Jeff's Review (Pics Up!)
Post Date: 2010-01-26
Page  <1 2345>
Born2rade View Drop Down
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 10:11pm
I cannot sleep with computer noise lol. Ill keep it going till midnight which would make the 12 hours. Even the temps have dropped from the usual 70's. Its staying at a steady 66-69 for the past couple of hours as far as i have seen.
Do i have to manually stop the test or will it stop once 12 hours hits?
Once 12 hours has finished, is there anything else that i need to do or am i completely done. Should i save profile to #2?
Edited by Born2rade - 26 Jan 2010 at 10:17pm
justin.kerr View Drop Down
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 10:22pm
yes, save to profile #2, and the basic overclock is done.
You can go for better memory settings, it takes longer, and is a bit tougher to do, and will have smaller gains, but I can help if you want to do it someday. Also you can overclock the GPU, it is easy to, and takes about as long to do as the CPU.
Most people would consider 20 passes of IBT at max mem, plus 12 hours of Prime 95 stable, max would be 50 passes of IBT max mem, and 24 hours of Prime95. Someone from DS might want to jump in to make sure this is up to their standards.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 10:23pm
you have to manually stop the test.
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 10:27pm
Yeah i think ill just leave it as it is. It seems to be working great.
Other than that i just want to say a super duper thank you for all your help.
you have been awsome. Thank you for being very patient with me as i am very newbie when it comes to this overclocking thing. I have learned quite a bit from this expeirence and perhaps i can someday build my own computer for fun and have a crack at some overclocking myself :).
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 11:28pm
no problem, and you are welcome. everyone was a noob once. Ouch
Sodius View Drop Down
  Quote Sodius Quote  Post ReplyReply bullet Posted: 29 Jan 2010 at 7:46pm
Amen, I am still a noobie. :)
Bullseye View Drop Down
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 30 Jan 2010 at 3:26am
lol
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 09 Feb 2010 at 11:12am
I have been running the new overclock, the one justin.kerr helped me with for about two weeks or so now. It has been working great. No crashing, no blue screens, no lock ups, nothing.
I have a question about something. it's about Hyperthreading technology. Should i have HT enabled or disabled?
I have read on forums that quite a people disable it. Are there really any disadvantages or advantages of it? They say it's really not needed.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 09 Feb 2010 at 11:20am
Here is the short answer.
Windows XP  HT off
Windows Vista, HT on will net a small gain over HT off but a few apps will still gain slightly with HT off so it is better on, but only by a very slim margin.
Windows 7, HT on, no question, decent to large gains across the board.
Onkel_Ken View Drop Down
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 10 Feb 2010 at 9:56pm
Nice system!!!!!!!!!!!!!!!!
HAF 932/920 OC 3.60/V8
EVGA Titan SC 6GB VRAM
RAM 6GB 1333Mhz
Western Digital 500GB/1TB BU
EVGA X58/Fatality X-Fi Champion
Catatonic View Drop Down
  Quote Catatonic Quote  Post ReplyReply bullet Posted: 11 Feb 2010 at 12:37pm
I agree. Looking good and running better!
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 12 Feb 2010 at 1:42pm
I was messing with the Core Voltage a little bit today. just lowering like it like two clicks or so just to see if it can handle a lower vcore.
I Bumped my QPI to 201 @ 4.2Ghz and tried lowering my vcore a tad (normally you would make it higher). About 4 mins into the intel burn test my screen went black.
I'm back with my original 4.16 OC and i lowered the Vcore to see what happens now. Deff getting lower Load temps atm.
Edited by Born2rade - 12 Feb 2010 at 1:45pm
tanamerra View Drop Down
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 12 Feb 2010 at 2:03pm
Where do you find the setting for HT? Want to see if mine is enabled.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 12 Feb 2010 at 2:27pm
use Cpuz, see at the lower right corner cores? should say four, then it says threads, should say 8 if HT is on  or 4 if HT is off
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 11:11am
Hey justin. How would i go about lowering my vcore and still trying to maintain stablity. Thats if mine can handle having a lower Vcore.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 12:06pm
you have a pretty low V core, I would not try to lower it.
here is my best 920 D0, so there are not many much better than this one. I don't have a 4.2 Ghz run, but here is the closest one I have to it.
Edited by justin.kerr - 13 Feb 2010 at 1:22pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 12:11pm
I know every chip is different. ive seen alot of people get with the same DO stepping chip get a very low vcore. They say almost all DO Stepping get 1.24 to like 1.26 vcore. Can other chips really be that much of a difference?
But i think everyone that has that low vcore, i just don't think they are stable at 100% load, like what mine is, it just doesnt make much sense lol. I mean sure mine booted up at that low vcore but as far as putting any load on it, the screen goes black.
I'm happy where mine is at, i just wanted to understand this low vcore thing a bit better.
Edited by Born2rade - 13 Feb 2010 at 12:21pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 12:43pm
The V core is in direct relation with speed, so keep that in mind, not really anyone is running 4.2Ghz @1.24 Volts with a 920 D0 with HT. 1.35V-1.45V is the norm for your speed.
To low of V core will cause instability, but also it will result in lower performance, when you push a chip just to the brink of crashing/not crashing it will produce poorer performance than one with a couple more notches of V core, also too much will cause the same issues, and all the other voltages are the same, they must be in concert, to make one big happy orgy of performance. That is why I had you adjust all the other voltages as I did. Ouch
Edited by justin.kerr - 13 Feb 2010 at 12:44pm
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 1:19pm
i would like to try and overclock my CPU and try to improve performance but afraid i would screw something up.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 1:20pm
well start a new thread in the overclocking/performance area, and we can begin. lol
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 1:42pm
Ah ok thanks justin :).
Don't worry. i was a little nervous myself. Justin will help you out.
GL
Born2rade View%20Drop%20Down
Post%20Options Post Options   Quote Born2rade Quote  Post%20ReplyReply bullet Posted: 26 Jan 2010 at 7:27pm
Back%20to%20Top
justin.kerr View%20Drop%20Down
DS%20ELITE
Post%20Options Post Options   Quote justin.kerr Quote  Post%20ReplyReply bullet Posted: 26 Jan 2010 at 8:28pm
The Drunken Monkey i7920 @4.7Ghz, HT on
(2) toxic 4890's @1025Mhz
Mushkin Redline ascents 6gb, 1784Mhz 7-7-6-19
(8)Intel X25m RAID 0 on LSI 9260
heat killer CPU block, EK mobo block, 4 triple rads
Back%20to%20Top
Sodius View%20Drop%20Down
DS%20Veteran
Post%20Options Post Options   Quote Sodius Quote  Post%20ReplyReply bullet Posted: 29 Jan 2010 at 4:46pm
Back%20to%20Top
Bullseye View%20Drop%20Down
Senior%20Member
Post%20Options Post Options   Quote Bullseye Quote  Post%20ReplyReply bullet Posted: 30 Jan 2010 at 12:26am
lol
I need advice on a desktop!!!!!!!
Back%20to%20Top
Post%20Options Post Options   Quote Born2rade Quote  Post%20ReplyReply bullet Posted: 09 Feb 2010 at 8:12am
Back%20to%20Top
DS%20ELITE
Post%20Options Post Options   Quote justin.kerr Quote  Post%20ReplyReply bullet Posted: 09 Feb 2010 at 8:20am
Windows XP  HT off
Back%20to%20Top
Onkel_Ken View%20Drop%20Down
DS%20Veteran
Post%20Options Post Options   Quote Onkel_Ken Quote  Post%20ReplyReply bullet Posted: 10 Feb 2010 at 6:56pm
Ticket 238402
HAF 932/920 OC 3.59/V8/6GB 1333Mhz
HP w2408h Vivid Color Widescreen
Back%20to%20Top
Catatonic View%20Drop%20Down
Post%20Options Post Options   Quote Catatonic Quote  Post%20ReplyReply bullet Posted: 11 Feb 2010 at 9:37am
Back%20to%20Top
Post%20Options Post Options   Quote Born2rade Quote  Post%20ReplyReply bullet Posted: Yesterday at 10:42am
Edited by Born2rade - Yesterday at 10:45am
Back%20to%20Top
tanamerra View%20Drop%20Down
Post%20Options Post Options   Quote tanamerra Quote  Post%20ReplyReply bullet Posted: Yesterday at 11:03am
Hailstorm Black OPS Edition Case
Extreme 3.33GHz CPU Overclocked
EVGA X58 3X Classified Motherboard
ATI Sapphire 5870's crossfire
Sub Zero Stage 6 LCS
6GB Ram
Win 7 Ultimate
1000W Corsair PS
Back%20to%20Top
DS%20ELITE
Post%20Options Post Options   Quote justin.kerr Quote  Post%20ReplyReply bullet Posted: Yesterday at 11:27am
Back%20to%20Top
Post%20Options Post Options   Quote Born2rade Quote  Post%20ReplyReply bullet Posted: Today at 8:11am
Back%20to%20Top
DS%20ELITE
Post%20Options Post Options   Quote justin.kerr Quote  Post%20ReplyReply bullet Posted: Today at 9:06am
Edited by justin.kerr - Today at 10:22am
Back%20to%20Top
Post%20Options Post Options   Quote Born2rade Quote  Post%20ReplyReply bullet Posted: Today at 9:11am
Edited by Born2rade - Today at 9:21am
Back%20to%20Top
DS%20ELITE
Post%20Options Post Options   Quote justin.kerr Quote  Post%20ReplyReply bullet Posted: Today at 9:43am
Edited by justin.kerr - Today at 9:44am
Back%20to%20Top
tanamerra
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 13 Feb 2010 at 8:53pm
Thanks Justin.kerr. That would be much appreciated.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 11:20am
then start the darn thread.., Smile
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:14pm
i know this may be a dumb question but i opened CpuZ on desktop but how do i save and post the 3 graphs here so you can see mt settings?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:20pm
press the windows button, in the search bar type snip, it will bring up the snipping tool, great invention. it will allow you to crop a portion of your desktop, or webpage, very handy tool, and start your own thread, stop de railing this one. Smile
  Quote tanamerra Quote  Post ReplyReply bullet Posted: 15 Feb 2010 at 1:31pm
OK and thanks. Starting new thread.
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 19 Feb 2010 at 7:41pm
Edited by Born2rade - 19 Feb 2010 at 7:42pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Feb 2010 at 12:26am
whatcha up to? did i create a monster? SmileShocked
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Feb 2010 at 3:02am
See now DS is slowly but surely not gonna like you, leading these eager young lads down this wicked path
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 20 Feb 2010 at 9:27am
Lawl, I never ran a Linx Test before so i wanted to try it.
Just Posting Pics as references.
Edited by Born2rade - 20 Feb 2010 at 9:39am
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Feb 2010 at 11:13am
Linx is just a different interface for Intel Burn Test, both use the Intel algorithms,  Linx is usually easier to use is all.
Vbulljon View Drop Down
  Quote Vbulljon Quote  Post ReplyReply bullet Posted: 24 Feb 2010 at 10:11am
Ermmnice rig!!!!!! been reading all the post on OCing, very nicely done guys!Ermm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 19 Jun 2010 at 3:44pm
Hey Guys, Just reporting an update.
It's been about 5 months that i have had my computer. The PC runs great. I have only had one crash. The only thing that has changed are my temps. My Idle during winter would sit at 37-40C, now that it is Summer My Idle sits 44-49C.
Just wanted to know if this much of a gain was normal, I do live in florida. The house stays below 80 Degrees But my room seems to be the hottest which sits at 80+ degrees.
If i run intel burn test @ Max my temp gets to 90c
Edited by Born2rade - 19 Jun 2010 at 3:48pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 19 Jun 2010 at 4:49pm
We'll it's no longer the winter then, so your ambient temperature is going to go up.
However, those are still good temps for such a high overclcok 4.0GHz+ on a single 120mm radiator.
Also, what really matters is your CPU temps during gaming and other computer tasks that you do. Intel CPU Burn or any other stress-testing application will put your CPU under load levels that are not normal usage conditions.
Edited by Alex - 19 Jun 2010 at 4:53pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 21 Jun 2010 at 6:08pm
Actually mine is a 240mm Radiator.
In Games it gets to around 70Cish.
Edited by Born2rade - 21 Jun 2010 at 6:08pm
 Post Reply Post Reply Page  <1 2345>
This page was generated in 0.203125 seconds.
