On boxed it this morning and connected it up! The bad part is I wont be able to really play with it till early tomorrow morning do to work. Argh!! I Bleed!
Chassis Model: Digital Storm HailStorm (Black OPS Edition)
Processor: Intel Core i7 960 3.2GHz (Quad Core)
Motherboard: EVGA X58 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series (Hand Tested)
Power Supply: 1000W Digital Storm Certified (Dual/Triple/Quad SLI Compatible) (Silent Edition)
Expansion Bay: USB Digital Media Card Reader (Black)
Hard Drive Set 1: Operating System: 1x (128GB Solid State (By: Corsair) (Model: CMFSSD-128GBG2D)
Hard Drive Set 2: Multimedia\Data: 1x (1.5TB Seagate Barracuda (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) (LightScribe Edition)
Video Card(s): 2x CrossFire Dual (ATI Radeon HD 5870 1GB)
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional (PCI-Express Slot Based)
H20 Tube Color: Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Enhancements: Touch 2000 Aerocool Temperature Display & Fan Controller
Chassis Mods: HailStorm & 950Si: Processor & Video Card Area: Drill and Mount Two Side Window 120mm Fan Blow-Holes
Noise Reduction: Noise Suppression Package (Optimized Airflow & Fan Speeds with Noise Dampening Material)
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz
Memory Boost: Yes, Overclock memory frequency (Includes Memory Fan Kit Installed)
Overclocked Processor Settings
Processor Speed GHz: 3.9
CPU Multiplier: 24
Voltage CPU VCore: 1.38
VDroop Control: Yes
i7 - BCLK MHz: 164
i7 - Voltage QPI\DRAM:
i7 - Voltage QPI\PLL:
i7 - Voltage CPU VTT: 200
i7 - Voltage IOH Vcore:
i7 - Voltage ICH Vcore:
i7 - Voltage IOH/ICH I/O:
i7 - PWM Frequency:
780i/790i - Memory Clock Mode:
780i/790i - CPU FSB MHz:
780i/790i - Voltage FSB:
780i/790i - Voltage SPP:
780i/790i - Voltage MCP:
Overclocked Video Card Settings
Core MHz: 875
Memory MHz: 1225
Shader MHz:
Motherboard BIOS: SZ44
Video Card Driver: 10.1
Chipset Driver: CD
Sound Card Driver: CD
Will post more later!
