Born2rade
Posted: 24 Jan 2010 at 2:43pm |
Here are my Bios Settings
Frequency Control CPU Clock Ratio ( 20X ) CPU Host Frequency(Mhz) ( 181 ) MCH Strap ( Auto ) CPU Uncore Frequency (Mhz) ( Auto ) CPU Clock Skew ( 0 ps ) Spread Spectrum ( Disabled ) PCIE Frequency (Mhz) ( 100 )
Memory Feature Memory Speed ( Standard ) Memory Control Setting ( Enabled ) Memory Frequency ( Auto -> 1067Mhz ) Channel Interleave Setting ( 6 Way ) Rank Interleave Setting ( 4 Way ) Memory Low Gap ( Auto ) tCL Setting ( 9 ) tRCD Setting ( 9 ) tRP Setting ( 9 ) tRAS Setting ( 24 ) tRFC Setting ( 74 ) Command Rate ( 1t )
Voltage Control EVGA VDroop Control ( With VDroop ) CPU VCore ( 1.35000mV ) CPU VTT Voltage ( +150mV ) CPU PLL VCore ( Auto ) IOH PLL VCore ( Auto ) DIMM Voltage ( 1.600 ) DIMM DQ Vref ( +0mV ) QPI PLL VCore ( Auto ) IOH VCore ( Auto ) IOH/ICH I/O Voltage ( Auto ) ICH VCore ( Auto ) PWM Frequency ( 800 Khz )
CPU Feature Intel SpeedStep ( Disabled ) Turbo Mode Function ( Enabled ) CxE Function ( Disabled ) Execute Disable Bit ( Disabled ) Virtualization Technology ( Enabled ) Intel HT Technology ( Enabled ) Active Processor Cores ( All ) QPI Control Settings ( Enabled ) QPI Link Fast Mode ( Enabled ) QPI Frequency Selection ( Auto ) OC Recorvery ( Enabled )
PnP/PCI PCI Express Maximum Payload Size ( 128 )
Question about the Mem Frequency. Shouldnt it be 1600mhz and not 1067mhz. My Ram is the 1600mhz mushkin silverline series or at least thats what it should be.
Edited by Born2rade - 24 Jan 2010 at 3:23pm
justin.kerr
Posted: 24 Jan 2010 at 6:25pm |
wholt crap. lol lots of stuff to change, but I will not be able to get you some good stuff till tomorrow afternoon, right now, playoffs, and I have a ton of people at the house, and I leave at 5:00 A:M to look at a job tomorrow. lol the memory, is BS EVGA is misleading, the Mhz is based on stock B clock, so pay no attention to it.
Born2rade
Posted: 24 Jan 2010 at 6:59pm |
Alright sounds good, Thx.
Lots of stuff to change lol?
*Edit*
What do you think about Speed Step?
Should this be enabled?
Mine is disabled.
I like to run the computer idle half the time.
Edited by Born2rade - 25 Jan 2010 at 12:59pm
justin.kerr
Posted: 25 Jan 2010 at 3:08pm |
Realtemp, and EVGA E-leet
once you have all the above programs installed, go into the BIOS and do the changes that I have made to your settings.
then F10 in the BIOS, and run 5 passes of Intel burn test at maximum level. if it passes and your temps are good, then in E-Leet raise the QPI to 183, then retest with IBT, 5 passes, if all good keep going up, 185, 187, 189, 191, 193, 195, 197, 199, 201. once you hit the thermal max of 85 stop, or if you have a bluee screen make sure you notice the error, if 101 add two clicks of CPU V core, if error 124 add one click to VTT
once you either hit 201 B clock, or hit 85C temps, then we can work on finalizing the overclock.
Frequency Control CPU Clock Ratio ( 20X ) CPU Host Frequency(Mhz) ( 181 ) MCH Strap ( Auto ) CPU Uncore Frequency (Mhz) ( Auto ) change to 16x CPU Clock Skew ( 0 ps ) Spread Spectrum ( Disabled ) PCIE Frequency (Mhz) ( 100 ) change to 105
Memory Feature Memory Speed ( Standard ) Memory Control Setting ( Enabled ) Memory Frequency ( Auto -> 1067Mhz ) not auto, make sure 1067 2:8 Channel Interleave Setting ( 6 Way ) Rank Interleave Setting ( 4 Way ) Memory Low Gap ( Auto ) tCL Setting ( 9 ) tRCD Setting ( 9 ) tRP Setting ( 9 ) tRAS Setting ( 24 ) tRFC Setting ( 74 ) Command Rate ( 1t )
Voltage Control EVGA VDroop Control ( With VDroop ) change to without V droop CPU VCore ( 1.35000mV ) up to 1.3875 CPU VTT Voltage ( +150mV ) CPU PLL VCore ( Auto ) change to 1.8 IOH PLL VCore ( Auto ) change to 1.8 DIMM Voltage ( 1.600 ) change to 1.65 DIMM DQ Vref ( +0mV ) QPI PLL VCore ( Auto ) change to 1.275 IOH VCore ( Auto ) change to 1.275 IOH/ICH I/O Voltage ( Auto ) change to 1.55 ICH VCore ( Auto ) change to 1.125 PWM Frequency ( 800 Khz )
CPU impedance change to less
QPI signal compensation to less CPU Feature Intel SpeedStep ( Disabled ) Turbo Mode Function ( Enabled ) CxE Function ( Disabled ) Execute Disable Bit ( Disabled ) Virtualization Technology ( Enabled ) Intel HT Technology ( Enabled ) Active Processor Cores ( All ) QPI Control Settings ( Enabled ) QPI Link Fast Mode ( Enabled ) QPI Frequency Selection ( Auto ) change to 4.8GT/s OC Recorvery ( Enabled )
Born2rade
Posted: 25 Jan 2010 at 3:36pm |
Ok I made the changes. It restarted and all i see is a black screen. atm.
Nothing is appearing on my screen atm...........It turned on fine.
Edited by Born2rade - 25 Jan 2010 at 3:39pm
justin.kerr
Posted: 25 Jan 2010 at 3:42pm |
some of the newer chips don't like the QPI signal compensation to less, set set it back to auto, and the cpu impedence to auto
Born2rade
Posted: 25 Jan 2010 at 3:44pm |
How do you do that when my screen is black heh.
justin.kerr
Posted: 25 Jan 2010 at 3:46pm |
lol, turn off the PC, hold to power button, if it is black on the re-boot you will have to clear the BIOS, and load your profile.
Born2rade
Posted: 25 Jan 2010 at 3:47pm |
Yeah i turned it off and turned it back on, still black.
How do you clear the bios?
Edited by Born2rade - 25 Jan 2010 at 3:48pm
justin.kerr
Posted: 25 Jan 2010 at 3:48pm |
there is a button the the back, says clear CMOS.
Born2rade
Posted: 25 Jan 2010 at 3:50pm |
OK i cleared it lol.
justin.kerr
Posted: 25 Jan 2010 at 3:51pm |
load profile, should be number 1. makes sure it boots up, then redo the settings, just don't mess with the two I mentioned above
Born2rade
Posted: 25 Jan 2010 at 3:52pm |
Where do i load profile?
NM, Found it.
Edited by Born2rade - 25 Jan 2010 at 3:56pm
Born2rade
Posted: 25 Jan 2010 at 3:59pm |
I loaded my profile but now it wants
Verifying DMI Pool Data..................
Boot From CD:
i wonder which cd this is refering to.
ohhhh me retarded. theboot was set to CD :)). I'm all good.
Edited by Born2rade - 25 Jan 2010 at 4:11pm
justin.kerr
Posted: 25 Jan 2010 at 4:10pm |
if you don't press anything nothing happens? your boot order must be messed up, you can change that in the BIOS you might have to hit load defaults, then load your profile
Born2rade
Posted: 25 Jan 2010 at 4:13pm |
yeah i'm good with that. I'm going to make those chagnes again with the two things u said to put to auto.
Born2rade
Posted: 25 Jan 2010 at 4:22pm |
Ok i made the changes u said to make. I'm now on the desktop.
Doing Intel Burn Test
Edited by Born2rade - 25 Jan 2010 at 4:23pm
justin.kerr
Posted: 25 Jan 2010 at 4:23pm |
you have E-leet, IBT, and realtemp?
Born2rade
Posted: 25 Jan 2010 at 4:24pm |
It Says i cannot do maxium stress test b/c i dont have that much memory..
Yes i have all the programs.
Avail Ram is 4983, it switches from that to 5010, Very close.
Should i select a diff one?
Edited by Born2rade - 25 Jan 2010 at 4:28pm
justin.kerr
Posted: 25 Jan 2010 at 4:28pm |
sometime you have to hit maximum again. lol just run it 5 passes to make sure you are still good
Born2rade
Posted: 25 Jan 2010 at 4:29pm |
It's not letting me do that max stress test. I have 6GB of Ram, Avail Ram is
4999's to 5010. I clicked it like 10 times. Won't start.
Edited by Born2rade - 25 Jan 2010 at 4:31pm
Born2rade
Posted: 25 Jan 2010 at 4:32pm |
Wow NM it finally started... after 20 clicks.
justin.kerr
Posted: 25 Jan 2010 at 4:37pm |
forgot, you have to select 8 threads to. lol if it clears this time, then just make sure you click on 8 threads next time
Born2rade
Posted: 25 Jan 2010 at 4:46pm |
Should it say passed on the Results?
B/c right now it is not saying Passed.
It says 3.507702e-002
justin.kerr
Posted: 25 Jan 2010 at 4:47pm |
should say someything like that 5 times lol
Born2rade
Posted: 25 Jan 2010 at 4:48pm |
Dont mind me lol. Never done any of this before so i'm just making sure :).
justin.kerr
it will say success when its done
Born2rade
Posted: 25 Jan 2010 at 4:55pm |
I just want to double check with you. max temp from real temp when i get into raising the QPI more is 85C, correct?
justin.kerr
Posted: 25 Jan 2010 at 4:59pm |
yes
Born2rade
Posted: 25 Jan 2010 at 5:23pm |
Doin well atm. 185 QPI, max temp is 73.
But That Max Temp Was From Last Test lol.
Edited by Born2rade - 25 Jan 2010 at 5:28pm
justin.kerr
Posted: 25 Jan 2010 at 5:28pm |
nice
make sure you have 8 threads selected on the Intel burn test.
Edited by justin.kerr - 25 Jan 2010 at 5:32pm
Born2rade
Posted: 25 Jan 2010 at 6:04pm |
Yeah, I been making sure.
almost done with the 187 QPI Test. Same Temps.
71-72c's With max of 73c
Edited by Born2rade - 25 Jan 2010 at 6:05pm
justin.kerr
Posted: 25 Jan 2010 at 6:07pm |
you are almost in the 4Ghz land
Born2rade
Posted: 25 Jan 2010 at 6:14pm |
Yeah man!. The highest i wanted was around 4.0xxx anyways. I cannot go any higher than 4.2.
justin.kerr
Posted: 25 Jan 2010 at 6:17pm |
if you are not heat limited you can go to at least 4.4Ghz. unless DS won't waranty over 4.2?
