Kelly, when we spoke earlier I was under the false opinion that the factory setting on the QX6850 was 3.3GHz.
Therefore, my less than enthusiastic response of an OC'd processor running at 3.6GHz. My apologies. The QX6850 OC'd to 3.6GHz sounds quite reasonable!
This link will take you to the Metacritic score for "The Witcher" (http://www.metacritic.com/games/platforms/pc/witcher) -- so far the reviews are "generally favorable" at 81. Interestingly, user scores (141 reviews) on Metacritic are a very high 9.7 out of 10. IGN readers (112 reviews) are showing a combined rating of 9.4/10. Anyway, I've only seen the opening cut but it's VERY WELL done. I look forward to playing it tonight--then on to HELLGATE.
Again, thanks for the update and advice. Hope you enjoy your shopping spree this evening!
Keith
