's from EVGA) and the R9 290X's are even cheaper than that. But... ew AMD. o.O I'm so confused here. Also, an 850watt is plenty for a GTX 980. Benchmarks have shown 4x GTX 980's pulling less than 500 watts... so two will be completely fine. |
Rem
Quote Reply Posted: 04 Nov 2014 at 10:12pm |
sorry Meller . after you recommend it and a couple other recommend it as well. I went back and do some more research since a lot of ppl seem to recommend it ^^', it got a lot of good review, so I though I would give it a try.
about the price, i don't know why but DS list them around the same price here is my config link https://www.digitalstormonline.com/configurator.asp?id=1088970 it might show lower price on your browser T_T. I will try to call DS tomorrow and see if anything can be done with it >< Edited by Rem - 04 Nov 2014 at 11:00pm |
Quote Reply Posted: 04 Nov 2014 at 11:01pm |
Not sure about the pricing. That is strangely expensive. Since you aren't water cooling your GPU's. You could always just buy one through DS, then buy the second yourself. That'll shave $700 off the total build cost... then drop the $500-$550 yourself for a matching GPU and save money that way.
@ Newegg a GTX 980 SuperClock ACX 2.0 is roughly $570... same on amazon. So Save $710 on total build, drop $570 yourself on a second card. Bam. Normally I can defend DS pricing, but... i'm at a lost right now. Not too sure what exactly is going on. Either the 295X2 is much cheaper than I thought on their site (I went off the original $1500 price tag you said). Obviously 2x $570 is < $1500 by more than $70. *shrugs* Yea, give them a call and see what you can work out. |
Rem
Quote Reply Posted: 04 Nov 2014 at 11:03pm |
yep, Will do that tomorrow ;)
Ariktu
Quote Reply Posted: 05 Nov 2014 at 7:13am |
I think AMD dropped the price on the 295x2 to around $1000 so the GTX 980 sli would likely be the same or more expensive depending on when DS bought theirs.
Quote Reply Posted: 05 Nov 2014 at 2:36pm |
At its shipped speeds the EVGA 980 Superclocked ACX 2.0 runs at 165W. So two is 330W at load, I doubt the rest of the system is going to take 520W. Power supplies generally have peak efficiency at ~50% load. With a CPU with a stock TDP of 88W, you should be around the sweet spot at load.
Quote Reply Posted: 05 Nov 2014 at 3:06pm |
You actually want full load to be up in the 70-80% range. This allows for an aged PSU to still handle loads, but it brings the efficiency at idle up. The PSU efficiency below 10-20% is horrendous and you do not want your computer to idle (where it spends a lot of time) below it. So, you do not want to over-spec your PSU either.
Rem
Quote Reply Posted: 05 Nov 2014 at 3:12pm |
I talked with DS sale dept.
They wont be able to do anything with GPU pricing. so I will prolly end up placing 1x GTX 980 instead of 2 with DS. then buy the 2nd GPU from newegg or something and do the SLI config myself. The spec in the opening Post look solid now, Thank a lot guy. ;) ! Once I figure it sort out the GPU issue, everything should be golden. Edited by Rem - 05 Nov 2014 at 3:18pm |
Quote Reply Posted: 06 Nov 2014 at 8:06am |
You are correct about over specing. The numbers do not include memory, motherboard and drives. But, this should give some room for overclocking with both CPUs and GPUs at higher voltages. So, I think that 850W is just about the right spec for overclocked dual 980 rig with a i7-4790k processor. It wouldn't hurt for Rem to discuss this with DS. Edited by danjw1 - 06 Nov 2014 at 8:09am |
Rem
Quote Reply Posted: 06 Nov 2014 at 9:17am |
I plan on Overclocking my CPU to 4.4, but I don't really have any plan to overclock my GPU.
Edited by Rem - 06 Nov 2014 at 3:58pm |
Quote Reply Posted: 07 Nov 2014 at 11:56am |
I would discuss power requirements with DS. EVGA suggests at least a 500W power supply in a system with a single GeForce GTX 980 Superclocked ACX 2.0. |
db188
Quote Reply Posted: 05 Dec 2014 at 4:15am |
i'm a little late to this discussion, but i would ask the OP why he plans to game at 1080p on 2xGTX 980 sli? or 2x anything for that matter? it's complete overkill of graphics muscle. you can game on max settings at 1440p with a single GTX 980 with almost every modern title (perhaps Far Cry 2 being the exception) out there.
my advice to anyone is that if you're going to drop that much dough on graphics muscle, then do it justice by paring it with a monitor/monitors to take advantage of it. 2xGTX 980's demand a triple monitor or 4k display setup, otherwise, go with a single card solution and game away at 1440p on a 28" 144 hz G-sync display. as far as cooling is concerned, i wouldn't put money into liquid cooling the GTX 980's until Nvidia lets their partners unlock the voltage. even though EVGA has recently come out with their Classified and Hydro Copper versions with custom PCB's they are still voltage restricted and won't overclock any better (on water) than they do on the custom air coolers that come with them. cooling the cpu, i'm not impressed with AIO coolers, so unless you plan on going with a custom loop i would invest in a good air cooler (i've got a Noctua NH-D14 in my current rig and it's simply awesome) for the same or less money than an AIO cooler. anyway, that's my 2c's worth. Edited by db188 - 05 Dec 2014 at 4:31am |
Rem
Quote Reply Posted: 05 Dec 2014 at 7:12pm |
Thank for the Help guy.
so I end up with 2x GTX 980 sli, current using 2 1080P monitor. I plan on buy either 4K or another monitor some time soon when they got a good price on it. here is my spec (place it,a few days back.) Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Edited by Rem - 05 Dec 2014 at 7:14pm |
db188
Quote Reply Posted: 07 Dec 2014 at 5:21pm |
this should be available soon (yum yum): https://pcmonitors.info/philips/philips-bdm4065uc-40-inch-uhd-4k-monitor/
for a good price it seems $700-$900. |
