Installing FarCry1
Post Date: 2011-12-25
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Topic: Installing FarCry1
    Posted: 25 Dec 2011 at 9:52am
ConfusedTried loading farCry1 unto system with Win7/64bit.Found all the updated patches. but upon loading, the install wizard stops and a box pops up stating the following "Run setup 32.exe on 32 bit windows, or run setup 64.exe on 64 bit windows. Nothing inside the box to pick from. the minute you close the box it take you to the finish box. Now this is a 32bit game, but I have tried all settings in compatibily mode. I even did a complete hard drive cleaning and reinstalled Win7, and half a day getting updates and drivers reloaded. Same problem! Virus program is off also. Even tried in safe mode, same box appears. Loads on my wifes 32bit system with out a hitch. Confused???
  Quote FrankW Quote  Post ReplyReply bullet Posted: 25 Dec 2011 at 11:35am
Hi MDR,
Make sure that Far Cry is being loading into Program Files (X86). This is where your 32bit files should be loaded.
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Posted: 29 Dec 2011 at 4:48pm
It's not going there for some reason. How does one send it there if the install wizard does not set it up?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 29 Dec 2011 at 5:20pm
Hi MDR..When the install disc starts, a couple of screens in it'll tell you the default install path.  It should be C:\ProgramFiles(x86)\Ubisoft\Crytek\FarCry.
It's probably defaulting to just \ProgramFiles\etc...... without the X86.  Hit Browse, and either manually, below Path, type it in or scroll to ProgramFiles(86)in window below  and click.
Great game.  Enjoy.Big%20Smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Dec 2011 at 5:30pm
right click the cd and choose "open" you should then be inside of the folder of the cd, now look for a file that is named "setup 64.exe" or something like that, if you don't have that in any of the folders that are inside the cd then do as the guys say and install it to x86 program folder.
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Posted: 30 Dec 2011 at 9:39am
Thanks guys, I'll try that. My copy is from 2004, setup 64.exe is not there.
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Posted: 30 Dec 2011 at 10:12am
CryOk guys , I placed the 32.exe file into x86 first. came back saying 1155:file C:\program file x86\FC32.msi not found. Went back to dics, copied FC32.msi file to x86. Same window appeared. Run on 32.exe or 64.exe. i then placed them into the common file folder. Same box jumps up! Do I need to place the whole dics into x86?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 30 Dec 2011 at 10:26am
I'm confused.Confused  From my experience, I didn't copy any files or folders from FarCry disc to pc folders.  I put disc1/Install/Play disc into cd, the disc auto loaded, then a couple of screens in, after clicking you agree to play by their rules, etc. , a screen pops with Install path filled in.  The path should be what I listed above with ProgramFiles(X86)\ being the folder. If not you have to manually tell it where to go from that same screen. I clicked cont. or something and then it installed fine.
If that doesn't work, you got me.  Hope this does it, it is a good game.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 30 Dec 2011 at 11:38am
Hi MDR,
It should work just like bprat22 described. Delete eveything and start over. Just insert the disk and follow the installation instructions. The disk will ask you where you want to install the file. If it is not what bprat22 listed above then you need to enter that folder address. The install program will put all the files in that one address.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Dec 2011 at 3:35pm
His disk is old so it does not have the 64bit installer.
I don't think he is able to get pass the installer part to get to what you guys are asking him to do, if I understand him correctly.
did you try right clicking the installer and from properties>compatibility> here chose xp sp3?
You said something about having a virus and the same issue with other apps? is that right?
Edited by DST4ME - 30 Dec 2011 at 3:36pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 31 Dec 2011 at 6:41am
LOL  All the discs are old.  It should work if he followed Frank and my suggestion.Big%20Smile
I think he meant turning off virus protect in case it was blocking program.
He hasn't come back, so hopefully it's loaded any he's deep in enemy territory.Awesome
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 31 Dec 2011 at 2:49pm
if you purchase the new dvd for far cry 1 it will have both 32bit and 64bit.
I believe he can call and request the new one.
Edited by DST4ME - 31 Dec 2011 at 2:50pm
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Posted: 01 Jan 2012 at 9:37am
CryDST4M is rt. Something is missing from a file. But when I run a microsoft dll scan, it says everything is fine no files missing. I can not get FC1 to load to be able to patch it. It's as though the wizard can not load to the path it needs to fully open. Thats why the box that opens says use 32.exe or 64.exe..I'm not a programer, so this is way beyond me. I need step by step instructions. The games site is no help either.They just want you to buy the latest and greatest. Thanks guys, have a safe and good yr, may all your CPU's and GPU's live long and prosper!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 Jan 2012 at 11:00am
Hi MDR.. Happy New YearBig%20Smile
Try this,kinda what DST was saying...Put dvd/cd in drive, when window pops to install or "Open folder to view file', click on Open.......In right hand window look for 'setup' with Application extension.    Right click setup, click properties, click compatibility folder, put check in box 'Run in compatibility mode' and WindowsXP (SP3) will highlight.  Hit Apply and then double click setup file again.
If install box doesn't autoload, just right click Start, open Windows Explorer, dbl click dvd drive and go to setup file and do the same.
If that doesn't work..CryCrytry looking for 32.exe or 64.exe file to dbl click. in windows explorer.
Boy, that's a mouthfull, so I hope it works.
Edited by bprat22 - 01 Jan 2012 at 11:01am
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Posted: 02 Jan 2012 at 9:04am
CrySorry guys nothing worked. Again, the wizard starts to load, but stops. Then that little box appears saying run setup with 32.exe or 64.exe.the minute you click this box to shut, the Finish box on FarCry appears. " It says the wizard was interrupted before Far Cry could be installed." Opening up the disc and looking at the files one will find the following:
DirectX9            6/1/2004   6:35AM       Filer Folder
Languages        6/1/2004   6:37AM       Filer Folder
Support             6/1/2004   6:37AM       Filer Folder
Game                6/1/2004   6:54AM       Cabinet File            1,405 KB
Autorun             2/15/2004 9:20AM       Setup Information          1 KB
FarCry               2/26/2004 9:57PM       Application                   32 KB
FarCryAuto CD 4/23/2004  4:09AM      Application               3,156 KB
FC32                 6/1/2004    6:59AM      Windows Installer... 1,372 KB
Setup.skin         2/23/2004  3:55PM      Skin File                   7,017 KB
setup32             6/1/2004    6:69AM      Application                4,485 KB
Thats it guys, nothing else. oh! by the way. My compatibility mode does not have XP-sp3 only 2. I keep thinking it has something to do with microsofts C++ as mine only goes back to 2005.?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Jan 2012 at 9:21am
DAMN.CryCryI don't know what else to try.  I did lots of searches, curious as hell, and it seems alot of people are having the same issues.
Just to be stubborn on my part, if you rt click setup32 and compatibility with XP sp3 or sp2 it didn't help?
I gotta take off for a little while.  You have my mind reeling.Big%20SmileBig%20SmileBig%20Smile
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Posted: 02 Jan 2012 at 9:31am
CryNope, no help at all. I've tried every compatibility mode avaiable. Need a programmer out there!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Jan 2012 at 2:37pm
contact FC's tech support and tell them you now have a 64bit os and the old copy of fc1 you have won't install on it, ask them for a newer copy with 64bit support.
do you have sp1 on your win7?
MDR View Drop Down
  Quote MDR Quote  Post ReplyReply bullet Posted: 03 Jan 2012 at 6:50am
OopsThanks guys for your help, it's been a ride. Went to Obisoft site and download another copy. $10 bucks. Of course your download comes from Digital River site. Had to download twice, and then redue the patches againUpset They are pushing the new FarCry3 for 50bucks in download form. There is a lot more data files in the startup disc then my old one. Must have something to due with the operating systems used then in 2004 and now. anyway thanks again for your time and help.
Old DS will be a year old in Feb, but keeps humming along.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Jan 2012 at 8:03am
Awesome  Glad to see your finally playing.Big%20Smile
Strange thing is, my original 5 cd set from '04, '05 installs fine on my old Dell and new ODE, both Win7 64 bit.  The files you posted match mine.Frustrated
Some did say different cd's had different 32.exe versions.
Thanks for letting us know.  Don't always get to know what happened.
Enjoy.Big%20SmileBig%20Smile
Edited by bprat22 - 03 Jan 2012 at 12:20pm
This page was generated in 0.1425781 seconds.
