Need a workstation for animation, music+
Post Date: 2011-03-09
OneLegos View Drop Down
  Quote OneLegos Quote  Post ReplyReply bullet Topic: Need a workstation for animation, music+
    Posted: 09 Mar 2011 at 4:39am
Hi, I've been to different shop sites, (Puget, ibuypower, imac) and now here to find a workstation.
Special Needs
: I don't overclock, don't want RAID.
I have a 1TB and 2TB SATA hard drives.  Cintiq Wacom display.
Spending $3000+ if necessary.  I have old accessories, so will not upgrade now unless recommended.
Expectations: I want programs to work quickly.  I hate when they need to wake up from being idle.  Run multiple programs, winamp, video player, photoshop, toonboom animtate, tv recorder, etc.  Future-proof.  Using two monitors (one being a Cintiq Wacom tablet display). Some gaming, I don't need maxed settings.
Usage
2d animation - ToonBoom Animate Pro
photo editing - Photoshop
music creation - FL Studio / Cubase
3d animation - maybe Maya (I'm not too much into this at the moment)
games - Diablo 3, Street Fighter IV, racing games (burnout / need for speed)
video editing - adobe premiere or other
web browsing
movie viewing (from the hard drive)
recording tv and game console gameplay - might get a Hauppauge HD PVR, currently have their pci tv tuner
-I don't know if what I have selected is overkill, and please recommend any changes since I feel like I'm guessing on all these core part selections.  I'm looking at the Protus workstations and don't know if I should upgrade a Protus C20 or go with the C40.
-does an added sound card improve a music creation program's performance?
-I'm not overclocking so is a heat sink and fan good enough?
Ticket: 497271
Chassis Model: Digital Storm PROTUS
Processor: !PROMOTION CLEARANCE: Intel Core i7 Extreme Edition 980X 3.33GHz (Six-Core) (Extreme Performance)
Motherboard: EVGA X58 SLI 3 Edition (USB 3.0 & SATA 6Gb/s) (Model: 131-GT-E767)
System Memory: 12GB DDR3 1600MHz Digital Storm Certified (Highly Recommended) (Hand Tested)
Hard Drive Set 1: Operating System: 1x (128GB Solid State (By: Corsair) (Model: Performance 3 Series CSSD-P3128GB2) (SATA 6Gbps)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Western Digital (7200 RPM) (64MB Cache) (Model: Black Edition WD2002FAEX) (SATA 6Gbps)
Video Card: NVIDIA PNY Quadro 2000 1GB (Outputs: DVI, DisplayPorts)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional (PCI-Express Slot Based)
Extreme Cooling: Standard Factory Heat-sink and Fan (Not Recommended for CPU Overclocking)
Boost Processor: - No Thanks, Please do not overclock my processor
Boost Video Card: Option Not Available
Boost Memory: Option Not Available
Benchmarking: - No Thanks
Sub-Total:$3,951.00
Thanks for your help.
Edited by OneLegos - 09 Mar 2011 at 4:41am
JStones View Drop Down
  Quote JStones Quote  Post ReplyReply bullet Posted: 09 Mar 2011 at 5:11pm
Hi Onelegos,
I too am a professional cg artist at a major vfx studio (not appropriate to actually say which one).  I think your build can be optimized greatly.
I will assume toonboom will use the same resources as maya, which is my primary program.
I do not know about audio programs though...
I would recommend the proc oc.  I used to think like you and avoid it to guarantee stability, but the oc done here is stable (I got it on one I recently got for a friend) and has been super stable.  It can only help you.  Just add a noctua air cooler.
Ditch the 980.  If you are after the extra cores get the 990, otherwise get a sandybridge 2600 and get the oc.  Kerr or one of the other frequent flyers here can verify but I understand the 2600 is faster than the 980 core for core, and if toonBoom is anything like maya its not very optimised for multi core usage anyways, the only exception being rendering.
I would also build a config in the "gaming" section and request that quaddro 2000 card be put in it.  Youll save a bunch of cash going with a haf case over the proteus or whatever it is.
I typically just use gaming cards myself, even though I do 0 gaming.  My geforce 480 runs all my apps smoothly on dual 30" monitors.
If you go the sandybridge route with a haf case you've just saved a bunch of cash that you could use to request more ram and bump up to 24 gigs...
