Hailstorm II vs Aventum IIPost Date: 2015-04-23 |
Matt714
Newbie Joined: 21 Jan 2015 Online Status: Offline Posts: 2 |
Topic: Hailstorm II vs Aventum II Posted: 23 Apr 2015 at 9:04am |
Hi,
How many fans does the Hailstrom II come with? I know that for the Aventum, it's 17. However, the HS II doesn't seem to come with more than the stock Corsair 900D fans. |
Quote Reply Posted: 23 Apr 2015 at 12:07pm |
The Hailstorm 2 comes with the default 3 x 120mm in the front and a rear 140mm fan I believe. The other fan options are dependent on the water cooling rad setup. A 480 mm rad in the top and another in the bottom would add 8 more 120mm fans in theory. The bottom can also house another rad on the other side, but the psu blocks it to a 240mm rad usually.
You could also just have fans added to the top, without a rad, and just for added case cooling. Hope this helps. Edited by bprat22 - 23 Apr 2015 at 12:07pm |
Quote Reply Posted: 23 Apr 2015 at 3:32pm |
Just to shed some light, the AVENTUM is a complete different ballgame than the HAILSTORM desktop lines. It features unique engineering and design elements that make it a far more high-end system. Check over both of the "Overview" sections on the product pages to get a good feel of how they compare.
If you have the budget, the AVENTUM is definitely the way to go. |
