Your build is way over your $2000 budget so I am going to ignore it also. If you are really locked into the $2000 budget then we will have to reconfigure.
Configuration: 696998 Cost: $3435
System Memory: 16GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 4GB (Includes PhysX)
The 670 4Gb GPU will be a good choice for the 2560 resolution.
Edit: I didn't notice the title of this thread. I guess you didn't need a configuration. The Klipsch ProMedia 2.1 is a system I have used since 2000. Great system for computers. The two speakers come with a black cloth covered screen on the front.
Edited by FrankW - 08 Jun 2012 at 6:40am
