HELP! What wires for dual screens?
Post Date: 2015-03-23
nayots View Drop Down
  Quote nayots Quote  Post ReplyReply bullet Topic: HELP! What wires for dual screens?
    Posted: 23 Mar 2015 at 5:38pm
My Vanquish L4 just got here, and I was about to plug in my displayport into the video card but it doesnt fit. There are DP options, but they are much smaller. What do wiring do I need to set up my dual screens?
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 23 Mar 2015 at 5:41pm
You can get adapters for displayport to HDMI or DVI. The cards typically have 1 displayport, 1 HDMI, 1 DVI-D, and 1 DVI-I.
  Quote nayots Quote  Post ReplyReply bullet Posted: 23 Mar 2015 at 5:43pm
Can I set up both screens with DP? I currently have a DP wire but it's DP large on both sides
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Mar 2015 at 6:16pm
Different model gtx 970s have different video port config. You could have mini displayport. Check the accessory box that came with your rig for DP to mini DP adapter. You might have to get mini to full size adapters to run both monitors. Or hdmi to DP , etc like was said.
  Quote nayots Quote  Post ReplyReply bullet Posted: 23 Mar 2015 at 8:26pm
Whenever I try plugging my monitor in it says "DVI NO SIGNAL" I've tried both monitors with different plug in wires, same thing. What do I do??
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 23 Mar 2015 at 8:39pm
Your card may have a plug in the display port. check closely and just pull it to remove. Asus plugs theirs, not sure about others.
Make sure you are plugging in to the video card and not the built in graphics on the motherboard.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 24 Mar 2015 at 7:53am
Hi Nayots,
Your 970 GPU should have three DP 1.2 connections. As stated they may be mini-DP. I suggest you call DS and a technician will help you get setup correctly for two monitors.
  Quote nayots Quote  Post ReplyReply bullet Posted: 27 Mar 2015 at 2:09pm
My DVI DUAL LINK wire works for either screen, I have DP wire with an HDMI tip + a adapter to Mini HDMI this is the one not being recongized. I've been calling tech support for a while, no asnwer :(
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 27 Mar 2015 at 8:45pm
Did you try any of the suggestions on your other post?
Go to control panel - devices and printers and see if the monitors are listed there. If not, at the top click 'add a device' and follow the leads to 'find devices'.
Then go to device manager - display adapters, and look for the Nvidia GTX970. Disable any others.
Go to 'monitors' and make sure yours are listed. If it says "generic pnp monitor" - turn off computer and monitors, unplug all from the wall and unplug monitor cable from the monitor for 2 minutes, then plug in the monitor cable first, and plug in the power cords and boot up as normal. Then recheck the above.
check device manager for any colored ! or ? marks which means something is wrong.
Post back the results of what you did and what you found.
Please try what we suggest and let us know what results you got. We are working blind as we must go just on what you tell us.
The call to DS may be the best solution as they can log on to your computer with logmein and get to see what we can't.
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 27 Mar 2015 at 11:42pm
Try this also.
hit (windows key) + P. You should get a menu on the right to select PC screen only (screen1), duplicate, extend, and second screen only.
What do you get? Can you select second screen only and get anything on that screen?
