How often to I have to refill watercooling?
Post Date: 2008-07-30
Rolet View Drop Down
  Quote Rolet Quote  Post ReplyReply bullet Topic: How often to I have to refill watercooling?
    Posted: 30 Jul 2008 at 2:59am
Since I gotta move my system out of corner to check reservoir, whats the average amount of time before I have to refill it? Thanks.
workingman View Drop Down
  Quote workingman Quote  Post ReplyReply bullet Posted: 30 Jul 2008 at 7:54am
maximum pc recommends checking levels once a wk and flushing once a yr..fyi
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 30 Jul 2008 at 8:41am
Dont listen to me..ive never had a liquid cooling system in my life...lol.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
Hanns-G HG 281D 28" HDMI Monitor
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 30 Jul 2008 at 9:43am
Im better in real life though, ive gotten so many credit card numbers from people! How do you think i paid for this computer? bwhahahah.......
Just fibbin!
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
250-80-300GB VR HD
Asus Xonar 7.1
  Quote Rolet Quote  Post ReplyReply bullet Posted: 30 Jul 2008 at 3:14pm
My temps on idle are 49-55 and on heavy load mid 70s. Once a week sounds too excessive. I was thinking of checking once a month.
What do you mean by flush once a year? Don't know much about watercooling. I was just thinking of refilling reservoir whenever I see it getting low.
Edited by Rolet - 30 Jul 2008 at 3:19pm
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 30 Jul 2008 at 4:24pm
Well, any system that utilised water for cooling has the potential for algae growth as well as corrosion effects upon metals. If your system uses mineral oil instead, both these primary problems are avoided. I dunno what other issues you may have to deal with... biological buildup and corrosion are prolly the main things to consider. Even with the use of algaecides (sp) and antifreeze, these additives eventually break down. That's prolly another reason for a system flush.
  Quote Rolet Quote  Post ReplyReply bullet Posted: 30 Jul 2008 at 5:19pm
Got this from site which uses same coolant.
"Fluid XP has a 5+ year shelf life but because of the fact that almost all of the tubing used in water cooled computers has some evaporation (due to the fact of the micro pores in flexible tubing), you may need to add a little after two years. This of course depends on how big a reserve you have.
Our ingredients in the coolant slow down the evaporation prcess but do not completely stop it. We recommend that it should be checked from time to time just to be safe. Under normal use the coolant should not have to be completely drained out and replaced for at least 5 years."
This makes me feel a lot better.
Sarah View Drop Down
Hardcore Gamer
  Quote Sarah Quote  Post ReplyReply bullet Posted: 30 Jul 2008 at 6:37pm
I suggest every 6 months to a year, or for that extra reassurance, every 3 months should be okay. However if you notice that your temperatures start to run a little hot then you should defienetly check on your water cooling just to be on the safe side.
Sarah
If you have sales questions, please contact craig@digitalstormonline.com
