Looking for insight on some upgrades for gaming
Post Date: 2014-11-18
grave17 View Drop Down
  Quote grave17 Quote  Post ReplyReply bullet Topic: Looking for insight on some upgrades for gaming
    Posted: 18 Nov 2014 at 2:47pm
Below are my current specs I'm starting to see a bit of a strain with my current rig and would like to start pricing and look at good upgrades for performance. Mainly I play recent games an see the chug such as in Dragons Age Inquisition, CoD AW at max settings on both and the new Far Cry 4. I'm thinking realistically all I have to do is switch out my 670 ftw for a 970 but if this thought process is wrong im open to better informed suggestions. Any all advice is appreciated thanks in advance
System Configuration:
Chassis Model: Special Deal Hot Seller - Corsair Carbide 400R
Processor: Intel Core i5 3570K 3.40 GHz (Unlocked CPU) (Quad Core)
Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) (Does Not Support SLI)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache) <b></b>
Hard Drive Set 2: Multimedia\Data: !CLEARANCE: 1x (120GB Solid State (By: Corsair) (Model: Force GT Series) (SATA 6Gbps)
Video Card(s): 1x NVIDIA GeForce GTX 670 2GB (PhysX) (FTW Overclocked EVGA)
Extreme Cooling: AIR: Stage 1: Cooler Master Hyper 212 EVO (High Performance Cooler)
Edited by grave17 - 18 Nov 2014 at 3:00pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Nov 2014 at 4:18pm
Hi grave17... You nailed it. All you need is the graphics card upgrade and the gtx 970 will give a huge boost. Between a 50% and double fps increase, game dependant.
Good luck and let us know how it goes.
  Quote grave17 Quote  Post ReplyReply bullet Posted: 18 Nov 2014 at 5:44pm
seeing as there are multiple 970's is any version in particular the best purchase choice I don't mind paying a bit more performance
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 18 Nov 2014 at 5:59pm
A high performance card that is rather quiet is the GTX 970 FTW, but from what I've heard, they are hard to find in stock. Another card to look for is the Galaxy GTX 970 Hall of Fame, which has the highest factory clock out there; don't know the availability of it though.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra
Bolt II
ASUS Z97I-Plus
i5-4590 w/ Corsair H100i
2x4GB DDR3-1866
EVGA GTX 970 FTW ACX 2.0
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 18 Nov 2014 at 7:02pm
it currently in stock on the Amazon site
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
  Quote grave17 Quote  Post ReplyReply bullet Posted: Yesterday at 2:57pm
So I am about to finalize my purchase with this card will I have any issues with how it fits or anything? I believe I wont but another pair of eyes just to be sure would be appreciated.
http://www.amazon.com/Gigabyte-GeForce-Graphics-GV-N970G1-GAMING-4GD/dp/B00NH5T1MS
Edited by grave17 - Yesterday at 2:58pm
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: Yesterday at 4:59pm
the length of the card is 12.28'' inches and the maximum card length that can fit in that case is 12.52'' so i don't think you should have any issues
Edited by ArkansasWoman777 - Yesterday at 5:00pm
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
This page was generated in 0.1005859 seconds.
