Harker 17.3Post Date: 2015-03-15 |
adamgre99
Newbie Joined: 15 Mar 2015 Online Status: Offline Posts: 6 |
Topic: Harker 17.3 Posted: 15 Mar 2015 at 10:25am |
2500 to 3000 Expectations: FPS Gaming Usage: World of Warcraft, Skyrim, and other games Special Needs: mainly gaming while on the road Saved Ticket #: 1163330 Hi Y'all I work as a Flatbed OTR truck driver with TMC and when ever I get the chance I hop on my laptop that I have now to pla some World of Warcraft for some questing and raiding. With the laptop that I have now my FPS with just questing is around 50 to 60 and raiding is down to 30 FPS or below. WoW is the game I play the most out of all games. I play over wifi from truckstops or Hotspots most of the time. I want to make sure that the Configuration that I saved #1163330 is worth the amount to replace the old computer that I have and here is the build of my laptop that I have now. Windows 7 Home Premium (x64) Service Pack 1 (build 7601) Install Language: English (United States) System Locale: English (United States) Installed: 7/15/2010 3:36:07 PM Boot Mode: BIOS (Secure Boot not supported) Acer Aspire 7551 V1.18 System Serial Number: LXRCE020731190060E2000 Chassis Serial Number: LXRCE020731190060E2000 Enclosure Type: Notebook Processor a Main Circuit Board b 2.20 gigahertz AMD Phenom II N970 Quad-Core 512 kilobyte primary memory cache 2048 kilobyte secondary memory cache 64-bit ready Multi-core (4 total) Not hyper-threaded Board: Acer Aspire 7551 V1.18 Serial Number: LXRCE020731190060E2000 Bus Clock: 200 megahertz BIOS: Phoenix Technologies LTD V1.18 04/25/2011 Drives Memory Modules c,d 612.50 Gigabytes Usable Hard Drive Capacity 415.64 Gigabytes Hard Drive Free Space Optiarc DVD RW AD-7585H ATA Device [Optical drive] TOSHIBA MK6465GSX [Hard drive] (640.13 GB) -- drive 0, s/n 31HWB0EZB, rev GJ003A, SMART Status: Healthy 8192 Megabytes Usable Installed Memory Slot 'S1' has 4096 MB Slot 'S2' has 4096 MB Local Drive Volumes c: (NTFS on drive 0) 612.50 GB 415.64 GB free AMD Radeon HD 7400M Series [Display adapter] Generic PnP Monitor (17.6"vis, January 2009) Atheros AR5B97 Wireless Network Adapter Edited by adamgre99 - 15 Mar 2015 at 10:56am |
adamgre99
Quote Reply Posted: 15 Mar 2015 at 10:28am |
I just want to make sure that the configuration 1163330 will be able to give me a lot more then what I got now. I do know that it is nowhere near what a desktop can do but with being on the road all the time, laptops is all I can do. would you all know what kind of FPS I would get with the new configuration
Pacesetter
Quote Reply Posted: 15 Mar 2015 at 11:36am |
You are getting a solid build and I would reasonably expect nearly double the performance you are getting now. Some public 'hotspots' use throttled performance so on the road you may see variances but as far as machine performance, you are gonna go "WOW"! |
adamgre99
Quote Reply Posted: 16 Mar 2015 at 1:37pm |
thanks.. with what I got now to pull 50 to 60 FPS is everything on low. Hoping to be able to at least do medium settings and pull better FPS
Pacesetter
Quote Reply Posted: 16 Mar 2015 at 2:24pm |
With this set-up WoW will probably auto=set to high/ultra. For me I just set ground clutter to low because it the grass is higher than my gnomes and goblins and it's easier to find stuff on the ground.
I'd expect you to see FPS increase of 30-50 in the world and 20-30 in raid environments. On wireless you might need to tone down particle density in raids as it can get pretty wild at times. |
Roykirk
Quote Reply Posted: 17 Mar 2015 at 1:01pm |
As others have said, you should definitely get plenty of FPS in WoW on High/Ultra with that build. Keep in mind that on battery the GPU and CPU will throttle down, so FPS will go much lower. While on battery you'll need to crank down the settings to Medium most likely to maintain good FPS. If you're able to keep it on AC power while on the road, you definitely want to do that.
EDIT: I'd recommend you not post serial numbers from your current system. Just a good habit. Edited by Roykirk - 17 Mar 2015 at 1:02pm |
Pacesetter
Quote Reply Posted: 17 Mar 2015 at 1:16pm |
This is true. I assumed he had a 110V outlet or at least a 12V - 110V adapter in the truck but should have made the distinction. Thanks for keeping me honest. : ) Edited by Pacesetter - 17 Mar 2015 at 4:38pm |
adamgre99
Quote Reply Posted: 19 Mar 2015 at 9:13am |
I do have power in the truck. 3000 watt inverter. So I am good there. Now when purchasing the laptop. Digitalstorm does takes all major credit cards correct? I plan to purchase this with my American Express
Quote Reply Posted: 19 Mar 2015 at 11:48am |
I dunno you might need to call or email and ask Edited by ArkansasWoman777 - 19 Mar 2015 at 11:48am |
Pacesetter
Quote Reply Posted: 19 Mar 2015 at 3:32pm |
They do take credit cards but you'll have to ask about American express.
maybe Alex will see this and give a definitive answer. : ) |
Quote Reply Posted: 19 Mar 2015 at 3:58pm |
We don't really accept American Express.
Clay
Quote Reply Posted: 19 Mar 2015 at 7:56pm |
Nice looking build
I7 13700KF 5.4hz
adamgre99
Quote Reply Posted: 21 Mar 2015 at 5:18am |
Well, that is going to make it hard to purchase the laptop, crying shame too. AmEx is all I have so looks like I might have to go somewhere else for a laptop which really sucks |
Quote Reply Posted: 21 Mar 2015 at 6:14am |
Adam, there are other options you can probably use: such as wire transfer which i used, paypal, check
Edited by ArkansasWoman777 - 21 Mar 2015 at 6:15am |
adamgre99
Quote Reply Posted: 21 Mar 2015 at 6:37am |
Oh . thanks for the info. I will probably use Paypal or such. cause this laptop is still looking better then ----- (since they were taken over by ------) Edit: Removed competitors' name. - Snaike Edited by Snaike - 21 Mar 2015 at 7:54am |
Quote Reply Posted: 21 Mar 2015 at 6:55am |
You're welcome
Edited by ArkansasWoman777 - 21 Mar 2015 at 6:56am |
Roykirk
Quote Reply Posted: 21 Mar 2015 at 12:40pm |
That should work. I have my AmEx connected to my PayPal account. |
Quote Reply Posted: 22 Mar 2015 at 2:37pm |
Ah, I should have thought of that. Great suggestion!
