MOBO?Post Date: 2014-10-17 |
Guests
Guest |
Topic: MOBO? Posted: 17 Oct 2014 at 5:19pm |
Hi,
Could this motherboard run Raid 0, times 4? I keep changing my mind on a configuration, the Aventum II case has 8 HDD/SSD bays. So was thinking of starting off with 4x 1TB Samsung 850 PRO SSD's from DigitalStorm. And later on I'd buy 4 other same SSD's from Newegg or something. And how would I setup Raid 0, is that some of device you attach or a program? Don't know a lot about computers & hardware. I know if 1 drive fails, you'll loose all data. But I don't mind, I don't want Raid 10 that takes 50% of the capacity. |
Quote Reply Posted: 17 Oct 2014 at 5:24pm |
1.) Should list the motherboard.
2.) Assuming it's the Rampage V that we discussed earlier, I believe it can. I'm not 100% sure how many arrays it can create. You'll have to do a search on the raid controller in the motherboard and the limitations on how many arrays it can create. |
Guests
Guest |
Quote Reply Posted: 17 Oct 2014 at 5:26pm |
Yes sorry, had it copied just forgot to paste it.
MOBO: ASUS X99 RAMPAGE V (Intel X99 Chipset) |
