how to turn on hardware virtualization
Post Date: 2012-07-18
dsellens View Drop Down
  Quote dsellens Quote  Post ReplyReply bullet Topic: how to turn on hardware virtualization
    Posted: 18 Jul 2012 at 8:22am
I recently received a Digital Storm Laptop and I can not find where in the bios to turn on VT.  How is that done?
Mordock
  Quote Alex Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 9:51am
If your laptop supports it, there should be a option somewhere in the BIOS for it, did you check your BIOS?
  Quote dsellens Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 12:00pm
ahhh, yeah.  I said I could not find where in the bios to set it.  If it is not there, then it would be a major/major/MAJOR oversight.  this is an Ivy Bridge 8320 so the chip definitely supports it.
Mordock
  Quote Alex Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 12:06pm
I'll ask the team for you.
  Quote dsellens Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 12:11pm
Thank you, will look forward to answer.  ahhh, 3820, not 8320 btw.
Mordock
  Quote Alex Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 2:14pm
The team just got back to me, they said VT-x is enabled by default. You may run the CPU-Z to check it.
  Quote dsellens Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 3:26pm
OK, thank you.  I check CPU-Z and you are correct.  Had never used that before, cool.  My VMware Workstation was not recognizing the VT.  I have found the setting that will allow it to use the VT correctly.  Thank you.
Mordock
