Help Locating Support MBPost Date: 2015-01-03 |
blanmgr
Newbie Joined: 03 Jan 2015 Online Status: Offline Posts: 5 |
Topic: Help Locating Support MB Posted: 03 Jan 2015 at 10:34am |
[>600 USD] Expectations: [I need a motherboard to support the PCIe bus crossover for (2) MSI Lightning cards. I blew my last board and 2 850w PSU and contacted Gigabyte to find out my 2011 socket i7-3820 X79 board doesn't support it.] Usage: [Gaming System] Special Needs: [None] Saved Ticket #: [None] Specifications: [Current System: HAF X Full Case 32 GB - Corsair Vengeance (2x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ16GX3M2A1600C10) 2 - MSI R9-290x Lightning 6 - Internal 2 TB WD drives 1 - Corsair H100i CPU Cooler 1 - Rosewill ATX 12V 1000W SLI 80 Plus Gold Certified Modular Active PFC Power Supply CAPSTONE-1000-M X55 Rhino HOTAS Throttle/Joystick setup Saitek Pro Flight Rudder Pedals 6 - External 3 TB WD drives ] |
Quote Reply Posted: 03 Jan 2015 at 10:42am |
I'd look around for an X79 mobo that supports CrossFire...I'm really surprised your current one doesn't support CrossFire...there are 40-lanes of PCI-e 3.0 from the processor and it is usually SLI that isn't support if anything is missing. Your case supports ATX, E-ATX, and ATX-XL, so pretty much any board you select should fit.
blanmgr
Quote Reply Posted: 03 Jan 2015 at 10:48am |
Unfortunately, I have a Gigabyte GA-X79-UP4 and blew the board and Corsair 850w PSU. I submitted a ticket to Gigabyte and they responded yesterday and said the GA-X79-UP4 does not support the new R9-290x crossover via PCIe bus. I can only go with people who have setup the new crossover with the R9-290x because the motherboard manufacturers are not noting if the boards support this new crossover connectivity (non crossover bridge connector). BL |
Quote Reply Posted: 03 Jan 2015 at 11:31am |
Yeah, its called XDMA and has the two cards in CF talking through the PCie and not a seperate bridge. I believe it started with the 290x cards.
I would think most mobo's do support it, at least after a AMD Catalyst driver update, but here's an article where they did test 2x 295x in quad. CF. They used the MSIX79A GD45 plus mobo. http://www.tomshardware.com/reviews/radeon-r9-295x2-crossfire-performance,3808.html Here's the board..... http://www.newegg.com/Product/Product.aspx?Item=N82E16813130681 Most boards don't mention the feature but I think it's understood but I can't say for sure. Hope this helps out. Good Luck. Double check my work before you spend any money. Edited by bprat22 - 03 Jan 2015 at 11:32am |
blanmgr
Quote Reply Posted: 03 Jan 2015 at 2:31pm |
Thanks.
Any opinions on the following motherboard? MSI X99S GAMING 9 ACK EATX DDR4 3000 LGA 2011-3 Motherboard BL |
Quote Reply Posted: 03 Jan 2015 at 2:50pm |
Your 3820k won't fit in the version 3 lga 2011. Way too many motherboards to know them all so maybe others know something of that one.
blanmgr
Quote Reply Posted: 03 Jan 2015 at 5:24pm |
Thank you. I overlooked the version 3 in the 2011 processor.
It seems the regular 2011 boards are starting to become very extinct. The possibility of locating these boards supporting the PCIe lanes are becoming a problem. I just visited MSI website and looked at their VGA compatibility chart for their gaming and oc boards. The charts state they only support 1 R9-290x for multi-graphics technology. I will need the help of the community to located a 2011 board that supports 2 R9-290x cards. BL |
Quote Reply Posted: 03 Jan 2015 at 5:49pm |
I believe the Asus Rampage 4 Black Edition with its lga2011 for your chip will support XDMA. I'm sure other Asus boards also do but...
Here's another link where they did cf the 290x with that board. http://www.tweaktown.com/tweakipedia/47/radeon-r9-290x-cf-amd-am3-vs-intel-lga-1150-vs-lga-2011-at-4k/index.html Again, double check their website. I'm on a tablet and hunting around can be a pain. Amazon and TigerDirect have them. Edited by bprat22 - 03 Jan 2015 at 5:55pm |
blanmgr
Quote Reply Posted: 03 Jan 2015 at 8:01pm |
Thank you once again. I checked the vendor website and did some research on the board. The board is a favorite for cross firing R9-290x on a 2011 board. You're right, there are some still available on Amazon and Tiger. I am ordering the board now. Thank you. BL |
Quote Reply Posted: 04 Jan 2015 at 2:52am |
My pleasure.
Let us know how you make out. Have fun. |
