jtspectra2
Topic: Liquid Cooled Xbox 360 Posted: 05 Dec 2008 at 6:01pm |
Q9650 @ 4.2Ghz( Liquid Cooled), 4GB 1600Mhz DDR3, GTX280 SLI, VRaptor,HAF 932
XpubuX
Posted: 05 Dec 2008 at 7:11pm |
This will void youre warranty on the xbox but may be worth it once the 3 year warranty is up.
MikeMaravani
Posted: 09 Dec 2008 at 11:59am |
Originally posted by XpubuX
This will void youre warranty on the xbox but may be worth it once the 3 year warranty is up. |
Well, in 3 years they just might have a new system coming out. There is talk on the web...
MarkNY
Posted: 11 Dec 2008 at 11:11am |
what is the point of that? can you OC an xbox 360 a ton with liquid cooling? is there any noticeable difference with game play?
White Aventum
3970X at 4.7Ghz
Asus Rampage IV Extreme
16 GB 2400MHz Memory
2x Nvidia Classified 680 4GB
2x 240 GB Neutron SSD
1x 1 TB WD Caviar
Liquid Cooled CPU/GPU/Chipset
jtspectra2
Posted: 11 Dec 2008 at 8:29pm |
no , but the 360 is loud as hell, im assuming it would take away from some loudness , also it keeps the CPU cooler . :D
its just something cool for us tech savvy people .
Rad!caL
Posted: 11 Dec 2008 at 10:19pm |
But now you can just load games on your HD so half the sound is gone without the DVD drive spinning.
MikeMaravani
Posted: 12 Dec 2008 at 12:10pm |
Thats true. I want to buy the Ultimate 360. Then I will do all the little tech projects.
Onkel_Ken
Posted: 13 Mar 2009 at 12:52am |
I think the xboxs are getting better. But my grandkid had one that died right after the warranty went out.
HAF 932/920 OC 3.60/V8
6GB 1333Mhz
HP w2408h Vivid Color/WS
