Memory advice with Asus-Sabertooth X79
Post Date: 2012-06-25
MICHAEL2A View Drop Down
  Quote MICHAEL2A Quote  Post ReplyReply bullet Topic: Memory advice with Asus-Sabertooth X79
    Posted: 25 Jun 2012 at 3:41pm
Hey guys, this may be a dumb question but I need to get this straight in my head. The X79 Sabertooth is a Quad Channel board with 8 dimm slots holding up to 32 GBs of RAM. I was planning on using 8 GBs of RAM for my new build but would that mean I can only use (2 X 4GB)? Meaning two dimm slots with 2 4GB cards? The reason I ask this is because on the Asus website it has qualified memory listings that show (2 X 4GB) for use of 8GB of RAM. Can I only use 4 GB of RAM per slot and if that is the case, would it mean operating in dual channel rather than quad channel using only 2 slots?
Help me Obi-wan, your my only hope!
Im%20with%20Stupid
NZXT Switch 810
Asus Sabertooth X79
16GB GSkill Memory 2133mhz
i-7 X3960, 3.3Ghz-3.9Ghz
Intel 520 240GB SSD
2 WD 300GB V-raptors
Zalman CNSP11X cooler
2 GTX 680 2GB SLI
Corsair HX1050 PSU
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Jun 2012 at 3:56pm
I believe you need to fill at least 4   slots for quad channel ram.      Otherwise you take a hit in memory bandwidth.     I would suggest 4x4 Gb sticks.
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Jun 2012 at 4:26pm
You need to fill up your memory slots in either a 4 slot configuration or 8 slot. 4x4GB is best.
  Quote MICHAEL2A Quote  Post ReplyReply bullet Posted: 25 Jun 2012 at 5:35pm
Thanks again Alex! Your a lifesaver.Big%20Smile
NZXT Switch 810
Asus Sabertooth X79
Intel 520 240GB SSD
2 GTX 680 2GB SLI
Corsair HX1050 PSU
  Quote MICHAEL2A Quote  Post ReplyReply bullet Posted: 25 Jun 2012 at 5:36pm
You to bprat22. Thanks.
NZXT Switch 810
Asus Sabertooth X79
Intel 520 240GB SSD
2 GTX 680 2GB SLI
Corsair HX1050 PSU
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Jun 2012 at 5:38pm
No problem, but, bprat22 and all of the other forum members deserve the credit, they're awesome! Awesome
This page was generated in 9.301758E-02 seconds.
