My ds review
Post Date: 2009-10-07
Page  <1234>
hemi392 View Drop Down
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 1:13am
i tryed it at 4050ghz with 1800mhz fsb and the vcore up to 1.4v it passed a 5 run with intelburn and i did a 15min with occt dunno if 15mins does much or not. occt temps were good intelburn ran hotter around 75C top and 60C for occt
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 1:19am
IntelBurn/LinX (same Linpack method) will make the cores hotter than any other program available.  5 runs is good, I generally do 3 per increase.
Those are still excellent temps.  Try 1833MHz FSB now, leave all voltages as they are first, and do a small increase if an error occurs, like 1.41-1.42v.
Edited by venom - 07 Oct 2009 at 1:19am
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 1:25am
ok testing now
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 1:41am
ok occt 15mins max temp was 65C and 3pass of intel burn 77C max 4125mhz,fsb 1833, vcore1.4,fsb1.35v
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 1:49am
Wow that is a nice chip... Can I have it?
Alright, now try 1866MHz FSB.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 1:54am
maybe ok im running the tests
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 1:59am
Wish I had a socket 775 board still.  Maybe I can get a 790i from somewhere... I have a Q6600 doing absolutely nothing.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:06am
must as well put it in somthing. ok occt 15min 65C max temp intel burn faild right away and then it crashed.
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:14am
When it bluescreens, look for the code down about half way on the screen.  Should be something like 0x00000000 (0x00000000, 0x00000000, 0x00000000, 0x00000000)
Two of the main ones you want to look for (before the ()'s) are 0x00000124 and 0x00000101.  101 = more vcore.  124 = more fsb, im assuming, it relates to VTT on the newer stuff.  50 = dimm, maybe fsb.  A = dimm.  There are others but harder to figure out which one relates to what.
Since it failed right away, try increasing Vcore to 1.42v.
Edited by venom - 07 Oct 2009 at 2:14am
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:15am
ok ill write them down
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:17am
ill increase vcore too
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:26am
0x00000101
0x0000000000000031
0x0000000000000000
0xfffffa60019d2180
0x0000000000000003
i bumped the vcore up to 1.4250v fsb still at 1.325v fsb 1866 still 4200mhz ill run some test now and see if it helped any.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:42am
ok occt 15mins max temp was 71C intel burn 3pass max temp was 79C
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:43am
Right on, now try 1900, 1.45v vcore.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:47am
ok will give it a try
  Quote Alex Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:48am
Nice to see our employee's helping out our customers overclock their systems.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:52am
yep
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 2:57am
occt ran for a min and it locked up no blue screen
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:02am
intel burn did one pass then blue screen same error cods
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:03am
0x00000101?  Try 1.475v if so.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:07am
yea same code 101 will try 1.475
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:28am
ok intel burn did a 3pass but temps got up to 87C which is hot didnt crash, occt went for 5mins max 72C and it locked up?
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:35am
Maybe OCCT is hitting the FSB harder, try increasing FSB voltage from 1.35v to 1.375v.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:36am
it will have to be 1.4v because its the only next choice in bios
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:39am
Oh that's fine then, I am used to the newer stuff, been about a year since i've touched an older socket 775 system.
If that doesn't help, give your DIMM a small increase, and if that doesn't work, lower both the FSB and DIMM to what they were and increase Vcore to 1.49375v
Edited by venom - 07 Oct 2009 at 3:40am
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:43am
occt ran for a min then it locked up
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:45am
ill try those and see what it does
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 3:50am
dimm would be mem volts?
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 4:02am
vcore at 1.49375v occt locks up after 5 mins
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 4:30am
I wonder why only OCCT is...  Interesting, try 1.52500v
Yeah, DIMM would be Memory.
Edited by venom - 07 Oct 2009 at 4:31am
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 11:28am
it just keeps locking up after a min on occt
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 10:08pm
i got it up to this, it was passing occt and intel burn. temps were still looking good cant seem to get it stable past this speed so i think ill leave it as it is.
  Quote venom Quote  Post ReplyReply bullet Posted: 07 Oct 2009 at 10:12pm
Great speed, could try for 1888MHz.
bears5150 View Drop Down
  Quote bears5150 Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 2:06am
awesome computer! hope to get one soon!
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 4:55pm
ill try it, run some more test and see what it does
 Post Reply Post Reply Page  <1234>
This page was generated in 0.2650146 seconds.
