Looking for help building my rig! ^_^ *ORDERED*
Post Date: 2012-07-08
Page  12>
Stealth1984 View Drop Down
  Quote Stealth1984 Quote  Post ReplyReply bullet Topic: Looking for help building my rig! ^_^ *ORDERED*
    Posted: 08 Jul 2012 at 5:35am
My budget for this system is around $2200-2650 (2650 being absolute max). This is only for the PC itself. I will be purchasing the monitors and peripherals separately.
- A fast-booting, cool and quite running machine.
- Case-wise, simple is best in my opinion. Don't need or want flashing lights and such. Clean looks; great air flow cooling.
- Great processor, memory, and GPU a must. (would like to go with the 680 4GB with future intentions to SLI the card).
-Extreme gaming capabilities. Playing Diablo III, Guild Wars 2, Next Gen FPS games, etc. want to be able to run games on highest settings.
-Handle a variety of graphic design and photo editing software at fast speeds (Photoshop, Lightroom, etc...)
-Able to process many applications simultaneously without memory or processor constraints.
Would like to avoid water cooled systems, I don't want to worry about that maintenance. I don't mind adding more fans in an effort to keep things running cool. I want my system to run cool and quietly.
Anyways, here is a build I came up with. Please let me know what you think. I plan to order within the next few weeks. Cheers!
Config Number: 705970
Current Cost: $2615
Chassis Model: Special Deal Hot Seller - Corsair Carbide 300R
System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) <b></b>
Video Card: 1x NVIDIA GeForce GTX 680 4GB (Includes PhysX) <b></b>
Edited by Stealth1984 - 24 Jul 2012 at 10:29pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Jul 2012 at 6:43am
Hi Stealth1984.....That is a nice build, but I would use a different case.  The 300R has a single 120mm fan feeding air into it.  You could add fans, but that would be more money and noise.
Go with at least the 500R case, with 2x 120mm fans in front and a 200mm fan on the side panel feeding air over the cards and mobo.  We always recommend the HafX case for tops in cooling.  Its front 230mm  fan's LED can be turned off.  It is the best.
To save a few hundred dollars you might consider the gtx670.  It's performance is very close to the 680's for alot less money.  You didn't mention monitor size or resolution but a single 670/680 on a 23" at 1920x1080 will play games like BF3, Metro2033, Crysis warhead on high settings, not maxed out settings.  Sli would be needed for that which you did mention.
Here's a build to check out along the lines I mentioned.
Config # 706079     Cost $ 2599
Video Card: 1x NVIDIA GeForce GTX 670 4GB (Includes PhysX)
EDIT,,,,
Here's abuild better suited to your photo editing.  It has the X79 quad channel ram motherboard intended for ram intense programs. The Z77 mobo's are dual channel ram.
The quad channel ram has a substantially higher memory bandwidth for Photoshop, Lightroom,  editing, etc.
 I dropped to the 4 core 3820 chip to stay in budget.  Unlss you're really into editing, etc, the 6 core 3930k chip might not be needed plus it's another $300.
Config # 706080     Cost.......$2648
Not sure why you want the 4GB vram but I put it into both builds.  The money saved on the 680 to 670 change is allowing the better mobo for your apps and budget.
Good Luck again.Big%20Smile
Edited by bprat22 - 08 Jul 2012 at 10:50am
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 08 Jul 2012 at 8:01am
bprat, thank you very much for all your time and help. You seem to be quite the jack of all trades on these boards :P
Both of these builds look great. I am going to be running the PC on dual ASUS VW246H Glossy Black 24" monitors and a friend of mine suggested the 680 4GB card. Honestly I don't know a lot about GPUs, but I wanted something that wouldn't become quickly outdated. I am not the type of user who likes to swap components out every 6 months to stay up with the latest and greatest.
With that being said, would you recommend going with a different card setup in SLI? If it meant spending a little more now to get more bang for my buck in the long run, I guess I could manage it. Doing an SLI setup myself down the road isn't something I feel comfortable with. By all means given the fact I want to do a lot of gaming and editing work, what would you suggest?
Everything else makes a lot of sense and looks great. Thanks again for your time!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Jul 2012 at 8:19am
If the budget allows, and it does avoid work down the road and gives you great gaming out of the box, I would add another gtx 670  vram to the second build.  The X79 will play real nice with your editing and the 670's in sli are about $400-500 cheaper then sli 680's.  The 680's do give a 5-10 % better frame rate, but only you can decide if the extra money is worth it.
The 4gb vram doesn't seem to do much right now.  Reputable sites that bench the cards have only found Skyrim, heavily modded with texture mods, any benefit at all.  A couple of years from now??   Who knows.  Some go 4gb vram as a "just-in-case" scenario.  But in a year or two a new generation card will be out, so its hit and miss.
Sli 670/680 on a your dual monitor will max most games, but some will dip into the 50 fps range, which is still great gaming.  Just that some want ultra settings with 60 + fps at all times and that can get expensive.  That's if you game on both which I have never gotten into.  I would rather a single myself, but that's just me.
Hope this helps.Big%20Smile
Here's alink that compare single 670 to single 680.  It might help.
Edited by bprat22 - 08 Jul 2012 at 8:24am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 08 Jul 2012 at 8:39am
One more thought just to confuse you some more.LOL
As the price tag goes over $3000, have you considered the ODE level 4 for $2499.  It has the sli 670.  Doesn't have the X79 and only 8GB ram but ram is cheap to add.  The Vortex 240mm rad cpu cooler isn't true water cooling.  It's a sealed unit with zero maintenance.
Just another way to go .  Big%20Smile
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 08 Jul 2012 at 10:50am
I wish more people posted so through like the OP was.
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 08 Jul 2012 at 11:10pm
Haha, its like you read my mind. ODE level 4 is certainly the best choice from a financial standpoint, but I am still leaning towards the second configuration you listed.
Another question that came to me was, how hard will it be to SLI a GTX 670 4GB down the road? As much I as I want to, I just can't justify the $3,000 price tag of upgrading to the 670 GTX 2GB SLI right now. As it is probably obvious at this point, I don't have a lot of computer knowledge from a hardware standpoint. Is adding an extra 670GTX 4GB card say a year or two down the road something I could do myself? If it is as simple as plug in the hardware and play then no worries of course.
If trying to do an SLI upgrade myself is going to be too difficult I may just go with the ODE out of convenience. I feel so torn between the two at the moment :p
Edited by Stealth1984 - 09 Jul 2012 at 1:29am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Jul 2012 at 4:15am
Yep, tough decisions for sure.Cry
Adding another card in sli is very easy.  It just slips into the next PCIex16 slot, plug in the 2x 6pin psu plugs, connect the bridge cable that connects the two and set it up in Nividia control panel with a couple of clicks of the mouse.  That's it.
In all reality, in a year or two new cards will probably be out that beats the 670/680 line and those will be the new ones to have.  But, then the 670's will have dropped in price....Maybe.
A single 670 will give you great gaming.  Its all about $$$ and expectations.
If it was me, I agree and would go with the second build, the X79 build.  It is better for your needs, photoshop, etc. and a single video card is very good.  If this was strictly a gaming rig then the ODE 4 would be my pick.
But, that's me.  Good luck with the decision. Big%20Smile
Edited by bprat22 - 09 Jul 2012 at 4:19am
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 10 Jul 2012 at 6:03am
Alrighty, well it looks like I have all the information I need to make my decision. Moving back to the states from Asia in less than a month. Will be ordering in 2 weeks. I will post one final config before I actually place my order to make sure everything is right. Thanks again for all the help, feel like I am buying with confidence now :D
I wanted to ask one more thing in regards to the build... I really don't like the looks of the Cooler Master 942 HAF X case. I know it is one of the best air cooling towers on the market. However, the looks of the case is a bit too much for my taste. With that being said, I really want to stay fan cooling only. I very much like the looks of Halestorm and Slade cases. Is there anything else that offers comparable cooling that looks sleek and simple?
Build in its current form:
Config: 706332
Total Price with Instant Savings: $2,708.00
Changed the mobo around because I wanted the built-in wifi feature as opposed to adding a card.
Motherboard: ASUS P9X79 DELUXE (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) <b></b>
Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard) <b></b>
Boost OS: FREE: Yes, Disable and tweak all of the non-crucial services on the operating system <b></b>
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Medium) <b></b>
Edited by Stealth1984 - 10 Jul 2012 at 6:48am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Jul 2012 at 6:48am
The Hailstorm is primarily for full water cooling and the 550D will not fit the Noctua D14 if that's what you meant for fan cooling.  Its really all fan cooling, even stage 6 water.
The 600T and 650D both are sleek looking in my opinion and come with front 200mm and top 200mm fans for very good cooling.  The 500R case is nice  and has 2x 120mm fans in front and a 200mm on side panel to blow air right on the video cards and mobo area.
The Slade 550D won't hold the D14, but if you went with the Vortex 240mm cooler, DS would mount it to the top to give the case top fan cooling with the rads 2 fans.  The Slade is rated better than I would've thought with its small fans.
Hope this helps.
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 10 Jul 2012 at 6:58am
So if I decided to go with say the 650D I couldn't use the D14, but could switch over to the Vortex 240mm and not lose much in the way of cooling? Forgive me if I am misunderstanding you :P
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Jul 2012 at 7:02am
No problem with the questions.Big%20Smile
The 650D will fit the D14.  The 550D, Slade, will not, from what DS has told others.  Its just too tight a fit for the Slade.
The Vortex 240mm cooler has about the same cooling as the D14 so cooling would not be an issue either way.
EDIT.....Your latest build looks great.  DS will not overclock the 3820 chip to stage 2 oc'ing.  Stage 1 they might do.
The rest looks awesome.Big%20Smile
Edited by bprat22 - 10 Jul 2012 at 7:04am
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 10 Jul 2012 at 7:03am
Ah ok I see what you are saying now. Thanks for the clarification
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Jul 2012 at 7:07am
My pleasure. Big%20Smile
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 23 Jul 2012 at 5:57am
Alright, I am going to pull the trigger and order my system in the next couple days. Still feeling really torn between the following builds:
706332, 711189, and the ODE lvl 4.
I am willing to spend the extra $200 now and SLI the card say a year or two down the road if the custom build has significant more longevity in terms of upgrade ability. Don't really need or want the Blu-ray player which comes with the ODE, but that is just a small thing.
Couple questions that might help make the decision easier.
1. Will the 800w on the ODE power supply be enough to cover future GPU sli upgrades?
2. When wanting to add more memory, can I purchase any memory regardless of speed or manufacturer and expect it to be able to work with the memory coming from DS?
3. Are there huge differences between the 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache)versus the 1TB black edition HDD?
Would really appreciate some final insight before I make the decision as this is a fairly large financial commitment for me. Also, thanks again bprat for all you do on these forums. Users like myself are forever indebted to you.
Edited by Stealth1984 - 23 Jul 2012 at 6:58am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Jul 2012 at 8:02am
Hi Stealth1984.....Looks like you did some config'ing lately.Big%20Smile
Here's my thought....The ODE 4 is the best bang for the buck of all 3 configs.  You're pretty much getting almost everything for $200 less than the other two, except no X79 platform.
The first build, 706332, has the X79 for photoshop, etc, but only a single 670.  For dual monitor gaming if that is still your wish, you won't be happy for the gaming you want.  This one is 'out'.
The second build, 711189, is real nice with the sli 670 FTW oc'd versions.  But I would change the cpu cooler to the Vortex 240mm .  They mount it to the top and give that case better cooling.   I stilll like the HafX case the best but you can't warm up to it, so the 550D with the added radiator/fans to the top will help.
Here's a config to confuse you moreBig%20Smile but is a combo of the first one with X79 quad channel for the photoshop and the second build with the case you like and sli 670FTW oc'd.  It's another $100 but has it all.
Config # 711193       Cost  $2810
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (PhysX) (FTW Overclocked EVGA)
If this messes with your budget too much, and the extra $100 just kicks it over the edge, then drop to a single 670 and save $400 off this.  For single monitor it will be great with single 670,  If dual monitor struggles with what you want you can always add another later.
For the budget, the ODE 4 is very tough to beat.  Other than X79, it does it all.  A higher budget, above $2500, does give you more options.
Any of these configs are great.
The 800w should be fine.  DS uses it for alot of sli builds.  Future cards if the trend continues will be even more energy smart.  You're actaully better off going with the 750HX for another $50 if in the budget.  The 750HX has a higher efficiency rating, 90% vs 80%, giving you more juice potentialy, and a 7 year warranty.  But the 800w will work.
The 1TD black HDD is faster I believe but they are all fast, so for me they're all good.
Ooops...This config should be stage 1 oc'ing.  DS only does stage 1 for the 3820.
Memory is all the same for the most part, but the speed should match.
Tough decisions.Big%20Smile
Edited by bprat22 - 23 Jul 2012 at 8:21am
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 23 Jul 2012 at 8:53am
Side note.  You see the price tag of near 3000 but the machine will run like a 5000 dollar machine.  Trust in these responses.
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 23 Jul 2012 at 5:37pm
Thanks for the quick and extremely thorough response bpratt; would be lost without you <3
Here is the final build as I linger in the checkout window. I decided to upgrade the power supply like you suggested. I plan on making the purchase today.
Just want one last check before I make the leap :p If its all good then ordering we shall go!
Cost: $2,840
Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (PhysX) (FTW Overclocked EVGA)
Edited by Stealth1984 - 23 Jul 2012 at 5:37pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Jul 2012 at 5:56pm
That build nailed it.     I think its a bit over your initial budget but does give you everyythiing with no compromise.    Really nice.        Best of luck and keep us updated.
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 23 Jul 2012 at 8:55pm
Order Placed!
But shortly after received this via e-mail:
Thanks for your order The Power Supply: 750W Corsair HX is not enough to run 2x Nvidia 670 video cards. You need to go with at least 1000W PSU.
Is this true? I am already significantly over budget and really don't want to spend the extra $100 on a better PSU. the ODE lvl 4 has a 800W PSU powering the same GPU setup.
Looks like the DS offices are closed for the day, so I will have to wait til tomorrow to find out more... Any advice as to best option?
Edited by Stealth1984 - 23 Jul 2012 at 8:55pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 6:02am
That's the first I heard of it.  We have said for a long time that the 800w and 750hx just make it for sli  and the 1050hx for sli is a safer way to go, but DS has been building sli's with the 800w for a long time and that  is what customers come back with when we suggest it.  My first couple of configs in this thread did have the 1050HX.
I got away from pushing the 1050HX for sli because of builds DS does offer with it.  Looks like I'll be going back to it.
Unless the X79 is the added problem, I can't say.  Or, the FTW oc'd 670's is too much.  If the X79 chipset or oc'd 670 is the difference, which I doubt,  then a 800w would be too close  for any sli build in my opinion in which case the ODE 4 would be borderline.
Ask them on the phone to clarify and let us know.  Lots of builds with sli and 800w have been done unless they were all changed to 1000w and nobody got back to the forums.
 If you have to up the psu, then maybe dropping to the standard gtx670's and not the FTW oc'd version will help balance the cost, saving $60.
Edited by bprat22 - 24 Jul 2012 at 6:40am
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 6:48am
Good call, sounds like that is the way to go. I'll call them this morning and have them make the change.
Cheers :)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 6:55am
I would still be curious as to what the problem is.  If the 800w doesn't make it for your build, then that would change the help I give to others, even the ODE 4.  In fact, I think the 1050HX is the way for any sli rig.
Sorry for the mixup on my part.
Either way, you do have an awesome rig.  Just a small bump in the road.Big%20Smile
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 7:26am
Yeah man, no worries at all. I will try to find out exactly what it was in the build that tipped the scales.
Just curious, is there much loss in GPU performance by downgrading from the OC'd card to the regular version?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 7:31am
From the benches I've seen the oc'd cards give a few fps better with some games and not much with others.  It helps but not a deal breaker.
In a way its good this happened, in my opinion.  I'd rather put the money to a better psu then oc'd graphic cards.  In the end you'll have a better system.
Edited by bprat22 - 24 Jul 2012 at 7:33am
Specht101 View Drop Down
  Quote Specht101 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 12:28pm
Im looking to build an x17m that has performance like a desktop. Any suggestions or opinions on my build are appreciated. So here it is,
Intel core i7 3920XM extreme edition 2.9ghz turbo to 3.8ghz with 8mb cache, 32gb DDR3 1600mhz ram, intel 240gb SSD (520 series) (sata 6gb/s), 500gb at 7200rpm (sata 3gb/s) HDD, nvidia geforce gtx 680m 4gb with nvidis optimus technology, and windows 7 ultimate. My budget is 4k so i really am trying to build the best laptop possible capable of playing the next gen of games. RPGs and such.And with all the reading I've done on the needs think I've got it right
LaneHayes View Drop Down
  Quote LaneHayes Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 2:50pm
You can buy a desktop that will max everything for the next 2-3 years for $2500 and will hold up way better over time. Buy a tablet if you need common portability. Lugging a 17 inch laptop around is the opposite of portable. Gaming laptops make the most sense for people who travel a lot for work, not really for students.
That said, if you're dead set on a laptop, you can save some money on the RAM (scale it back to 16gb at least). Would keep the top of the line GPU, but I've  never seen a laptop gpu not degrade over time. Maybe the new stuff runs cooler and is different. However, if you're just playing mmorpgs, you might be able to get away with a cheaper GPU.
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 3:29pm
Yeah trust me I used to lug around a 17 inch gaming laptop portability was not in its vocabulary
  Quote Specht101 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 5:50pm
Yea I travel a lot for work so a desktop won't work for me. Thank you for the input though. Any money I can save is alright by me
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 10:25pm
LOL my thread has turned into something else or so it seems...
Was able to step down the cards to the non OC'd version while upgrading to the 1050W PSU so the price increase was minimal. Apparently it was the combination of the X79 and GPU SLI that could cause potential problems. The 800W might have been enough, but it would be a close call.
Best bet is to promote the 1050W PSU on future SLI builds IMO.
Order has been approved and currently in stage 1!!
Thanks again for all the help bprat. I just might name this rig after you
Edited by Stealth1984 - 24 Jul 2012 at 10:32pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Jul 2012 at 3:27am
Yeah, he highjacked your thread.LOL  Must be from all the excitement of reading your builds.
So glad it worked out and ,yes, the 1050HX or equivalant for sli is the way to go.  If its close with X79 and oc'd cards then too close for me with any sli.    This little blip ended up giving you a healthier rig.
Congrats and keep us updated.   Awesome
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 25 Jul 2012 at 3:51pm
Yeah I think it actually worked out for the best.
Machine is already in stage 5! I am returning home to states in two weeks after being away for 3 years. Looks like it will be sitting there to greet me :)
Pretty excited
  Quote Stealth1984 Quote  Post ReplyReply bullet Posted: 26 Jul 2012 at 5:11pm
UPDATE: Stage 7 QA Check Passed
Estimated Shipment Date: 0-1 business days (Mon-Fri) from 7/26/2012
ZOMG!!!1!
Tidgxor View Drop Down
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 26 Jul 2012 at 6:23pm
Awesome
Jesta42o View Drop Down
  Quote Jesta42o Quote  Post ReplyReply bullet Posted: 26 Jul 2012 at 9:55pm
Sweet ! mine shipped July 24th but won't be here till 30th
This page was generated in 0.25 seconds.
