Keep your registry clean!!!Post Date: 2007-08-01 |
Page 12> |
Robert
Newbie Digital Storm Customer Service Joined: 01 Nov 2007 Online Status: Offline Posts: 133 |
Topic: Keep your registry clean!!! Posted: 01 Aug 2007 at 5:34pm |
It is VERY important to maintain a clean registry.
First, please open up a run command. (Start->Run->CMD) or Hold down the Windows key and press R. Type in regedit. Then go to File, then Export. Please save your registry back up to a folder you will remember. It is VERY unlikely you will need to use this, but it can happen. Download Abexo Registry Cleaner, Eusing Registry Cleaner and CC Cleaner. I've been using all of these applications for years and guarantee they are malware/spyware free. You can even read the reviews of these applications at download.com. Before running these applications, please take the time to uninstall any unused or unnecessary applications on your system. The reason being, these registry cleaners will come by and clean whatever those programs left behind. From experience 99% of applications leave some dirt. Now you're ready to scan your registry and clean it up!!!! Each of these programs are very straight forward, but if you have any issues please post here and I'll help you out! CC Cleaner has different functions, it cleans your internet traces but also has a registry cleaner. The reason I'm recommending all three is because no matter what order you run them in all three will find issues! Cheers! Edited by skyR - 22 Oct 2007 at 7:00pm |
Vjzzerdrjx
Groupie Joined: 06 Aug 2007 Online Status: Offline Posts: 57 |
Quote Reply Posted: 07 Aug 2007 at 4:45pm |
I just used all three of those, cleaned out over a gig of random dirt.
jkornhiser
Newbie Joined: 17 Aug 2007 Online Status: Offline Posts: 7 |
Quote Reply Posted: 17 Aug 2007 at 1:45pm |
Good stuff!! I haven't "cleaned house" in the past 4 years (age of my current box), I've been extremely wary...........looking for something safe and proven to do the work
-JohnK
MCSE, CCNA, BSIT Systems Administrator |
Robert
Quote Reply Posted: 17 Aug 2007 at 7:56pm |
lol I've cleaned up peoples computers where I've found 1500+ bad entrys. You can feel such a major difference after cleaning them out.
jkornhiser
Quote Reply Posted: 17 Aug 2007 at 8:59pm |
Wow! Between the three programs, I cleaned up over 1GB and I lost count of the # of entries. I also turned off the services that weren't needed and there is definitely a noticeable performance increase.
Thanks guys!
-JohnK
Harry
Groupie Joined: 03 Aug 2007 Online Status: Offline Posts: 190 |
Quote Reply Posted: 18 Aug 2007 at 10:03pm |
You need to buy the full versions of these programs not the free downloads, right?
jkornhiser
Quote Reply Posted: 19 Aug 2007 at 7:41pm |
I just used the free versions Harry, and they all seemed to do their job. If I recall correctly, only one of them indicated a "trial period".
-JohnK
Phreak
Senior Member Joined: 19 Aug 2007 Online Status: Offline Posts: 118 |
Quote Reply Posted: 20 Aug 2007 at 12:00am |
Very nice. Thank you for the heads up about these wonderful programs.
Robert
Quote Reply Posted: 24 Aug 2007 at 7:47pm |
Nope, they are all freeware. One of them asks you to register each time you open it, but the program remains fully functional forever.
Dave
Senior Member Joined: 01 Aug 2007 Online Status: Offline Posts: 172 |
Quote Reply Posted: 25 Aug 2007 at 1:32pm |
Whoa man 5,231 Invalid Entries o.O
X-Fire: OddityX1337
Yahoo: l33tz0rz1337 Rick Rolled Son! |
GruntMaster
Groupie Joined: 07 Aug 2007 Online Status: Offline Posts: 52 |
Quote Reply Posted: 26 Aug 2007 at 8:24pm |
That works great...very simple to use. I found 382 issues with my work laptop...can't wait to check my old home pc.
E6850 [email protected]
nVidia 680i LT 750W Thermaltake 250GB HD 2GB DDR2 Corsair 800Mhz XMS2 GeForce 8800 GTS 320MB |
Harry
Quote Reply Posted: 26 Aug 2007 at 8:45pm |
I reformatted not that long ago and still found a few hundred issues.
I have been using ccleaner for a while and think it's a great little program.
Thanks for the info.
Harry
4261
Newbie Joined: 26 Aug 2007 Online Status: Offline Posts: 99 |
Quote Reply Posted: 01 Sep 2007 at 1:26am |
CCleaner deleated my C drive
Vjzzerdrjx
Quote Reply Posted: 01 Sep 2007 at 10:55am |
The only way it could have deleted your C drive is if it wasn't being used at all, and therefor wasn't your main drive?
denslayer
Newbie Joined: 24 Aug 2007 Online Status: Offline Posts: 17 |
Quote Reply Posted: 02 Sep 2007 at 3:48pm |
Wow, 1000 bad entries, first time I've ever used a reg cleaner Thanx for the advice
EdH63
DS Veteran Joined: 01 Sep 2007 Online Status: Offline Posts: 1826 |
Quote Reply Posted: 03 Sep 2007 at 5:13pm |
I've been using RegVac Registry Cleaner for a number of years (Full Version around $29.00). It also is a very comprehensive and effective cleaner. Totally safe and easy for the novice user. It also has some very in depth functions for the experienced user. I highly recommend it along with the others posted here.
Another great cleaner for your PC is A-1 Ultra PC Cleaner. This is another layer of comprehensive cleaners for your PC aside from the Registry. Both great programs to consider. |
Sonofek
Groupie Joined: 03 Sep 2007 Online Status: Offline Posts: 59 |
Quote Reply Posted: 08 Sep 2007 at 3:23am |
I've been using Clean Up for awhile. Just ran it and cleared around 350MB, then ran Eusing, and ended up with 848 items in need of repair. Running the last now.
Phreak
Quote Reply Posted: 26 Sep 2007 at 4:58pm |
good apps robert, thanks for the links.
Core 2 Quad Q6600 OC @ 2.7Ghz
2GB DDR2 Corsair 800Mhz XMS2 GeForce 8800 GTS 320MB nVidia 680i LT Stage 3 w/ TwisterBoost EXTREME DS case |
Electro
Newbie Digital Storm Apprentice Joined: 08 Oct 2007 Online Status: Offline Posts: 11 |
Quote Reply Posted: 09 Oct 2007 at 8:29pm |
I prefered CCleaner when they called it Crap Cleaner...
EdH63
Quote Reply Posted: 11 Oct 2007 at 5:07pm |
Just an FYI - I ran A1Click Ultra PC Cleaner on my wife's computer yesterday and removed over 100,000 problems, around 3.4gigs, from her PC. I hadn't run it in about 2 years until yesterday. Although she has a piddly little Dell system, it's running much smoother now.
This program is awesome! Been using it on my own rig for a number of years. http://regvac.com/ |
commast
Senior Member Joined: 11 Oct 2007 Online Status: Offline Posts: 262 |
Quote Reply Posted: 11 Oct 2007 at 8:13pm |
People, just be aware that Registry Cleaner can also mess up your window registry. Make sure you backup your registry before run any reg cleaner. Some cleaner can be too agressive in cleaning out your registry. I use CCleaner to clean out my temp files but when it come to the window reg i usually do it myself but i use CCleaner as a double verification tool. |
EdH63
Quote Reply Posted: 12 Oct 2007 at 3:19pm |
This very true, some programs can be way too aggressive. Although, I've never had any issues with RegVac or A1 Click Ultra PC Cleaner. These programs clean as default only the safe entries and issue that should be taken out immediately. It gives you the options to go over other entries and warns you about removing them before you do. Simple instructions... Red light, Yellow light, Green light. Kind of dummy proof. |
Jingping
Groupie Joined: 11 Sep 2007 Online Status: Offline Posts: 193 |
Quote Reply Posted: 17 Oct 2007 at 3:14am |
Are these fully Vista compatible?
EdH63
Quote Reply Posted: 17 Oct 2007 at 9:13am |
I'm using the one's I've posted about on Vista Premium 32 bit... no problems.
Bill the Cat
DS Veteran Forum Bitch! Joined: 27 Aug 2007 Online Status: Offline Posts: 1150 |
Quote Reply Posted: 13 Dec 2007 at 8:01pm |
CCleaner actually does have at least one dangerous option. The "Cleaner" section has check box to delete Windows Explorer Recent Documents; apparently not the list of recent documents, but the documents themselves. You really, really, really do not want to do this.
I did.
After running CCleaner, all my Word and Excel files were gone! Incinerated not recycled. Imagine that for a moment....
Fortunately, I'd done a backup a week ago. "Acronis" comes through again.
3.6 GHz E6850, 4 GB RAM, GTS 250, TJ9, Win 7 64-bit
4.4 GHz i7 3930K, 16 GB RAM, GTX 670, 550D, Win 7 64-bit |
Getout
Groupie Joined: 21 Nov 2007 Online Status: Offline Posts: 128 |
Quote Reply Posted: 01 Jan 2008 at 5:02pm |
sticky this
sundowner
Senior Member Joined: 11 Sep 2007 Online Status: Offline Posts: 501 |
Quote Reply Posted: 01 Jan 2008 at 10:19pm |
Pro case with extra fan
Quad Q6600 2.4 OC'd 3.1! Nvidia 8800GT Asus Maximus Formula Mobo 2xgb 800mhz corsair xfire - xuntiltheendx |
brownhaze
Newbie Joined: 15 Feb 2008 Online Status: Offline Posts: 8 |
Quote Reply Posted: 15 Feb 2008 at 3:31am |
Well I ran the Abexo cleaner and the Eusing cleaner and I don't think they did anything. The Abexo cleaner scanned and found 1038 entries but when I tried to repair them it told me to register. I thought it was free.
I also ran Eusing, scanned, but when I tried to repair the issues it just froze. And now I'm trying to uninstall it but it says it cant open the INSTALL.LOG file. What should I do? |
EdH63
Quote Reply Posted: 15 Feb 2008 at 7:59am |
Buy the full version. Typically when you run a free registry cleaner it will find and isolate all the issues, but it will not remove them. To remove them you usually have to buy the full version. I know this to be the case with RegVac and A1 Click Ultra PC Cleaner. I have them both (Full versions), but when I had just the free versions, I could never actually remove anything. It just finds and isolates. I may be wrong with other brands. Edited by EdH63 - 15 Feb 2008 at 8:02am |
EdH63
Quote Reply Posted: 15 Feb 2008 at 8:01am |
The ones I'm speaking of are... yes. |
propboy
Newbie Joined: 01 Nov 2007 Online Status: Offline Posts: 17 |
Quote Reply Posted: 15 Feb 2008 at 7:46pm |
Any issues running these on a Vista 64 machine?
Thanks
1000K PC Power & Cooling
Intel Quad 6850 Dual 8800 Ultra's 680i mobo 4gb ram 12-1 media card reader 2x150 Raptors 2x500 HDD (raid 0) CoolerMaster Stacker 830 Vista Ultra 64 |
EdH63
Quote Reply Posted: 15 Feb 2008 at 7:54pm |
MajorWyrenutz
Newbie Joined: 02 Dec 2007 Online Status: Offline Posts: 16 |
Quote Reply Posted: 17 Feb 2008 at 7:05pm |
I ran the Eusing free reg. cleaner on my vista 64 system, and now I've got some problems. I has turned my desktop black, and will not allow me to mke any changes. It also has disabled the control panel, which makes it hard to try to do anything about it. It ALSO turned off or deleted my print spooler, and when I go into services to turn it back on it gives me an error that it can't find the files.
Now, the Eusing cleaner did a backup of the registry when it ran, but when I double clicked on those files, they disappeared and didn't do anything at all, and are now apparently gone..
does ANYONE know what I can do here? everything else on the system (games, apps, etc.) seem to still work ok, but I need to use the printer, and the all black desktop + no control panel is also kind of a drag...
oh boy..what did I do?
Solo
Senior Member Joined: 27 Oct 2007 Online Status: Offline Posts: 395 |
Quote Reply Posted: 18 Feb 2008 at 8:46pm |
try a restore point?
pgs8113
Senior Member Joined: 26 Oct 2007 Online Status: Offline Posts: 147 |
Quote Reply Posted: 19 Feb 2008 at 6:35pm |
I ran ccleaner and eusing and they worked great... thx for the links.
QX6850 Extreme 3.33 Ghz (OC)
nvidia 680i Core 2 Quad(A1) 2Gb Corsair Dominator 1066 Mhz 1x150 Gb Raptor (10k) 1x320 Gb WD 8800 Ultra 768 Mb |
Post Reply | Page 12> |
