monitors
Post Date: 2007-11-17
!ender_ View Drop Down
  Quote !ender_ Quote  Post ReplyReply bullet Topic: monitors
    Posted: 17 Nov 2007 at 11:32am
so my rig is in stage one!  and I've been sort of thinking about getting a new monitor, especially since I've heard that the newer ones are getting so cheap!
*I can tell that the new trend is to get a widescreen, most of my initial looking for a ~200 dollar monitor is turning up widescreens. Honestly, I'd prefer not to have a widescreen monitor, regaurdless of the trend...
*also I'm wondering where the best color depth is, Flat Panel LCDs seem to be the mainstream, glare is a bit of a problem for the one I have now Cry,
*and last, through my search for my new video card (8800 GT), I learned about DVI vs VGA out, (yes i know I'm behind the times) my question then, is: what is the real difference between DVI vs VGA, is it like RGB vs Coaxial for TVs? (aka absolutely no difference except how you connect it?)
what I'm looking for:
flat panel or comparably light (not CRT)
21-19 inch
good color depth / framerate
ideally NOT widescreen
$170-$210
no need for more than 1600x1200 res
I'm not looking for some bleeding edge 9000x90000 res 2000fps monitor with more colors than the eye could ever comprehend, im looking for a durable, decent quality monitor that will do my new rig justice (any tips for avoiding glare would be nice as well <3 )
Edited by !ender_ - 17 Nov 2007 at 11:39am
Dog Lover View Drop Down
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 12:05pm
I will be watching this post with bated breath as I am as we speak searching the web for a replacement for my 19 inch CRT that is about 7 years old and works great.... but its not going to work with the dual 8800 GTX's that are coming in my new DOS system.....
I will post some links if I find anything that may help.
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 12:10pm
Just curious.... What makes you think the 8800 GTXs won't work with a VGA monitor?
3.6 GHz E6850,       4 GB RAM, GTS 250,   TJ9, Win 7 64-bit
4.4 GHz i7 3930K, 16 GB RAM, GTX 670, 550D, Win 7 64-bit
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 12:17pm
The connections are different, right?  Mine does not have a DVI plug.  Just the blue one... That wont work with the 8800's, will it?
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 12:42pm
Most card manufacturers still include VGA/DVI converters. So you will be able to connect your old monitor to your new computer.
VGA is analog and DVI is digital. DVI is the newer technology (standard nowadays) and has the better image but it really isn't noticeable unless you take an extremely old vga monitor and put it side to side with a new dvi monitor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009087
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009109
Edited by skyR - 17 Nov 2007 at 1:07pm
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 12:53pm
oK.... Good Info... No answer this, my monitor has the blue plug... My Nvidia card now also has a white and blue plug area.  So, on the 8800's I see only DVI connections, right?  Where would I plug it in?
ed1371 View Drop Down
  Quote ed1371 Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 1:00pm
when you get your puter, it should come with a small adapter that connects the blue plug to the white connector.
Silverstone TJ-10
INTEL 4790K
16 gigs ddr3
ssd and such
liquid cooled cpu
2080 RTX Super
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 1:01pm
Oops... I re-read your post.... so, there are converters?  Do they come with it or something else to buy?  LOL..
Seriously, I am thinking to upgrade... here is what I am looking at:
And this is even labled as Certified Windows Vista!  Gaming forums give it good reviews, too...
Opinion?
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 1:10pm
All Samsung products are great =) That monitor can connect with either VGA or DVI too.
http://images10.newegg.com/NeweggImage/productimage/14-130-303-08.jpg
This is what most manufacturers include with their cards. You will be getting this stuff with your new Digital Storm computer.
You plug the DVI to VGA adapter into the back of your video card and you plug your monitor into the adapter.
  Quote ed1371 Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 1:13pm
well you said you are moving up from a 19"
I personally would get the 225bw (or the 226bw) its what I have now and its really nice.. the extra inches really do make a differance...
wow that didnt sound right... lol
samsung makes some really good monitors... so you will be well off choosing them
here is the one a lot of ppl like
Silverstone TJ-10
INTEL 4790K
16 gigs ddr3
ssd and such
liquid cooled cpu
2080 RTX Super
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 1:32pm
More great info........... I am still searching the web to see what I want.  I will take all of your advice into concideration.  I just do not want to go to big!  Heck, I am sitting what, 2 feet away from my screen playing video games?  My eyes will explode!
Minion View Drop Down
  Quote Minion Quote  Post ReplyReply bullet Posted: 17 Nov 2007 at 1:53pm
Not true, with just a little more caffeine your body will adjust. You just might not seem normal to everyone else.  Big%20smile
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 18 Nov 2007 at 2:11am
thanks for the help and opinions guys!
im going with the Acer AL1916Fbd, great pick skyR!
donkeypunch View Drop Down
  Quote donkeypunch Quote  Post ReplyReply bullet Posted: 18 Nov 2007 at 7:07pm
It's a good time for buying peripherals with Black Friday right around the corner. I just purchased a Samsung 24" 245BW for $500 not even a month ago. Circuit City will have it on sale for $320 for Black Friday! They have a 24" Acer for $250.
I didn't think there were too many jaw dropping deals worth fighting the crowds and waiting in 3 mile long lines this year but I saw a few things that tweaked my interest. I'm still kicking myself for missing that sale on the Toshiba HD-A2 HD player for $98 plus 5 free movies. The thing was practically free. Bah humbug! Dead
Why you all up in my puddin? :P
georges326 View Drop Down
  Quote georges326 Quote  Post ReplyReply bullet Posted: 18 Nov 2007 at 7:15pm
That Samsung 245BW is what I'm getting my son.  Costco regularly has it for $449 with an excellent return policy.  The CC price is based on approx.  $170 worth of mail in rebates off of their regular $499 price.
Have Fun,   George
  Quote donkeypunch Quote  Post ReplyReply bullet Posted: 18 Nov 2007 at 7:41pm
I love Costco! And yes, that price for the 24" Sammy is after MIR. Its a great monitor, I think he'll like it. If you unscrew the 4 back panel screws and remove the bolt you can then turn it to portrait mode. They don't advertise that feature and you don't have to break any seals or anything so it shouldn't void any warranty. But if you want the ability to rotate the monitor from landscape to portrait thats how ya do it.
Bigdog View Drop Down
  Quote Bigdog Quote  Post ReplyReply bullet Posted: 18 Nov 2007 at 8:49pm
My sister bought me the 24" samsung 245BW monitor.  I must say, this thing looks fantastic.  It's a very nice monitor.
Processor: QX6850 (3.3Ghz)
RAM: 4GB 1066 Dominators
Graphics: 2x 8800GTX 768MB
Sound Card: Fatal1ty
HDD 1: 2x 150GB raptor (RAID 0)
HDD 2: 1x 150GB raptor
HDD 3: 320GB western
Liquid cooling (red)
Hump View Drop Down
  Quote Hump Quote  Post ReplyReply bullet Posted: 18 Nov 2007 at 10:08pm
Where did you confirm this price for the 245BW?  I only see the 226bw for a sale price on their site.
  Quote donkeypunch Quote  Post ReplyReply bullet Posted: 18 Nov 2007 at 10:14pm
http://www.blackfriday.info/search.php?search=24%22+monitor
and another-
http://bfads.net/Search/24%22%20monitor/all+all+all/
Screenshot of the ad from Circuit City for 24" Sammy:
http://bfads.net/Samsung-24-HD-LCD-Widescreen-Monitor-at-Circuit-City
Screenshot of the ad from BestBuy for 24" Acer:
http://bfads.net/Acer-24-Widescreen-LCD-Monitor-AL2416WBsd-at-CompUSA
Thats also where they show the 24" Acer for $250. If you google "black friday deals" it'll list some sites where you can search for upcoming Black Friday deals.  Some companies released their sale prices early, some haven't. Granted it's with a MIR but it's a nice chunk of change your saving. Happy Holiday shopping! Tongue
Edited by donkeypunch - 18 Nov 2007 at 10:27pm
