Jeff's Review (Pics Up!)
Post Date: 2010-01-24
Page  <1234 5>
Born2rade View Drop Down
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 24 Jan 2010 at 2:43pm
Here are my Bios Settings
Frequency Control
CPU Clock Ratio ( 20X )
CPU Host Frequency(Mhz) ( 181 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( Auto -> 1067Mhz )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( 74 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( 1.35000mV )
CPU VTT Voltage ( +150mV )
CPU PLL VCore ( Auto )
IOH PLL VCore ( Auto )
DIMM Voltage ( 1.600 )
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( Auto )
IOH VCore ( Auto )
IOH/ICH I/O Voltage ( Auto )
ICH VCore ( Auto )
PWM Frequency ( 800 Khz )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Enabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( Auto )
OC Recorvery ( Enabled )
PnP/PCI     PCI Express
Maximum Payload Size ( 128 )
Question about the Mem Frequency. Shouldnt it be 1600mhz and not 1067mhz.
My Ram is the 1600mhz mushkin silverline series or at least thats what it should be.
Edited by Born2rade - 24 Jan 2010 at 3:23pm
justin.kerr View Drop Down
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 24 Jan 2010 at 6:25pm
wholt crap. lol lots of stuff to change, but I will not be able to get you some good stuff till tomorrow afternoon, right now, playoffs, and I have a ton of people at the house, and I leave at 5:00 A:M to look at a job tomorrow. lol   the memory, is BS EVGA is misleading, the Mhz is based on stock B clock, so pay no attention to it. Shocked
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 24 Jan 2010 at 6:59pm
Alright sounds good, Thx.
Lots of stuff to change lol?
*Edit*
What do you think about Speed Step?
Should this be enabled?
Mine is disabled.
I like to run the computer idle half the time.
Edited by Born2rade - 25 Jan 2010 at 12:59pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:08pm
Realtemp, and EVGA E-leet
once you have all the above programs installed, go into the BIOS and do the changes that I have made to your settings.
then F10 in the BIOS, and run 5 passes of Intel burn test at maximum level. if it passes and your temps are good, then in E-Leet raise the QPI to 183, then retest with IBT, 5 passes, if all good keep going up, 185, 187, 189, 191, 193, 195, 197, 199, 201. once you hit the thermal max of 85 stop, or if you have a bluee screen make sure you notice the error, if 101 add two clicks of CPU V core, if error 124 add one click to VTT
once you either hit 201 B clock, or hit 85C temps, then we can work on finalizing the overclock.
Frequency Control
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )    change to 16x
PCIE Frequency (Mhz) ( 100 )  change to 105
Memory Feature
Memory Frequency ( Auto -> 1067Mhz )    not auto, make sure 1067 2:8
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( 74 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( With VDroop )  change to without V droop
CPU VCore ( 1.35000mV )   up to 1.3875
CPU PLL VCore ( Auto )  change to 1.8
IOH PLL VCore ( Auto )   change to 1.8
DIMM Voltage ( 1.600 )  change to 1.65
QPI PLL VCore ( Auto )  change to 1.275
IOH VCore ( Auto )  change to 1.275
IOH/ICH I/O Voltage ( Auto )  change to 1.55
ICH VCore ( Auto ) change to 1.125
CPU impedance change to less
QPI signal compensation to less
CPU Feature
QPI Frequency Selection ( Auto ) change to 4.8GT/s
PnP/PCI     PCI Express
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:36pm
Ok I made the changes. It restarted and all i see is a black screen. atm.
Nothing is appearing on my screen atm...........It turned on fine.
Edited by Born2rade - 25 Jan 2010 at 3:39pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:42pm
some of the newer chips don't like the QPI signal compensation to less, set set it back to auto, and the cpu impedence to auto
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:44pm
How do you do that when my screen is black heh.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:46pm
lol, turn off the PC, hold to power button, if it is black on the re-boot you will have to clear the BIOS, and load your profile.
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:47pm
Yeah i turned it off and turned it back on, still black.
How do you clear the bios?
Edited by Born2rade - 25 Jan 2010 at 3:48pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:48pm
there is a button the the back, says clear CMOS.
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:50pm
OK i cleared it lol.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:51pm
load profile, should be number 1. makes sure it boots up, then redo the settings, just don't mess with the two I mentioned above
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:52pm
Where do i load profile?
NM, Found it.
Edited by Born2rade - 25 Jan 2010 at 3:56pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 3:59pm
I loaded my profile but now it wants
Verifying DMI Pool Data..................
Boot From CD:
i wonder which cd this is refering to.
ohhhh me retarded. theboot was set to CD :)). I'm all good.
Edited by Born2rade - 25 Jan 2010 at 4:11pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:10pm
if you don't press anything nothing happens? your boot order must be messed up,    you can change that in the BIOS  you might have to hit load defaults, then load your profile
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:13pm
yeah i'm good with that. I'm going to make those chagnes again with the two things u said to put to auto.
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:22pm
Ok i made the changes u said to make. I'm now on the desktop.
Doing Intel Burn Test
Edited by Born2rade - 25 Jan 2010 at 4:23pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:23pm
you have E-leet, IBT, and realtemp?
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:24pm
It Says i cannot do maxium stress test b/c i dont have that much memory..
Yes i have all the programs.
Avail Ram is 4983, it switches from that to 5010, Very close.
Should i select a diff one?
Edited by Born2rade - 25 Jan 2010 at 4:28pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:28pm
sometime you have to hit maximum again. lol  just run it 5 passes to make sure you are still good
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:29pm
It's not letting me do that max stress test. I have 6GB of Ram, Avail Ram is
4999's to 5010. I clicked it like 10 times. Won't start.
Edited by Born2rade - 25 Jan 2010 at 4:31pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:32pm
Wow NM it finally started... after 20 clicks.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:37pm
forgot, you have to select 8 threads to. lol if it clears this time, then just make sure you click on 8 threads next time
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:46pm
Should it say passed on the Results?
B/c right now it is not saying Passed.
It says 3.507702e-002
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:47pm
should say someything like that 5 times lol
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:48pm
Dont mind me lol. Never done any of this before so i'm just making sure :).
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:48pm
it will say success when its done
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:55pm
I just want to double check with you. max temp from real temp when i get into raising the QPI more is 85C, correct?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 4:59pm
yes
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 5:23pm
Doin well atm. 185 QPI, max temp is 73.
But That Max Temp Was From Last Test lol.
Edited by Born2rade - 25 Jan 2010 at 5:28pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 5:28pm
nice
make sure you have 8 threads selected on the Intel burn test.
Edited by justin.kerr - 25 Jan 2010 at 5:32pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:04pm
Yeah, I been making sure.
almost done with the 187 QPI Test. Same Temps.
71-72c's With max of 73c
Edited by Born2rade - 25 Jan 2010 at 6:05pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:07pm
 you are almost in the 4Ghz land Angry
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:14pm
Yeah man!. The highest i wanted was around 4.0xxx anyways. I cannot go any higher than 4.2.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 25 Jan 2010 at 6:17pm
if you are not heat limited you can go to at least 4.4Ghz. unless DS won't waranty over 4.2?
 Post Reply Post Reply Page  <1234 5>
This page was generated in 0.171875 seconds.
