Jeff's Review (Pics Up!)
Post Date: 2010-01-25
Page  <12345>
Born2rade View Drop Down
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:19pm
Yeah i'm 99% Sure DS wont Warranty after 4.2Ghz.
One question. What is your opionon on Speed Step?
I like the idea of it b/c i like to sometimes leave my comper idle.
justin.kerr View Drop Down
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:25pm
speedstep on overlclocked rigs, no
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:40pm
Ok I Will just go up to 4.1xxx Ghz and stop there. I will let you know when i'm done with that test (When i get there) so you can tell me what to do next :).
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:43pm
199 B clock then lol
hope it makes it there with the base voltages. would be nice, same with your cooling system keeping up with the chip!
plus your RAM will be running full speed then to. Tongue
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:48pm
It's holding up well so far man. Testing 4.011 Ghz. Still the same temps.
Fluxing 71-72, Max: 73.
also a sidenote. My room is 80F
Edited by Born2rade - 25 Jan 2010 at 6:52pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:52pm
I know this is a really dumb question, but over the forums it is so hard to help overclock compared to being there in person, but when you bump up the QPI in E-leet you are hitting apply before you run Intel Burn test correct? lol
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:58pm
Yepp, I hit "Apply Selection"
Plus i make sure it says what the ghz is before i run the test on CPUID and the REALTEMP
Also Making sure its 8 Threads and Maxium Test Selection.
Edited by Born2rade - 25 Jan 2010 at 7:03pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 7:11pm
It's starting to now just go to 74c as a max @ 4.043 (RealTemp)
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 7:15pm
only 3 more tests to go!
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 7:52pm
195 QPI Tested: Passed
Max Temp 76C
Testing 197 QPI (4.126Ghz)
Edited by Born2rade - 25 Jan 2010 at 7:54pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:05pm
getting very close to completing the first part of overclocking. then off to step 2.. lol  maybe the GPU later also? Smile
Edited by justin.kerr - 25 Jan 2010 at 8:06pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:14pm
Ok It finished that test.
Can i test it at 200 QPI instead of 199?
200 (4.2Ghz) is the most i can go as far as warranty is concerned.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:15pm
use odd B clock numbers, evens tend to have stability problems.
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:17pm
Ok ill just stick to 199 :).
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:17pm
ok, now you need to re-boot, then go into the bios, and raise the  overclock to 199 and F-10 get back into windows and run the Intel Burn test like before, but 20 passes, if all goes well, then a minimum of 12 hours of Prime95
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:21pm
Ok, i will change it to that in the bios after this last test.
ill do those tests 2morro if that is all fine lol.
What Prime Settings Do i Use?
Edited by Born2rade - 25 Jan 2010 at 8:22pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:23pm
yep, if you pass the tests then you can call it done... there is a bunch more stuff we can do, but nothing that will make a noticable gain.
run Prime 95 Blend test
Edited by justin.kerr - 25 Jan 2010 at 8:23pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:30pm
Ok.
When u said change the F to -5, did u mean cpu uncore freq?
Intel Burn Test 20 Times (max settings) (8 threads)
and
Prime 95, Blend Test (12 Hours)
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:32pm
sorry I meant hit the function 10 key, to save your settings in the BIOS. lol
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:34pm
Ok so only change the 199?
Edited by Born2rade - 25 Jan 2010 at 8:39pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:42pm
yes, that is the only new change in the BIOS for now
Edited by justin.kerr - 25 Jan 2010 at 8:44pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:44pm
Ok I'm Booted to the desktop. Super Super Ty.
You have been awsome Ermm
I will let you know how the tests go later 2morro.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 8:45pm
ok, hope it passes the tests, would make for a very easy overclocking process Thumbs%20Up
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 10:30am
Just Starting the Intel Burn Test, 20 Times. My Room is like 74F Today.
My Room Was 80F Yesterday. Temps Will Be Lower.
Do i have to change any of the settings on the Blend Test on  Prime95.to make it run 12 hours?
or
Do i just click it just as it is and run it?
Edited by Born2rade - 26 Jan 2010 at 10:47am
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 11:37am
just click on the blend test, no need to adjust a thing.   good luck!
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 12:07pm
Ok, It passed the Intel Burn test, 20 times.
I guess ill just go ahead and do the blend test now. It will end at midnight. I can stay up that late.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 12:09pm
congratz!  what was the max temp?
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 12:10pm
72-73C for the 20 times intel burn test
last night my max was 77c b/c my room was 80F.
Running Prime95 Now. Temps are lower on Prime compared to Intel Burn Test.
Edited by Born2rade - 26 Jan 2010 at 1:01pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 1:13pm
I was reading this one post about his sound card being in the wrong slot. Mine looks like it is in the same spot as his was. I have a picture of it on the 1st page on the bottom. Can you check it out real quick?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 1:15pm
you have a different setup, so yours is fine
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 1:46pm
I find intelburn stresses the cpu the most. congrats, and way to go JK, I don't know where you get the patience, tho this one went pretty quick
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 1:51pm
thanks DST, lol yeah I imagine it will be a lot longer helping you get more out of your new rig.. Confused
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 2:01pm
lol well first I got to get the rig
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 3:37pm
Yeah Justin was very patient with me :).
Prime 95 (Started 12pm EST Noon)
3 1/2 hours (All Passed)
6 hours. (All Passed)
9 hours. (All Passed)
12 hours. (TBA)
Edited by Born2rade - 26 Jan 2010 at 9:14pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Jan 2010 at 9:45pm
only a couple of hours left, maybe run it till morning? lol
 Post Reply Post Reply Page  <12345>
This page was generated in 0.515625 seconds.
