How often should I clean my computer?Post Date: 2014-10-16 |
Rockcem
Newbie Joined: 09 Aug 2014 Online Status: Offline Posts: 86 |
Topic: How often should I clean my computer? Posted: 16 Oct 2014 at 5:04pm |
As the title says I was wondering how often should it be cleaned and how should I go about cleaning it, Currently I only had it for about a month and I was just wondering.
*The Beast Has been Acquired*
Quote Reply Posted: 16 Oct 2014 at 5:37pm |
I remove the side panels about every 6 months and use canned air to blow out the cpu cooler, radiator or fins, depending on what you have, the fans, graphics card and across the motherboard. You'll normally see early stages of dust as white buildup on the fans and motherboard. Use short bursts, can upright.
Every situation is different. You can use HWMONITOR, a free download, to check your gpu and cpu core temps under stress. Good to keep track every once in awhile. I do it every week, at least. No vacuum cleaners. Static from it might blow a board. Hope this helps. |
Arisen
Newbie Joined: 15 Oct 2014 Online Status: Offline Posts: 8 |
Quote Reply Posted: 16 Oct 2014 at 5:39pm |
bprat22 is on fire!
Quote Reply Posted: 16 Oct 2014 at 6:58pm |
I dust mine once a month although it doesn't get all that dusty and i use the Metro Vacuum ED500 DataVac which you can find on Amazon
Quote Reply Posted: 17 Oct 2014 at 2:26am |
I am with ArkansasWoman's thinking here. I pull my machine apart once a month and do what I can to remove the little dust bunny critters. Canned air for the internal fans and heatsinks (as bprat says, can UPRIGHT, short bursts) but for the Vanquish filters (both front fascia and PSU filter underneath) I rinse off with water. (Thoroughly dried before reinstalling.) This is also the day that the machine gets 2 full scans MalwareBytes and SuperAntiSpyware, CCLeaner and whatever else I have on hand.
Once everything is cleaned, inside and out, I make a restore point.
Quote Reply Posted: 17 Oct 2014 at 4:51pm |
Given that I have 2x 480mm Radiators, 1x 240mm radiator, a total of 23ish fans (counting in my head as I'm not home right now), plus all the dust filters and the fact that it sits on the floor (yes I know... sitting your on the ground is absolutely horrible.. -_- My desk gets too clutters to give up space.)
I open it up and remove fans and blow everything out once a month. I have a calendar reminder for the first Saturday of every month. It really depends on where you live, position of your PC, etc. If you live in the midwest where it's hot and dusty, and/or it's on the floor, and/or you have pets... you'll want to do it quite often. If you live on the coast (like me), hardware floors, no pets, sits on a table... etc, you can probably do a cleaning every couple of months. |
Quote Reply Posted: 17 Oct 2014 at 4:57pm |
23 or so fans....wow |
Quote Reply Posted: 17 Oct 2014 at 4:59pm |
Don't judge me... I have needs.
Roykirk
Quote Reply Posted: 19 Oct 2014 at 2:19pm |
Make sure you hold the fans still while you're blowing them out or you could burn out the bearings.
Quote Reply Posted: 20 Oct 2014 at 7:24am |
Oh.. this^^ So much this^^ Your compressed air comes out of the can at a really good speed for blowing dust off of things, but can turn the fan blades at a rate they are really not designed for. |
Quote Reply Posted: 20 Oct 2014 at 8:45am |
I don't hold my blades... I like to listen to the whiz sound. *Child at heart*
Quote Reply Posted: 20 Oct 2014 at 10:10am |
Oh... that explains ~so~ much... |
Rockcem
Quote Reply Posted: 20 Oct 2014 at 5:48pm |
So I have read everything and So far what i understand is take apart most of the computer and use compressed air to clean the parts and fans, Any recommendations for the Canned air?
Razorback
Groupie Joined: 18 Aug 2014 Online Status: Offline Posts: 99 |
Quote Reply Posted: 20 Oct 2014 at 6:10pm |
Mine is Office Depot cleaning duster. Not sure if it matters or not. Seems to work just fine for me. Edited by Razorback - 20 Oct 2014 at 6:10pm |
Intel Core i7 6700k 4.5 GHz (OC)
ASUS Maximus Hero VIII 16GB DDR4 3200 MHz 120GB Samsung 840 EVO 250GB Samsung 840 EVO 1TB Seagate (7200 RPM) (64MB Cache) 1x NVIDIA GeForce GTX 1080 8GB |
Quote Reply Posted: 20 Oct 2014 at 7:29pm |
Really doesn't matter the brand of air.... all are going to be basically the same thing. The only thing of real importance with ALL brands of canned air is to keep them upright when using. Never tilt or turn the can as the gases will liquidate and you'll get to shoot a high powered stream of ice into your beloved computer parts.
They ain't gonna like it much. |
