My ds review
Post Date: 2009-10-08
Page  <1234>
hemi392 View Drop Down
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 8:32pm
occt ran 15mins didnt frezze up like its has been max temp was 72C, intel burn 3 pass max temps were mid 80's a little to high for my taste's of course intel burn runs it hotter where occt dont. i might be able to get a little more out of it. unless i can find a way to get less vcore to it so thiers less heat on the cpu dunno if thiers anything else i can fine tune to do that?
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 08 Oct 2009 at 9:33pm
just played ofp2 for about 45mins and it frozze so i guess it wasnt very stable yet
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 1:45pm
got it to stable out for about 2 1/2 hrs now havent tryed a longer test.
vdroop disabled
cpu core 1.3825v
cpu fsb 1.475 had to have it on this to stable it out 1.4v lasted for 2hrs
mem 1.5v
nforce spp 1.42v
nforce mcp 1.5v
cpu pll 1.5v
dunno if cpu fsb at 1.475v is good for it but its the only way i could get it to stable. i would like to have it at 1.4v if i could find some way to stable it out on those volts
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 11:49pm
Nice progress, 1.475v isn't too high.  You could try getting some better thermal paste and see if that shaves a few degrees off.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 10 Oct 2009 at 10:36pm
ill figure something out
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 12 Oct 2009 at 11:20pm
  Quote venom Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 12:30am
Right on!  What are the load temps?
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 1:30am
i think im having mem timeing or mem volt problems. loads were 70C-75C . my mem is 9-9-9-24 1.5v but is that what i have to run it at or can i change it to something else. settings now will run 3dmark with any problems but i do any kind of stress test and it locks up. i need to stable it some how im still figuring that one out
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 2:00am
load temps very on what testing program i use.some run 70-75 others 60-70 running same stress size.
  Quote venom Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 2:10am
1.5v seems a little low for the RAM.  Try 1.55v.  Stabilize the RAM now before tightening timings.
Very good temps!
Edited by venom - 13 Oct 2009 at 2:12am
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 9:47am
it says 1.5v and 9-9-9-24 on the side of my ram so is that just the min spec i can run it at???? is 9-9-9-24
a looser timing or a tighter?
  Quote venom Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 11:22pm
9-9-9-24 is quite loose, but I would try the 1.55v and even 1.6v if you are still having random freezing.  Once you get that fixed, try 8-8-8-20.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 11:50pm
all i know is that this oc is kicking my butt
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 22 Oct 2009 at 9:35pm
Edited by hemi392 - 22 Oct 2009 at 10:19pm
Asus X79 deluxe w i7-4820k
corsair 750w
Geforce gtx 660sc
Gskill 8gb 1866mhzs ram
signal loop water cooling for cpu
Sodius View Drop Down
  Quote Sodius Quote  Post ReplyReply bullet Posted: 15 Dec 2009 at 10:32am
I take it the timing has been resolved? So how is the machine performing now?
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 15 Dec 2009 at 12:14pm
i kept it at 4ghz for now  im having a hard drive issue i think at the moment  other wise  its running good on games
corsair 750w
Geforce gtx 660sc
  Quote Sodius Quote  Post ReplyReply bullet Posted: 15 Dec 2009 at 1:14pm
Great to hear, and 4ghz is nothing to sneeze at though, that is a very nice speed to be at as long as it is stable.
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 16 Dec 2009 at 11:48am
yea  until i get it figured out then ill probley go back up in speed for now im staying in a safe zone
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 28 Jan 2010 at 4:52pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 28 Jan 2010 at 6:11pm
well since i got my hard drive back iv been trying to get my oc back up to what i had it at  and i think im finally getting thier.just some pictures of my progress
vdroop on   vcore 1.4v   fsb 1.475
uploads/2665/Capture3.PNG   cpuz picture
uploads/2665/Capture.PNG     System idle
vdroop off      vcore 1.35625v      fsb 1.4v
uploads/2665/Capture5.PNG  occt 1hr test cpu temp
Edited by hemi392 - 30 Jan 2010 at 11:12pm
corsair 750w
Geforce gtx 660sc
  Quote Sodius Quote  Post ReplyReply bullet Posted: 28 Jan 2010 at 10:50pm
Very cool
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 31 Jan 2010 at 9:32am
3dmark 06 score uploads/2665/Capture9.PNG   its just the free download version not full
corsair 750w
Geforce gtx 660sc
Caleb View Drop Down
  Quote Caleb Quote  Post ReplyReply bullet Posted: 31 Jan 2010 at 1:14pm
lalalalalalalal
Bullseye View Drop Down
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 03 Feb 2010 at 1:17am
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 05 May 2010 at 9:23pm
Edited by hemi392 - 05 May 2010 at 9:25pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 05 May 2010 at 9:26pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 05 May 2010 at 9:27pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 06 May 2010 at 7:17pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 09 May 2010 at 9:44pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 09 May 2010 at 9:46pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 09 May 2010 at 9:47pm
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 09 May 2010 at 9:52pm
corsair 750w
Geforce gtx 660sc
justin.kerr View Drop Down
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 10 May 2010 at 12:25pm
very nice temps!
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 10 May 2010 at 5:52pm
yes they are but anything past 4300ghz needs alot of vcore and the temps climb way up   to much for 24/7 use
corsair 750w
Geforce gtx 660sc
sgtkawi11 View Drop Down
  Quote sgtkawi11 Quote  Post ReplyReply bullet Posted: 16 May 2010 at 10:27pm
This is a preview of my system just got it a couple weeks ago love it.Ouch
monitor and keyboard, mouse and inside with stage 6 liquid cooling duld vid. cards intel i7 at 4.4ghz quad core 1000w power supply
thank you so much DS this computer runs awesomeOuch defintley reccomend this web siteBig%20smile
 Post Reply Post Reply Page  <1234>
This page was generated in 0.2304688 seconds.
