Help selecting appropriate config
Post Date: 2010-08-02
Whoops View Drop Down
  Quote Whoops Quote  Post ReplyReply bullet Topic: Help selecting appropriate config
    Posted: 02 Aug 2010 at 10:18am
Hello.  I've been looking around online for a good place to buy my first ever gaming PC.  As a lifelong mac user, I really don't know a whole lot about PC's, though over the past few days I've picked up some rudimentary knowledge.
I ran across this site on a reccomendation, and it looks to be filled with some very knowledgable folk, so I'm making a standard "Help my setup not suck" topic here.  Any help would be greatly appreciated.
Details:
Budget:  $2,000 - $2,200.  This does not include monitor, keyboard etc.
Purpose for PC:  In terms of gaming prowess, I'm looking for something that could play games like WoW and Starcraft 2 at highest possible settings with complete stability (these are just examples as they're the only PC games I own at the moment).  In addition, I intend to make this PC the hub for my entire media center (Movies, music, games etc.)
Monitor:  23" HDMI LCD, 1920 x 1080
Qustions:
1:  In regards to the video card, the ones I see mentioned most often are the ATI 5870, 5970, and the NVIDIA GTX 480.  What exactly is the difference between these video cards?  And which would be ideal for gaming on a single monitor setup?
2:  In regards to overclocking, what are the risks involved?  What sort of alterations to I need to make to accomodate overclocking?  And what parts of the PC are even worth it?  (ie. which parts will overclocking grant a *significant* increase in performance)
Other notes:  This setup is not customized at all, I'm using this as a base because it is the most appropriate for my budget.
Thanks in advance for any help/advice that you have.
Chassis Model: Special Deal Hot Seller - Black OPS Assassin Edition
Motherboard: EVGA X58 Micro Edition SLI (Intel X58 Chipset)
Power Supply: 750W Digital Storm Certified (Dual SLI Compatible) (Silent Edition Recommended)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM)
Video Card: 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
Extreme Cooling: Standard Factory Heat-sink and Fan
Benchmarking: - No Thanks
"Only an idiot would quote himself" -me-
!ender_ View Drop Down
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 02 Aug 2010 at 2:36pm
youre in a good place price wise, gives you a good amount of flexibility, id start here: $1982
http://www.digitalstormonline.com/comploadsaved.asp?id=427732%20
added in a 1tb drive becuase you mentioned media use/storage
overclocking is getting really close to normal these days, with the case selection on this site, the only change you need to make is adding a good cpu cooler, which is already included in my link
the FIRST thing i would add if you could afford a price bump would definitely be a sound card. if you consider sound important at all this is the best place to spend the next $150
personally, i would take that over a second HDD, but i dont know how much you intend to store, 500gb is a lot of real estate, i think a lot of people buy high to follow the crowd, ive never used more than 300 and i edit movies, work in photoshop, always have several games installed, and have a good amount of movies/shows/junk too
as far as the difference in the video cards, ill have to leave you to spend some of your own time looking, the first difference is the brand, price, features... shouldnt take more than a few hours looking online to be informed of all the differences
This page was generated in 2.392578E-02 seconds.
