KaWaL
Topic: Ivy Bridge is out! Should i bite? :D Posted: 29 Apr 2012 at 4:23pm |
 Now that the Ivy bridge(s) made it to DigiStorm and that my old "gaming" desktop is dead (or dying), i think it's time i try buying a custom build from DS. Before that, i would like to know what you guys think of this config. Any tips? Anything that might be unnecessary OR necessary? Am i overdoing the memory and PSU? Is this a good z77 mobo? Is it really possible to overclock this CPU to stage 2 with just the cooling that i chose? I'm mostly a gamer but it wouldn't hurt to have awesome performance in multitasking and other stuff (photo and video editing, etc.) Config: 681824You will notice i don't have a graphics card on this config because i plan on adding an EVGA 680 SC+ Signature w/ backplate when it becomes available. It should be, anytime soon. I got a notification email 2 days ago from EVGA website saying it's available but i checked and it's not... weird. I like awesome graphics but i don't plan on doing any multidisplay setups.
KaWaL
Posted: 29 Apr 2012 at 4:24pm |
Oh here's a copy of the Specs if loading the config is too much of a burden.  Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D
Power Supply: 1200W Digital Storm Certified (Dual/Triple/Quad SLI
Compatible) (Silent Edition Highly Recommended)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair)
(Model: Force GT Series CSSD-F120GBGT-BK) (SATA 6Gbps)
Video Card: - No Thanks, I will be installing my own video card(s)
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow
& Fan Speeds with Noise Dampening Material)
Boost Memory: Memory Fan Kit Only (Does not include memory overclocking service)
Office: Microsoft Office 2010 Home and Student (PC Attach Key PKC)
Edited by KaWaL - 29 Apr 2012 at 4:38pm
Zieno
Posted: 29 Apr 2012 at 4:25pm |
Ivy bridge runs hotter than sandy, just putting it out there, its performence also isnt that great compared to sandy as far as i have seen
KaWaL
Posted: 29 Apr 2012 at 5:35pm |
explains why it only costs $20 extra compared to the 2700k.
Is the ASUS SABERTOOTH Z77 considered a "Pro or Deluxe Series motherboard"? Just need to know since stage 2 overclock seems to require mobos with said designation/s. From my other choices in this config, only one ASUS board has "DELUXE" on it. i.e. ASUS P8Z77-V DELUXE
Edited by KaWaL - 29 Apr 2012 at 5:38pm
Posted: 30 Apr 2012 at 3:46am |
Hi KaWal....Welcome to the forums. I would suggest the HafX case ( Dreadnought ) instead of your pick. The HafX is the best air cooled case and doesn't need all those noisy Zalman fans you picked or the sound suppression package, which is reaaly a waste of money. HafX large 230mm and 200mm fans turn slow, move lots of air and are quiet. Slow fans equal less noise. You're right to change mobo to the P8Z77-V Deluxe. It oc 's to stage 2 for sure and the Deluxe has built in WiFi, allowing you to drop the added wifi card that takes up pci4e lanes in case you ever sli'd. Drop the memory fan kit...Just wasted money. 8GB ram is all games can use, unless your editing requires it. Either way, drop speed to 1600 Mhz, the difference you'll never see in gaming. The psu all depends on how many graphic cards you'll be using. For a single go 750HX, sli go 1050HX and tri-sli whicjh your mobo can't do effectively anyways would be 1200W. Hope this helps and Good Luck
Edited by bprat22 - 30 Apr 2012 at 3:46am
Posted: 30 Apr 2012 at 10:41am |
We just updated the configurator to reflect that the Stage 2 overclocking works on the Sabertooth product line.
Asangard
Digital Storm Live Chat Rep.
Posted: 30 Apr 2012 at 10:50am |
Hi KaWal bp is correct that the P8Z77-V Deluxe has built in WiFi so you wouldn't need the extra WiFi card. But just to answer a couple of questions about the Sabertooth Z77 board. It can been overclocked to stage 2 and does support dual SLI. All ASUS sabertooth boards are made with what ASUS calls "Tuff Components" and to Military stardards. These components again according to ASUS are independently certified. That is why ASUS has a 5 yr warrenty on their Sabertooth line of motherboards.
Edited by Asangard - 30 Apr 2012 at 2:37pm
darbebo
Posted: 30 Apr 2012 at 2:29pm |
I did not know delux comes with wifi!!!
KaWaL
Posted: 30 Apr 2012 at 7:29pm |
Thanks bpratt, thanks Alex, and thanks Asangard! Yea, 8 gig memory sounds about right, i havent seen any game (that i play at least) that uses up 8 GB memory. Okay, the memory fan kit i guess is unnecessary. I had the exact same HyperX fan in my old rig and it coincidentally "broke" and started making noises on the day that i made this config. The computer gods are telling me something, maybe.  I have been thinking of sticking to the 1050HX but i thought to overcompensate when i saw the 1200 Digistorm Certified as lower price. Then again, high wattage = more money lost. i'll stick to the 1050HX for future SLIing Thanks again to Alex for updating the Stage 2 info for the Sabertooth. The P8Z77-V Deluxe is a sure choice for built-in WiFi but does anyone know if the sabertooth's "Thermal Armor" actually have noticeable effects in the temp side of things? As for the case, i am trying to go for a minimalist look-- Minimal sound (w/o liquid cooling), a low profile look, but kicks ass. The Dreadnought is awesome for having huge 200+mm fans. but there's just something about its aesthetics that i'm not into right now. Maybe if i was buying it a few years ago i would have picked it easily. I know, i'm getting old and picky. i think i'll need to look around for a good balance if there is one since i didn't pay much attention for the case. (Is the Corsair 600T a good one?) It's something to think about more. The Zalmans can go.
Posted: 30 Apr 2012 at 9:39pm |
You're most welcome!
Posted: 30 Apr 2012 at 9:40pm |
The thermal armor does seem to help with temps, but, honestly it's not something that will help a whole lot in stability or overclocking, it's mainly for looks. The Corsair 600T is a great option, so is the Corsair 550D which is on our Black|OPS side of systems.
Asangard
Posted: 01 May 2012 at 7:42am |
Posted: 01 May 2012 at 7:56am |
KaWal...Like Alex said, if the HafX isn't something you can feel the love for  then the 600T or 500R in black or white are very good cases for cooling.
jooks1184
Posted: 01 May 2012 at 8:16am |
Hey Kawal,
As to you question of whether sandy bridge or ivy bridge is better, I would say that for just gaming, sandy bridge should be fine. However, Ivy Bridge does offer PCIe 3.0 which would allow you to take full advantage of the 6 series nvidia cards and/or the 7000 series radeon cards. If you're trying to save money, go sandy bridge. Like someone said above, Ivy Bridge runs faster than Sandy Bridge so you'll be able to achieve a higher OC with SB. Also, the gains from ivy bridge over sandy bridge aren't really significant. Until Intel releases those Haswell CPUs with the 3d transistors, I would say that SB would be more than good enough for you. Anyone please chime in if I'm wrong or anything. Thanks.
I forgot to mention something. I'm not 100% positive but I believe that SB and IB or cross-compatible.
Edited by jooks1184 - 01 May 2012 at 8:17am
Asangard
Posted: 01 May 2012 at 9:32am |
Hey Jooks just a couple of things that you mentioned. The Ivy Bridge CPUs replace the Sandy Bridge CPUs so I don't think Intel is making the Sandy Bridge chips any more. DS is still offering the SB chips in the configuration section though. The Ivy Bridge CPUs actually do use the 3D transistors. Here is a quote from a review by PCGamers: "Ivy Bridge is more interesting because it’s the first chip produced on Intel’s 22nm technology, down from 32nm for Sandy Bridge. That means faster clockspeeds and lower power consumption. Even better, due to the physical restrictions of making semiconductor gates at these improbably small scales it uses the excitingly named ‘ 3D tri-gate transistors‘ which Intel is pioneering here. These basically involve extruding gates upward rather than down flat to increase the surface area available to electrons for activation, rather than laying them down flat. They do both fit the same 1155 socket so IB is backwards compatable with SB but might require a firmware update according to articles I have read. From some articles I have read Ivy Bridge is the end of the line for the 1155 socket. Rumors have it that the Haswell CPUs rumored to be a yr away at least will use a 1150 socket.
jooks1184
Posted: 01 May 2012 at 9:58am |
Thanks for the clarifications :). I know I mentioned this above but now I am having second thoughts, I wonder if the PCI 3.0 will bring significant performance boosts over 2.0.If not, then is there a reason to upgrade to IB. I mean the price difference isn't really anything so that's not an issue. However, i read this review where IB didn't show much improvement from SB. I'll link it when I can. I was hoping to wait for IB but I wonder if I should just settle for SB
Posted: 01 May 2012 at 10:10am |
jooks1184......Ivy Bridge is already out. The Intel Core i7 3770K for example is IB.
Asangard
Posted: 01 May 2012 at 11:10am |
Jooks1184 Ivy Bridge gives about 10% boost in performance. Some reveiw show a little less. But the big difference is in native 3.0 USB (10 times faster access speeds) and as you mentioned 3.0 PCIe which doubles the through put on the Graphics Card side. Also the Z77 motherboards are better engineered so less electricial leakage and the don't have the BIOS bugs in the previous motherboards. Most reviews I have read say that if you already have a Sandy Bridge settup there is no need to rush out and get the Ivy Bridge. But if you are trying to choose between Ivy and Sandy I think it is worth going the Ivy Bridge root. Here is a link to a review of the 3770K Ivy Bridge CPU from overclockers.com:
stayghost
Posted: 01 May 2012 at 3:02pm |
The discussion in the comments of that Overclockers review is making me nervous regarding heat issues with IB. Do you think it's something to be wary of?
I was considering grabbing an ODE 4 but according to the discussion there maybe I should build a custom with SB i5k ?
Asangard
Posted: 01 May 2012 at 3:34pm |
With Ivy Bridge you can get good overclocks at a lot lower voltages that Sandy Bridge. One review I read they got to 4.5Ghz without having to increase the voltage at all. So I don't think that this is going to be an issue. All the early reviews do stress that you need to pay close attention to what you are doing when OCing an Ivy Bridge CPU. You can't OC it the same way as Sandy. It's not as easy as with Sandy but DS are experts so as I said I don't think this is an issue.
josephlee
Posted: 02 May 2012 at 7:58am |
Yeah, that is what I have been seeing too. The OC process for Ivy is a little more complex than Sandy. But that is why we have DC, they have the tools/experience to get it done safe.
